Old Jun 19, 2012, 05:33 AM
easystarfpv4 is offline
Find More Posts by easystarfpv4
Joined Mar 2012
Question
What diameter of carbon fiber rod should I use for my Multiplex Easystar?
I want to strengthen the wings on my Easystar because of a more powerful motor I have installed. What diameter of carbon fiber rod should I use in the wings so as to keep them stronger?
Thank you for any information on this.
easystarfpv4 is offline Find More Posts by easystarfpv4
Reply With Quote  (Disabled)
Old Jun 19, 2012, 06:03 AM
EraJomppa is offline
Find More Posts by EraJomppa
Foamy Scratchbuilder
EraJomppa's Avatar
Finland, Pirkanmaa, TRE
Joined May 2011
hmm, isnt there a carbon spar on a easystar to begin with? I thought there is. at least the ones Iv flown had reinforced wing.
but if you need a spar, Id say above 5mm diameter should do it. the bigger the better though.
EraJomppa is offline Find More Posts by EraJomppa
Old Jun 19, 2012, 06:41 AM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
The biggest diameter rod that will fit inside the existing spar. In the bixler its a 4mm rod but the EZ* might be different.
nogas is offline Find More Posts by nogas
Old Jun 19, 2012, 09:18 AM
vvV FANG Vvv is offline
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Eurongilly
Joined Aug 2008
8mm tube alot bigger than the bixler one, you can use one longer than the stock one too just sharpen a end and push it through.
This is the best easystar build ive seen and i usually follow it!
http://rcexplorer.se/projects/fpveasystar/fpv.html
vvV FANG Vvv is offline Find More Posts by vvV FANG Vvv
Old Jun 20, 2012, 08:20 AM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
just put a 1in strip of fiberglass tape on top/bottom of wing the length of wing.
ror1 is offline Find More Posts by ror1
Question Where and how to install Carbon Fiber Rods in Easystar easystarfpv4 Electric Plane Talk 2 May 09, 2012 11:00 AM
Question Can I upgrade my Battery for my Multiplex Easystar? easystarfpv4 Electric Plane Talk 7 Apr 19, 2012 07:46 PM
Help! Friends in the EU! 7.5mm diameter square rod/stock? Aluminum/Carbon? daign Multirotor Talk 4 Dec 29, 2011 07:56 PM
Help! Can prefab carbon fiber rods be bent using heat flying_rhyno Composites Fabrication 8 Sep 27, 2011 01:11 PM
Discussion Carbon fiber rod-what size? for 3D model? pathfinder67 3D Foamies 1 May 06, 2010 08:59 PM
