Edmonton, Alberta, Canada
I had very good results with my first trial use of this film:
http://www.rcgroups.com/forums/showp...4&postcount=63 So far so good (a few months later) but I don't have any information on longer-term durability. Also no idea of things like fuel resistance (irrelevant to an all-electric guy like me). There are lots of (mostly positive) comments here on RCG. Try it. I think you'll like it.
Covered both of these with it:
http://www.rcgroups.com/forums/showthread.php?t=1581339 http://www.rcgroups.com/forums/showthread.php?t=1606772 Just like above, I do electric so not sure about the fuel or the durability. The workability applying it is nice, though. Every bit as easy as UltraCote. And the rolls seem huge after using UltraCote. They don't have an inner cardboard tube, and mine keep going and going... |
Re HK coverings just watch when covering thin sections like tailplanes ,if the 2nd covering touches the first it will stick and wont come apart without damage , my cure was to dust with talc the inside of the first covering.
Latest blog entry: For motor builders
I covered this plane with it and it worked great. the white is some monokote I had lying around. The only thing I could say to look out for is taht certain colors have a white adhesive on them so when your overlapping your pieces a little bit when it shinks some there will be a little residue but you can clean it up pretty easy. just more work thats all.
I don't know how well the adhesive will stand raw fuel, a) its not my plane so I can't go dumping fuel on it, and b) it may take some time to fail. generally capilllary action will draw fuel between the layers of covering, and cause it to degrade.
In a year's time we'll know whether the film can withstand fuel. |
Philippines, NCR, Quezon City
Joined Apr 2012
| Thread Tools | |
| Question covering a foam plane with a film | zeezee | Foamies (Scratchbuilt) | 3 | Nov 14, 2011 05:31 AM |
| Discussion Oly III Fuselage covering film or fiberglass what do you think? | hog2soar | Sailplane Talk | 16 | Nov 02, 2011 06:04 PM |
| Question HobbyPartz Film Covering | foamflyer | HobbyPartz.com | 6 | Oct 27, 2011 07:55 PM |
| Question Fuel proofing for solar film covering | mystifried | Beginner Training Area (Fuel) | 4 | Sep 18, 2011 01:29 AM |
| Discussion How would you cover film over film? | flyboy320 | Painting and Finishing Tips | 13 | Jan 31, 2010 07:55 AM |
