The pitching moment caused by the thrust line is exactly like turning a bolt with a wrench. Think of your hand as the motor, the wrench as the pylon, and the center of gravity as the bolt. By looking at it this way you can see that an engine on a pylon directly over the CG is the worst case. You can not fix this by tilting the motor. The only thing on an airplane that can counter the pitching moment from this is the horizontal stabilizer. Making the HS that you have won't be very effective during takeoff because there's not much airflow over it yet. What you need to do is strengthen the vertical fin and move the horizontal up int the prop wash.
http://www.rcgroups.com/forums/showt...5#post11005529 http://www.rcgroups.com/forums/showt...24#post7092431 --Norm |
| Thread Tools | |
| Help! Extreme thrust angle on pusher | nomadic80 | Beginner Training Area (Aircraft-Electric) | 11 | Jun 21, 2012 08:19 AM |
| Question Down and Right Thrust on non-angled firewall | Thermalin | The Builders Workshop | 8 | Jun 18, 2012 07:59 PM |
| Help! Motor thrust angle on pylon racer | knifeedge63 | High Performance | 12 | Oct 14, 2011 03:08 PM |
| Discussion Fighting CG, thrust angle, and trim. Should a super decathlon be this difficult? | stgdz | Electric Plane Talk | 30 | Oct 02, 2011 12:02 PM |
| Question Can thrust angle cause rolling out of loops (unintentionally)? | omster | Electric Plane Talk | 12 | Sep 26, 2011 12:42 AM |
