Old Nov 09, 2001, 10:37 AM
Darwin is offline
Find More Posts by Darwin
Darwin's Avatar
United States, IN, Lafayette
Joined Dec 1996
Need In-Flight Video TX/RX
Hi, Guys:
I am currently pulling together a project to build a show plane for this coming year's meets (Mid-Am, NEAT, etc). As part of the project, I have need of a TX/RX set that will transmit video data line of sight in the same range envelope as our control radio gear. HAM license status is not an issue.
There will be an independent 12-14V power supply on board the aircraft specifically for the entire video system. Ideally, the TX/RX should be either two channel (2 separate video sources) or should be switchable between the two sources in flight.
I am interested in any help I can get. I browsed the search function on the group, but there seems to be a lot of background noise of smaller, lower range systems.
Regards,
Darwin
Darwin is offline Find More Posts by Darwin
For Sale In flight video camera with Rx/Tx neilo Aircraft - Electric - Airplanes (FS/W) 7 Oct 19, 2005 01:03 PM
In flight video - from the Big T Sal C Electric Plane Talk 17 Apr 15, 2002 08:36 PM
Video Display for in-flight video or anything Kosh Aircraft - Electric - Airplanes (FS/W) 0 Feb 25, 2002 01:09 PM
In-flight video power converter camship Power Systems 8 Oct 12, 2001 07:42 AM
need heli.i have gyro,tx,rx,hs81mgs,batts allready Kevin Graehl Electric Heli Talk 9 Aug 03, 2001 12:07 AM
