Old Jun 19, 2012, 09:40 AM
Retreating Blade Stall
Arcturus97's Avatar
United States, VA, Woodbridge
Joined Apr 2011
Damaged 6S Lipo; One cell bad; Need help with discharge and disposal
I've got a 6S-3000 that was in a crash. There is small but visible physical damage to cell #3 (pic attached, wrapper peeled away by me for view). Post crash all cells had pretty much equal voltages at around 3.8
I charged the battery, charger really struggled getting it balanced (took a long time), to get cell #3 up to 4.2 volts. I was suspicious so after a break I put it on a 1C discharge, set to go down to 3.6v per cell to see much capacity came out. About 45 minutes later the charger started alarming, I was in the room the whole time ran over and saw that it terminated due to low voltage on (you guessed it) cell #3. #3 was at 3.1v while all the others at 3.7v
I've had this battery in a lipo bag by itself on a concrete floor for the last week or so wondering what to do with it. In that time cell #3 has now dropped to 2.9v, others still at 3.7v. Using the charger to discharge is not an option - I suppose I could fool the charger (icharger 306b) by not plugging in the balance port but that doesn't seem like a good idea - I'm not looking for a fire on my workbench.
The whole point - how can I discharge this battery safely so it can be disposed of?
I've read different things about the salt water bath: some say do it, others say do it after discharged, and others say it will not discharge a lipo.
Arcturus97 is offline Find More Posts by Arcturus97
Old Jun 19, 2012, 10:14 AM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Salt is a no-go.
For a 6s you will have to make a series light bulb discharger. Put 2 automotive light bulbs in series. An 1157 or 2057 will work. Simply go from your battery plug to a mating plug + to bottom contact/contacts of bulb 1. Solder a short wire from brass side to bulb 2 contact/contacts. Another wire from bulb 2 brass side to the - of plug.
These will get hot and may take all night to fully discharge this pack. Do this in a safe area as you will not be there to monitor it that long.
Just because the light bulbs are not lit the pack may not be fully discharged. Once ALL heat is gone + 1 hour it should be discharged to a safe disposal state.
Rick
rampman is offline Find More Posts by rampman
Latest blog entry: mean well S-210-12 power supply
Old Jun 19, 2012, 11:46 AM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
^^ What Rick said.
If your charger has a discharge function you can put it into Nicad mode, set for .1 volts at max discharge and do that a couple of times to affect a complete discharge.
Either way, once the pack is discharged, strip and twist the leads together to prevent voltage rebound in the pack.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jun 19, 2012, 12:15 PM
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
FWIW when I discharge packs, I put them on the grill outside and close the lid. I have never had any issues but if one does flame it won't hurt anything.
feathermerchant is offline Find More Posts by feathermerchant
Old Jun 19, 2012, 12:32 PM
pgk
Joined Mar 2011
Except if you were planning on grilling burgers that day! (: lol... Sorry, couldn't resist...
Pete
pgk is offline Find More Posts by pgk
Old Jun 19, 2012, 04:52 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Well If I see it flame up, I just go get the patties and start cookin. (JK)
Help! 6S with a bad cell CJRAY Glow to Electric Conversions 9 May 10, 2012 07:41 AM
For Sale 6S 3000mah Turnigy with one bad cell MrRetro Aircraft - Electric - Batteries & Chargers (FS/W) 7 May 02, 2012 04:55 AM
Sold Turnigy 3600mAh 6S 30C with bad cell snoshoe62 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 09, 2012 02:34 AM
Sold 6s Turnigy 5000 35C lipo with a bad cell. litespeed Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 21, 2011 09:47 AM
For Sale Brand new Kong Power 2600mah 6s lipo with one bad cell rccrazee Aircraft - Electric - Batteries & Chargers (FS/W) 20 Mar 23, 2009 12:55 AM
