Old Jun 19, 2012, 10:13 AM
hog2soar is online now
Find More Posts by hog2soar
hog2soar's Avatar
Central California
Joined Jan 2010
Curious........Has anyone built or tried to build a Bi-plane Sailplane
I was wondering if anyone has built or tried to build a Bi-Plane Sailplane? Something in say a 2M size. Hi-Start,Winchable or electric. Maybe even a Bi-plane DLG
I just thought it might be a fun project if it's at all possible.
Any thoughts,ideas,pictures,etc.or am I just one step closer to the nut house in my old age.
Eddie
hog2soar is online now Find More Posts by hog2soar
Old Jun 19, 2012, 10:36 AM
Highride is offline
Find More Posts by Highride
Michigan's Upper Peninsula
Joined Sep 2007
Eddie,
About four years ago a new guy showed up at our field with an electric biplane glider. He had some pretty old technology in terms of motor and battery, but he did manage to get it in the air. It really struggled. A very short flight then he had to recharge. Very sluggish on controls as well.
The plane was very heavy and the wings seemed to be over-built for a glider and the wingspan in relation to the size of the fuselage seemed short. I was impressed with the guy's perseverance since it looked like this was quite a project. If memory serves me, it kind of looked like a motorized Gentle Lady or that general layout but with two wings, one "stacked" on struts above the "regular wing". They seemed a little too close compared to a regular bipe.
My thought is that a longer, well-designed single wing would perform much better than a biplane arrangement for sailplanes. Just an opinion. Maybe an aero-engineer will pop in with some ideas.
By the way, I never saw that guy again. Think he could have made some contributions to the club considering his imagination and willingness to experiment.
Dave
Highride is offline Find More Posts by Highride
Old Jun 19, 2012, 10:39 AM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
A friend has a Stagger Wing Beech craft sloper. Fly's pretty good too. It's all ePP foam as well.
prodjx is offline Find More Posts by prodjx
Old Jun 19, 2012, 11:58 AM
granada don is offline
Find More Posts by granada don
life long racing nut & modeler
granada don's Avatar
Granada Hills Ca.
Joined Nov 2009
Hi Eddie
Was thinking about your 2 wing idea, you just might add quite a bit of weight in the wing to wing and to the fuse hook up stuff.
Plus a 2 m would be a 13 footer and that is good size, so maybe smaller would be better to keep it lighter and use 2 sticks for the rear fuse half and hook to the stab at each end.
And a small pod between the wings for the RC gear, you could use up a few sheets of paper getting this one together.
Have fun !!
G Don
granada don is offline Find More Posts by granada don
Old Jun 19, 2012, 12:19 PM
HerkS is online now
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
1987
HerkS is online now Find More Posts by HerkS
Old Jun 19, 2012, 12:30 PM
Jim Deck is offline
Find More Posts by Jim Deck
Jim Deck's Avatar
Valparaiso, IN
Joined Apr 2005
There was a full scale soaring bipe
Here's some info on a full scale soaring (more gliding than soaring I suspect) biplane, an early homebuilt, the Heath Super Soarer. A model of this would certainly raise eyebrows at your flying field.
Jim Deck is offline Find More Posts by Jim Deck
Old Jun 19, 2012, 12:39 PM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Well, of course it is possible. But I don't see any advantage of having a second wing and it will more than double the drag. As a thermal glider it's performance would be very disappointing. But on a slope with unlimited energy available you can afford to have an aerodynamically inefficient plane and not have any problems staying up. But still there wouldn't be any other advantage than novelty value.
jkettu is offline Find More Posts by jkettu
Old Jun 19, 2012, 02:41 PM
hog2soar's Avatar
Central California
Joined Jan 2010
I just thought it might be a fun project. Something different.
I wouldn't expect it to be a competition type plane. But would love to see the looks on all the guys faces as you took it to the winch.
Old Jun 19, 2012, 03:24 PM
Thermaler is offline
Find More Posts by Thermaler
Balsa breaks better
Thermaler's Avatar
Buchanan Mi
Joined Apr 2005
Years ago in one of the magazines (remember those things?? ) there was a picture of one that was slapped together from the remains of several gliders that died at a contest.
If it actually flew or not I don't remember.
Anybody else have something to ad???
Joe
Thermaler is offline Find More Posts by Thermaler
Old Jun 19, 2012, 09:12 PM
fnev is offline
Find More Posts by fnev
Joined Jan 2009
I hope the link works:
http://modeliste01.skyrock.com/28082...-colab-n1.html
fnev is offline Find More Posts by fnev
Old Jun 19, 2012, 10:36 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Biplanes have lower induced drag than monoplanes of the same span. Especially if the wings are fairly far apart (in the vertical direction). Of course, the wings get in each others way a bit. Perhaps the best thing for that would be to stagger them a lot, although if you don't stagger them much, you can join the tips for even less induced drag. If you swept the aft ones forward and the forward ones aft....Hmm...sounds like we just reinvented the joined wing. If the wings were not joined, it would probably help to use anhedral on the lower ones and dihedral on the upper ones. At least until it's time to land!
I think you could get a glider which had a lower sink rate than a conventional one, but it would likely have some extra drag when trying to go fast. And if you measured things in terms of L/D per building hour, it would be hopeless.
lincoln is offline Find More Posts by lincoln
Old Jun 21, 2012, 03:45 PM
Libelle201B is offline
Find More Posts by Libelle201B
Libelle201B's Avatar
S. FL
Joined Jan 2007
I remember back about 1978 I saw someone flying a biplane hobby hawk at Torrey Pines CA. It seemed to fly ok.
Libelle201B is offline Find More Posts by Libelle201B
Old Jun 21, 2012, 10:00 PM
fnev is offline
Joined Jan 2009
I am surprised no one reacted to the video I linked to...
Unfortunately it is a french site and you have an add that covers the video window for a few seconds before you may access it. You as well can click on the top right corner of the add to make it disappear quicker...
This project went all the way to full scale application but never passed the prototype/experimental stage as far as I know while showing some very interesting results and performances
Old Jun 22, 2012, 01:22 AM
hasselblad7 is offline
Find More Posts by hasselblad7
USA, CA, Roseville
Joined Aug 2006
The wing spacing should be at least equal to the cord length of wing to keep both wings effective.
I miss my 2x4 that had great maneuverability with its short wing. Maybe with a biplane design you can create a super floater with all that wing area but that would be slightly more aerobatic than a typical 2m.
hasselblad7 is offline Find More Posts by hasselblad7
Old Jun 22, 2012, 08:12 AM
HerkS is online now
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Maybe this is the reason you didn't get a response:
Discussion Has anyone tried or had any luck with a Zagi glider in New England wk662 Flying Wings 0 May 08, 2012 05:24 PM
Discussion Has anyone tried this GoPro looking Swann camera for $180 from Costco jasper7821 Aerial Photography 4 Apr 04, 2012 06:07 PM
Discussion Has anyone EVER tried to fly two planes simultaneously? Watch the video!!! JanRy Combat 13 Mar 27, 2012 08:25 PM
Discussion Anyone has build this plane before? RyanMa Foamies (Scratchbuilt) 0 Sep 27, 2011 01:20 AM
Those looking for a bi-plane or tri-plane KenP Parkflyers 2 Oct 13, 2004 03:37 PM
