Old Jul 16, 2012, 11:29 PM
therealthing691's Avatar
australia
Joined Apr 2007
i use blue i hope its not red as its stronger i think
therealthing691 is offline Find More Posts by therealthing691
Old Jul 17, 2012, 10:27 AM
United States, WA, Shelton
Joined Nov 2010
Yes red is metal to metal such as bearing races in metal housings. I just want to add that there is a purple loctite that works well to gum up threads from shaking loose, but is easier to loosen then blue
blueskysailor is offline Find More Posts by blueskysailor
Old Jul 21, 2012, 12:26 AM
Joined Nov 2010
Thanks Keithm for the tip on the gears. I got two from SDP/SI for my Park Hawk and cut the hubs down to a 3mm height with a drill press and a Dremil cut-off wheel. The drill press made a great horizontal saw. Using the old gear as a template and a "c" clamp in a vise to hold the two gears in phase I drilled the holes in the new gear. It put it back together and test flew it today . Thanks also to Brian for the tips. The Loctite was blue and the screw loosened easily with a Weller dual temp soldering gun . Stay away from sidewalks.
Old Aug 29, 2012, 08:46 AM
United States, FL, Ocala
Joined Jan 2007
Replacement of Conn rod bearings
I realize I'm a little late in posting this info. As mentioned on the previous page, I needed to replace the conn rod bearings on my LH. I found parts that exactly matched the original SK rod end and bearing at my LHS. They are also easy to find on eBay. The rod end and bearing are from racing trucks and are made by OFNA Racing. The rod end is P/N 36690 and the bearing, P/N 36850.
I took LIG's advice and ordered a .093" X 16.75" X 16.75" Black Glass Ply fiberglass sheet from ACP Composite.
http://www.acpsales.com/search.php?mode=search&page=1
Using a dremel tool, it is easy to cut out the fitting that inserts in the rod end. Cut it a bit oversize and thread it into the rod end using a good grade epoxy. Drill and tap the holes to attach to the flex plate and your done.
I received a PM from n553302 who made his repair by using the same parts. He used a cutoff wheel to remove the old rod end and used the original attachment plate in the new rod end. I would suggest that it might be quicker to use his method and avoid making the new plate fitting. If this doesen't work, you can then cut out a new plate as I've described.
Perhaps n553302 will add a post to this detailing his method.
keithm is offline Find More Posts by keithm
Old Aug 29, 2012, 11:16 PM
australia
Joined Apr 2007
glad to see people making there own stuff i find it fun
Old Sep 29, 2012, 04:37 PM
DesmoHead's Avatar
USA, CT
Joined Aug 2007
WingSails
I'm interested in attemting to fabricate my own WingSails for my bird. Has anyone out there tried that? Is there any info out there as to what the materials are on the SK Orni's? Maybe sources?
Thanks!
-eric
DesmoHead is offline Find More Posts by DesmoHead
Old Sep 29, 2012, 08:10 PM
australia
Joined Apr 2007
any questions just ask i have made sum for my park hawk andmade a large one for my own bird cheers Brian
Old Sep 30, 2012, 07:46 PM
DesmoHead's Avatar
USA, CT
Joined Aug 2007
Awesome
Brian,
Thanks! Think I might I might put this in a separate thread, but for now.
What is the material exactly? Feels like Dacron but what weight?
Is the type that has the "cross hatches" something special?
What is the black tape? Is it just binding tape or something special?
What adhesive is used to bind the Dacron together where you place the carbon battens?
Can you recommend any sources for these materials?
-eric
Old Oct 01, 2012, 09:18 PM
australia
Joined Apr 2007
any kite makers or sail makers the black is 3oz dacron the ripstop i got was .6 oz from a local racing sail maker any thing up to 1 oz would be ok i would say as for adhesive it is double sided tape which you can get this from hang em high or kite builder on the net google it
hope this helps cheers Brian
Old Oct 01, 2012, 10:17 PM
DesmoHead's Avatar
USA, CT
Joined Aug 2007
Thanks!
Brian,
Awesome thanks!!
-eric
Old Oct 01, 2012, 10:34 PM
australia
Joined Apr 2007
anytime
Old Oct 08, 2012, 09:48 AM
Joined Nov 2007
I desperately need a body/fuselage for my Park Hawk - been out of action for 6 months after a crash -
Where to get , please ?
teamlotus is offline Find More Posts by teamlotus
Old Oct 11, 2012, 10:05 PM
Walkera fan-boi
MiniChopper4Me's Avatar
USA, FL, Sunny Isles Beach
Joined Jun 2009
O-Rings for Big Lazy Hawk
I recently purchased a used Big Lazy Hawk from Heavy Chevy. I'm in need of replacement o-rings, the ones used to attach the tail to the tail servo, but it appears its the same part used in various places on the bird. Can anyone tell me what the dimensions/hardness/etc. of the part are so that I can order a bunch from McMaster-Carr instead of trying to place a small parts order from SK?
Thanks in advance,
MiniChopper4Me
MiniChopper4Me is offline Find More Posts by MiniChopper4Me
Old Oct 11, 2012, 10:27 PM
Walkera fan-boi
Joined Jun 2009
Nevermind, I think I found them:
12mm OD x 5mm ID x 3.5mm CS, bought 50 on eBay for less than $5. Now I just gotta wait for them to get here from HK :P
MiniChopper4Me
Old Oct 13, 2012, 05:26 AM
australia
Joined Apr 2007
post a picture where is it broken
Alert SK Ornithopters - Great Product (maybe), Lousy Business (definitely) bwayneholt Ornithopters 24 Oct 08, 2012 08:01 PM
Discussion Slow Hawk RC Bird- SK Ornithopter RobscoRC Ornithopters 2 Jun 04, 2012 10:00 PM
Rave SK Ornithopters delivered as promised drmwmc Ornithopters 0 May 17, 2012 04:37 PM
Discussion Dual motor setup in SK ornithopter? Socalfusions Ornithopters 5 May 14, 2012 10:27 AM
Wanted Wtb-1/16th revo after market parts skyjacker07 Cars - Trucks and Parts (FS/W) 2 Sep 13, 2011 07:42 AM
