Old Jun 19, 2012, 11:05 AM
Joined May 2012
got a question about finding out what a motor(s) needs
I bought an electric motor off Ebay. This is something special. It is a contra-rotating propellor electric motor. I had thought that it'd be just one electric motor with some kind of planetary gear based transmission to drive both props.
It is not.
It is two motors mounted coaxially, each motor driving a prop. The props are approximately 7 inches diameter.
I have one problem. The unit did not come with a spec sheet, and the seller says that they can't get one.
So, not having a lot of experience with electric flight motors for RC, I'm asking how I'd be able to determine not only the type of battery pack, but also what kind of electronic speed control this'd take, what kind of power requirements, that sort of thing.
When I saw this, I saw a golden opportunity to build something that's been tickling the back of my mind for years: a Fairey Gannet, although a Westland Wyvern comes in at a close second. The Gannet is a rather interesting looking tubby lady, while the Wyvern looks like either a Sea Fury or a Sea Fire on steroids.
But, due to the size of the unit, I doubt I'd be able to build a particularly large model, nor even a very detailed one. Mebbe a sport scale fun flyer, or even a stand way off scale model.
But, first I have to figure out how to power this little beastie.
The wires aren't even labelled, so I'm not sure which is the postive wire, negative wire, or the ground wire.
maxwill is offline Find More Posts by maxwill
Old Jun 19, 2012, 11:35 AM
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Maxwell
Welcome to RCG
If your contra system has 3 wires from each motor, it is brushless, and requires two brushless ESCs to operate it.
Does it look something like this?
http://www.hobbyking.com/hobbyking/s...dProduct=17150
Can you post a picture?
rick.benjamin is offline Find More Posts by rick.benjamin
Old Jun 20, 2012, 03:52 AM
Joined May 2012
Unfortunately, I don't have a camera with which I can post a picture.
It is kinda like that, yet unlike, because the motors are a bit longer individually, and has three blade props.
But yes, each motor has three wire, but they aren't tagged or otherwise labelled. I'd at leat like to be able to find out which wire is the ground.
They are brushless.
How do I determine which esc to use(power output/voltage)?
I'm in the dark here, and am not sure how to grope around. I'm afraid that if I connect the wrong wire combination, I might fry the unit.
Old Jun 20, 2012, 07:51 AM
Staffs, UK
Joined Nov 2003
Brushless motors don't have a "ground" wire. All three wires are connected to the 3 phases of the windings. To connect them to a brushless ESC just connect in any order, see if the motor turns the right way and if it doesn't just swap over any two of the three connections. Sounds odd but that's how it works. Oh and before you ask, you can't really test anything without an ESC, a brushless motor will not run at all unless it's connected to a brushless ESC.
If you tell us the rough size and weight of each of the motors are we can make a reasonable guess at what sort of power they might want. But so far you've given us nothing to work on other than "approximately 7 inch prop"....from just that I'd guess at probably a 3S 11.1V battery and probably less than 25A...but I could be way off.
Steve
slipstick is offline Find More Posts by slipstick
Old Jun 20, 2012, 09:09 AM
Joined May 2012
Well, the motors are .915" in outer diameter, and each one is approxinately .47" long, the whole unit being 2.75" long, including the props and spinner, and looks more compact than the one in the pic that was posted. The front prop has the legend EP-7035X3, the rear prop has on it EP-7035RX3.
Does this help?
I didn't know you could hook the wires up in any old way.
Old Jun 20, 2012, 02:43 PM
Staffs, UK
Joined Nov 2003
23mm = 0.9" which suggests that what you have is very close to the Hobbyking one. It uses 8x4 2-blade props which are equivalents to your 7x3.5 3-bladers so I'd guess that the specs are as near to identical as makes no difference. So 3S and a pair of 25A ESCs looks like a pretty good guess .
Steve
Old Jun 20, 2012, 03:40 PM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
Two of these ESCs will do the job
http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
Connect both ESCs to your receiver with a "y"cable
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
Old Jun 20, 2012, 09:23 PM
Joined May 2012
Well, I'm kinda newly back into RC, as well as electric flight. Back in the early 80's, the best electric motor I could get was a rather large one that was most decidedly not brushless, and the only batteries available for any kind of power were NiCads. But at the time, I was designing my own scale flying wings, among others, then Life got in the way, and I dropped out a bit. Back then, there were no such things as electric ducted fans, as well, although with a bit of ingenuity, one could put together a peanut scale rubber powered ducted fan(such as an A7 Corsair II that flew indoors), and turbines for RC models were reserved for the financially very well off. If one could find an old Dynajet, and didn't get arrested flying it in the nearest school field, then that was the extent of fast flying jets.
But, having gotten married recently(coming up on two years, and we are both still acting like newlyweds), my wife asked me if I wouldn't want to take up a hobby of some sort, which I have, RC and scale plastic models.
Right now, while I'm putting together the plans for a scale Gannet(probably stand way off scale), I'll also be getting back into the air with a basic trainer, something that I'd be able to "kiss" the ground repeatedly as I learn to earn my wings back. Because, after all, the only way to graduate to the next step is to finally crash your model so many times that it can't possibly be put back together, and from what I've seen so far, the basic trainers available at the local hobby shops look pretty tough, relatively speaking.
Of course, having been able to purchase some acreage of my own helps, as well.
But, even when I wasn't building models, I was always doing aviation research, because I knew in the back of my mind that eventually I'd find more subjects for future modelling projects.
Old Jun 21, 2012, 07:52 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Read these:
https://sites.google.com/site/tjingu...arging-how-tos
http://scriptasylum.com/rc_speed/lipo.html
http://www.rcgroups.com/forums/attac...mentid=1690134
This diagram shows only one motor and ESC but your contra-rotating motor requires two ESC. The second one would just be in parallel with the one shown.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jun 21, 2012, 09:09 PM
Joined May 2012
Yes, I have two sets of wires.
Old Jun 22, 2012, 12:23 AM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
Does this help?
Maxwell;
Yes, it helps. More information is better than less.
Three wires from the ESC connect to three wires from the motor.
To reverse motor rotation, swap any two of the three wires (when power is removed).
Old Jun 22, 2012, 12:30 AM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
Picture of two motors and two ESCs
Old Jun 22, 2012, 03:51 AM
Joined May 2012
Originally Posted by rick.benjamin View Post
Maxwell;
I did not know that. The last electric motor I had, was back in the early 80's, and had only two wires, was 4 times bigger across than this one, and swung a 10 inch prop, and had no kind of speed control.
Help! Need help finding out what on this Rustler rcnewbiee Car Talk 4 Apr 21, 2012 05:55 PM
Discussion About to buy a motor and need help deciding what one I need!!!!! bluemeane 3D Foamies 8 Mar 08, 2012 09:40 AM
Discussion About to buy a motor and need help deciding what one I need!!!!! bluemeane Parkflyers 0 Mar 02, 2012 12:15 PM
Discussion I've got this plane, and this motor, what motor mount do I need? polar8 Glow to Electric Conversions 9 Feb 20, 2012 06:13 PM
Question Where do you find out what F3X flying is all about? Mr. Wiz Multi Task F3X 3 Dec 12, 2011 07:57 PM
