Old Jun 19, 2012, 05:43 AM
makind's Avatar
Česká republika, Hlavní město Praha, Praha
Joined Apr 2011
Scratchbuilt Focke Wulf 190 - proof of concept
I decided to try new concept of building planes. Till now i was using dollar tree foam. Now i switched to EPS+XPS foams.
This is my very first plane i build using this foam. It was supposed to serve as learning guide for future planes, tryout for different colors and also as weight/wing span comparison.
I have several 1200kv motors at home with 800g trust. So i wanted to know whats the biggest wing span i can use and be under 800g.
Final plane has some issues, but i was expecting that from the beginning. If you make some step prior some other, sometimes is very hard to fix your mistakes. So the main wing is not perpendicular to fuselage, the fuselage is not 100% symmetrical an angle of incidence is not set correctly. I made some test flight, plane is very tail heavy. I have to add 100g in the nose to balance it.
But after all i was very surprised how well the plane flies compare to how many mistakes i made during the build
Now im preparing version 2 of the same plane with wing span of 1050mm.
The spec for the plane are
wing span: 1000mm
weight with 2200mah 3s battery + 100g weight in nose: 830g
motor: 1200kv
prop: 9x4,7 SF
makind is offline Find More Posts by makind
Old Jun 19, 2012, 05:44 AM
makind's Avatar
Joined Apr 2011
i had big problems with orientation, since the plane is gray.
I ended up with fluorescent orange paint on the bottom main wing and nose
Old Jun 19, 2012, 10:55 AM
Lost but making good time
Joined Nov 2008
makind,
Nice work...Kurt Tank would have a grin on his face!
Regards,
Hankg
hankg is offline Find More Posts by hankg
Build Log Kit No - 406 Focke-Wulf 190 davidwl Scale Electric Planes 38 Dec 28, 2012 02:06 PM
Sold Hobbico Focke-Wulf Fw 190 Ahmed_A Aircraft - Electric - Airplanes (FS/W) 0 Mar 16, 2012 07:49 AM
Sold LAX LPU:Hobbico Focke-Wulf Fw 190 Select Scale EP Mikemynameis Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2012 07:54 PM
Sold Parkzone Focke Wulf 190 RTF J31968 Aircraft - Electric - Airplanes (FS/W) 12 Feb 27, 2012 11:25 AM
Sold Parkzone Focke Wulf 190 RTF ...PRICE LOWERED J31968 Aircraft - Electric - Airplanes (FS/W) 0 Feb 25, 2012 01:13 PM
