Old Aug 03, 2012, 12:23 PM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Mounting the Plate.
Well after much thought...here is what I am going to do
Taped the ole Typhoon motor to a plastic tube...pushed the motor forward and bolted it to the mount plate.
Then a 60mm spinner base plate and collet were used to clamp to the motor shaft and hold the plate in place.
Unless someone has a better idea...am going to mix up the JB weld this after noon and put it in
arcticflyer is offline Find More Posts by arcticflyer
Old Aug 03, 2012, 03:38 PM
Joined Jan 2006
Mount is in!
Well I had to get help from the wifecause I needed three hands but the mount is JB welded in and the plane is hanging in the closet till tomorrow morning...we shall see
Old Aug 03, 2012, 03:53 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
thats the way to do it.... looks very good..
sebbe is offline Find More Posts by sebbe
Old Aug 03, 2012, 04:00 PM
Rolf D. is offline
Find More Posts by Rolf D.
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
I am very busy at moment, next days I show you how its working without help from your wife
there are other interesting funny things where she can help
otherwise my girl is my helping hand , starts my hotliners, looks that I load my Lipos , has a look if all is ok with the plane, makes the videos - photos.
and when I ask her when I do changes - she gives professional advice ....
no I dont sell her and dont grand her
Rolf D. is offline Find More Posts by Rolf D.
Old Aug 04, 2012, 09:54 AM
Joined Jan 2006
Mount In.
Took the spinner off this morning and all looks well The mount looks straight but I won't know till all is bolted up and I get the incidence meter out
Next is mounting the tail and getting the incidences correct I do not want the wing and tail to differ...want everything at zero degrees if possible. That tail will be a challenge
Old Aug 05, 2012, 10:39 AM
markusvt is offline
Find More Posts by markusvt
215.0 MPH
markusvt's Avatar
United States, VT, Essex
Joined Jul 2007
Looks nice and clean. I like JBweld too, stays put for sure.
Getting the tail pinned, aligned and glued is the worst part of the whole project IMHO!
markusvt is offline Find More Posts by markusvt
Old Aug 05, 2012, 11:49 AM
Rolf D. is offline
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
Hello Arctic
what kind of prop do you want to use, "normal" propeller or folding prop ?
next question:
how many rpm do you think you get with your motor ?
next question:
is this an aeronaut spinnercap ?
for how many rpm do they mean you can use it ?
next question:
for how many KW is it like the manufacturer / distributor ?
speedflying brings a huge lot of problems and lot of points you have to watch out for
Old Aug 05, 2012, 03:23 PM
Joined Jan 2006
Rolf...that Aeronaut was only to mount the plate...it does not let enough air in and is the ugliest spinner I have ever seen
Will be using one of my True Turn Turbo Cool spinners depending on which prop I decide to use. They cut me a spinner for 7x10 APC and I had a custom cut spinner done for the Aeronaut yoke. Will say this this...the TT's ain't cheap but you get what you pay for! And they let in a killer amount of air into the motor!
For the maiden I will start out with a totally expendable power system (ie. cheap ESC, cheap Typhoon 1350kv motor, cheap Turnigy 5S battery) just in case
After surviving the maiden I am going to put a Mega 22/60/1E (about 1400kv) in it and see how far we can go. Then...I plan on getting one of Steve's 1521/2D's (1425kv) and running some head to head tests. Should be interesting, fun, and crazy fast
I'm a pretty good way off from maiden. Have to get the tail feathers on next and I want them straight so some thought is going to go into it first and a second opinion from a good builder friend of mine.
Oh yeah...as far as RPM's are concerned. Am looking for whatever will get me to 4KW to start. I have a set of Marcus K's 7x13 folders and a bunch of APC sport and pylon props. Getting good speed props is a problem over here as you know...am waiting on you to get some good stuff in stock, hint...hint!
Chris, if you're home and read this I'd like to stop out this week and have you take a look if that is OK?!
Old Aug 06, 2012, 04:03 AM
Rolf D. is offline
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
I am waiting for my little beast who brings the Baby forward - get it in around 10 - 14 Days.
good point by the motor is - he will close the hole in the fuse and the spinner is a bit smaller than.
also too I got at Unterwössen Flightfestival some different props who bring best performance with the motor. and as a good advice I do not use Graupner DES 448 BB MG Servos. by a speed over 400 km/h they didnt work fine. So I take now Graupner DS 3288 BB MG because as per Erwin ( Eisvogel ) they work fine.
Old Aug 06, 2012, 05:16 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Rolf, how much is the cost of that outrunner ?
Old Aug 06, 2012, 12:38 PM
Rolf D. is offline
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
quality and power and all special has a special price
Old Aug 06, 2012, 01:14 PM
Eisvogel is offline
Find More Posts by Eisvogel
E.S.
Bavaria
Joined Dec 2008
http://www.rs-e-motoren.de/joomla/in...=122&Itemid=87
Eisvogel is offline Find More Posts by Eisvogel
Old Aug 06, 2012, 01:19 PM
scorpion-fan is offline
Find More Posts by scorpion-fan
Joined Nov 2008
sebbe,
390 euro!
price list:
http://www.rs-e-motoren.de/joomla/im...t_jan_2012.pdf
scorpion-fan is offline Find More Posts by scorpion-fan
Old Aug 06, 2012, 01:50 PM
markusvt is offline
215.0 MPH
markusvt's Avatar
Joined Jul 2007
Nice looking servo spec wise, $91 US dollars each!
Specification
Torque at 4.8V, approx.: 64 N/cm
Transit speed at 4.8V, approx. : 0,11 Sek/40°
Holding torque 6.0V, approx.: 159 N/cm
Charging rate at 4.8V approx.: 1110 mA
Transit speed at 6.0 V, approx. : 0,09 Sek/40°
All-up weight, approx.: 21,5 g
Angular travel incl. trim, approx. : 2 x 45 °
No-load current drain, approx. : 9 mA
Torque at 6.0V, approx.: 76 N/cm
Charging rate at 6.0V approx.: 1240 mA
Dimensions (LxWxH): 30 x 11 x 29 mm
Holding torque 4.8V, approx.: 135 N/cm
Bearings: Lager bb2x
Gear unit: Getriebe mg
Operating voltage : 4,8 ... 6,0 V
Old Aug 06, 2012, 03:32 PM
Rolf D. is offline
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
Originally Posted by scorpion-fan View Post
One euro to much, accurately 389 Euro ;-)
best regards
rolf
Discussion HJK Speedwing LP1 Build sykotic High Performance 431 Jan 05, 2015 01:44 PM
Discussion Micro Shrike Build Thread (was Mystery Build Thread) AndyKunz Electric Plane Talk 101 Dec 05, 2013 09:50 AM
Discussion Carrotcake's 1/10 Traxxas E-Revo Monster Truck-Photos/Discussion/Tips/Info Thread carrotcake Electric Power Cars 583 Jan 07, 2011 05:23 PM
Discussion tHe MoNsTeR Is AwAke OFFICIAL 2010 Build ThReAd (56k warning) Bruzzer Off-road Cars 0 Dec 31, 2009 11:04 AM
Canterbury Monster F20 build thread Fourthearth Slope 59 Jun 20, 2006 10:09 AM
