Old Jun 19, 2012, 04:58 PM
MassiveOverkill is online now
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
What timing should I set my Seaking 120A ESC
So I have a CF2812 3300KV 8 magnet pole, 12 coil brushless on 2200 mAh 3S 30C batteries. What should my ESC timing be?
Pics:
Left motor is a standard CF2812 brushless. Right is Joysway frankenbrushless that I can't find anywhere. They removed 6 magnets (14 on left, 8 on right) and beefed up the gauge of the windings:
Motors put back together:
Windings of the stock Joysway Frankenbrushless:
MassiveOverkill is online now Find More Posts by MassiveOverkill
Site Sponsor
Old Jun 19, 2012, 06:03 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
So the motor on the right is a stock motor..................you didnt remove the magnests?
scorpion1 is offline Find More Posts by scorpion1
Old Jun 19, 2012, 06:39 PM
Joined Feb 2011
No, Joysway did that. I say Joysway because Google to infinity doesn't bring up any motor in this configuration. Actually I wish I could reproduce this configuration as I could just modify a standard CF2812 motor. If you look at the Joysway, the magnets are slightly bigger and if you look close, you may be able to see the slots machined into the outer hub to hold the magnets in place while they are epoxied.
Site Sponsor
Old Jun 19, 2012, 06:50 PM
Pseudonym is offline
Find More Posts by Pseudonym
Pseudonym's Avatar
Joined Apr 2012
Does the manufacturer of the motor have any reccomendations? I would probably start at 7.5 degrees and re-assess the situation from there if you have nothing else to go on. Typical smaller/higher kv outrunners run relatively low timing relative to larger outrunners.
Pseudonym is offline Find More Posts by Pseudonym
Old Jun 19, 2012, 09:39 PM
Joined Feb 2011
No recommendations, but Google says usually lower pole motors run lower timing while the more poles you get the more timing you can add.
Site Sponsor
Old Jun 19, 2012, 10:02 PM
Pseudonym's Avatar
Joined Apr 2012
Higher pole count outrunners sometimes run higher timing, but they are also usually lower kv and low RPM setups.
Take, for example, the scorpion 3126 brushless outrunners. They are 8 pole motors and scorpion reccomends 5 degrees of timing.
Since you have a modded motor it's unknown how it will react, but I would try 7.5...check speed and temps relative to run time and adjust the timing next run and check again.
Old Jun 21, 2012, 07:34 PM
Joined Feb 2011
OK guys, I got my Seaking 120A ESC installed and man this thing jumps out of the water!! I've only done short 1-2 minute runs and the motor is running really hot. The driveshaft is pretty friction-free, but as I said in the other thread, a little heavier than the stock drivetrain. I went from a 30mm prop to 32mm. I guess I could go back but I don't think it's the prop.
I've tried 3.75, 7.50, and 11.25 ESC timing and she still runs hot. If it's a timing thing, it should run cooler the lower the timing I use right? Cooling tube spits out a nice stream of water.
What do you think, try 0 degree timing? BTW I'm glad I got the programming card.
Oh, it's weird hot the motor responds to timing. When I had it at the most advanced of 11.25 the drivetrain sounded like a bumble bee, whereas the lower the timing I used the smoother she ran. I think I just answered my own question but would like more input.
Thanks.
Site Sponsor
Old Jun 21, 2012, 11:02 PM
Joined Feb 2011
I had to ditch the new compression collette as it was too heavy and unbalanced. I drilled out my old brass collette to accomodate the larger .130 flexshaft as well as put some hot glue at the bottom of the motor so it mates with the plastic and vibrations are much less now.
Old collette was only 7 grams, new one was 12.
Site Sponsor
Old Jun 22, 2012, 06:16 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Heavy won't add vibration, but unbalanced could.
Did you switch from a 30mm plastic prop to a 32mm metal prop? Did you add more pitch too?
wparsons is offline Find More Posts by wparsons
Old Jun 22, 2012, 07:48 AM
Joined Feb 2011
Well the magnet casing probably isn't perfectly balanced, so the heavier motor coupling just made things worse (in addition to itself not being balanced). Vibration in the orginal setup as just a small buzz, with the new motor coupling, it was a big racket.
Went from plastic to plastic. I'm guessing my stock 30mm shaft fit the same dimensions as the one from OSE. I got the OSE 32mm
30mm Diameter, Pitch 1.4x30=42.0mm or 1.65"
32mm Diameter, Pitch 1.4x32=44.8mm or 1.76"
I'll know tonight after work if swapping the orginal collete back in did the trick.
Site Sponsor
Question Tacon 3674 1300kv and seaking 120a frankykae Racing Boats - Electric 6 Mar 16, 2012 09:25 PM
Discussion Seaking 120a help willy007 Racing Boats - Electric 11 Feb 01, 2012 07:47 PM
Discussion Help Please! what should i set up my CC25 using a Align 430L 3550 wac Castle Creations 1 Jul 04, 2006 07:28 PM
Discussion Discussion - Help Please! what should i set up my CC25 using a Align 430L 3550 wac Power Systems 1 Jun 12, 2006 12:54 PM
Should I set my Brushless ESC to fast start? sirdirk007 Power Systems 0 Mar 29, 2005 11:32 AM
