Old Jun 18, 2012, 11:03 PM
SteveM is offline
Find More Posts by SteveM
Joined Dec 2002
A123 Rx pack..... add diodes?????
Folks,
Wish to use 2s A123 pack for receiver, but 3150's are really not suitable for > 5.4V.
Can I just add 2 x diodes in series to drop the 1.4V (suppose fresh off charge A123's will be 7.2V for short while, dropping to 6.6-6.8V for most of time)
If so, which diodes would be suitable, considering may need max 3-4 Amps??
Please advise.
Many Thanks, Steve
SteveM is offline Find More Posts by SteveM
Old Jun 18, 2012, 11:34 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Yes you can. IMO, buy some 3A diodes and double up in parallel (6A) so you have a huge window as we don't know the spikes your system sees.
I have no idea where you live, USA or otherwise, as your location is void under your user name but Radio Shack may have what you are looking for. An EE Will disagree with me but in this aplication a diode is a diode is a... Look for the black color, white stripe...
Rick
rampman is offline Find More Posts by rampman
Old Jun 19, 2012, 11:53 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
+1,
I would also like to mention that you can also use a decent switching BEC, such as the 10A BEC from Castle Creations, but the diodes are simpler, cheaper, and very reliable. Unfortunate that those servos are only rated for 4 cell operation
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Jun 19, 2012, 12:49 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Agree that diodes will work to drop voltage but using two in parallel will not increase load handling as this requires both diodes to have the exact same forward voltage drop, which is almost never the case. As such, one diode will be carrying most of the current load.
Use a 6A (or greater) diode to provide some margin. Also consider adding a heatsink if your servo current load is anywhere near constant as the voltage drop will be dumping more heat.
IMO, an inexpensive switching BEC may likely prove to be less of a hassle and may be more efficient and dump less heat. Also, a BEC will allow you to use a lipoly pack, which have much greater energy density than a 2S A123 pack...
Mark
mrforsyth is online now Find More Posts by mrforsyth
Last edited by mrforsyth; Jun 19, 2012 at 01:00 PM. Reason: added heatsink recommendation
Old Jun 19, 2012, 03:02 PM
Marion is offline
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
One good reason to parallel diodes is for better reliability. Yes, I have had diodes fail mechanically due to poor packaging. .
Marion is offline Find More Posts by Marion
Old Jun 19, 2012, 04:19 PM
SteveM is offline
Joined Dec 2002
Thanks for all your replies/interest.
Switching or linear BECs do not seem to be an option for a 2s A123 source.
I tried a couple of Turnigy ( Hobbywing) 3A becs, supposedly rated down to 5.5v i/p, and even at 6.2v the o/p dropped to 4v for 2.5A load.
I have built many linear regs in the past, as follows:-
http://www.dream-models.com/eco/electrics-bec1.html
They are fine for i/p voltages 8v up, but I have just tested one at
6v input.................it gives a 3v output, so you really do need a >2V overhead for these linear 78XX regs. to work correctly. (don't really want to add another cell)
I wonder if anyone has had any success with certain makes of BEC
Rgds, Steve
Old Jun 19, 2012, 07:14 PM
So. Cal.
From where was the loaded voltage measured? e.g. - Are you certain that the drop was not due to wire and connector losses and did you verify that the output voltage was higher with same load but with higher input voltage?
Not refuting your claim, merely trying to better understand.
I have had nothing but perfect success with the two following BECs from 'the King':
http://www.hobbyking.com/hobbyking/s...Reduction.html
http://www.hobbyking.com/hobbyking/s...23v_Input.html
Admittedly, I use 3S lipoly or 4S A123 input. Also, at 3A rated output, both are inadequate for your needs.
Have you tried this one:
http://www.hobbyking.com/hobbyking/s...or_Lipoly.html
Also, are you opposed to using 2S or 3S lipoly rather than your A123s? I understand this will require an additional purchase but it will absolutely solve your issue and lipolys are silly cheap these days.
Mark
Old Jun 19, 2012, 08:21 PM
SteveM is offline
Joined Dec 2002
Mark
Thanks Mark,
I'll repeat the test tomorrow, checking voltage very close to BEC pcb.
Lipos....yes, obvious option.....just wanted to bury A123's in the nose, topping up in situ at 3-4A.
will post result...rgds
Old Jun 19, 2012, 10:45 PM
So. Cal.
Gotcha Steve. Makes perfect sense now.
The more I think about your specific application, the more I personally would discourage the use of diodes to drop voltage.
Reasons for my though process as follows...
  • As you stated in post #1, two diodes will be required to drop voltage into a usable range for your application. Junction drop will be ~1.4 volts. Two A123's in series will have loaded voltage of ~6.2 volts toward the end of discharge. Ignoring wiring and connector resistive losses, this puts you in the 4.8 volt range. Additional drops due to current spikes from heavy servo transients as well as wiring resistive losses may put you in the 'brownout' zone for many 2.4Ghz radio systems.
  • 1.4 volt drop across the series diodes will dissipate nearly 6 watts at 4A current draw. This will absolutely require some airflow across the diodes or other form of heatsinking to ensure reliability.
IMO, using an additional A123 cell (3S pack) or a 2S lipoly in conjunction with a BEC would be a far more reliable alternative. I understand the caution about charging a lipoly within your model but this concern is largely mitigated by simply performing a balance charge with a decent quality charger. (I have performed nearly 5K balanced lipoly charges over the past 6 years without a single incident and would have little hesitation about charging inside any of my planes.)
Really curious to see your BEC voltage drop testing to know whether HobbyKing's input voltage specifications are optimistic.
Cheers,
Mark
Old Jun 20, 2012, 12:32 AM
SteveM is offline
Joined Dec 2002
It may surprise you to know that the above is for a Hotliner, on 5s 4Ah pack.
I also bought the 5-7.5A Turnigy (Hobbywing) BEC, to use with the full 5s lipo, but planned current draw is 120A, and I recently read all of the following:--
http://www.rcgroups.com/forums/showthread.php?t=1668258
It made me very concerned over using main flight pack on a $1500 aircraft, at that current,.
Thanks for all your suggestions.....think may add extra cell.
Will re-test the BEC also.
Rgds, Steve
Old Jun 20, 2012, 02:46 AM
SteveM is offline
Joined Dec 2002
3A BEC Pics!!
OK.... these pics show 6v SLA input to the 3A Turnigy BEC.
Left meter shows output, stabbing leads close to BEC....it can't even hold 4.2v!
Last pic confirms we are just subjecting to a 2.4A load.
Input leads are clamped between the right hand meter probes, and the SLA terminals with croc clips.
BEC becomes hot very quickly.
Rgds, Steve
Old Jun 20, 2012, 03:17 AM
SteveM is offline
Joined Dec 2002
Note....just tried an old tx pack input, measuring 7.4V under load..... output holds at steady 5.2v no pbm, although bec becoming hot.
More.... just tried the Tgy 5-7.5A one.
6v in, 4.7v out @ 2.6A, 4.4V out at 3.3A load.
Only becomes warm
Old Jun 20, 2012, 05:39 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Rectifiers are better than diodes. They are more durable, have a better package, and you can get them from defective (PC) power supplies.
Julez is offline Find More Posts by Julez
Old Jun 20, 2012, 03:20 PM
So. Cal.
Interesting data Steve.
Since your application is a hotliner, I personally would oversize the BEC as servo loads on hotliners that are moving at high speed can be very high due to dynamic loads on control surfaces. Servo current draw can be surprisingly high even when flying flat and level.
Cheers,
Mark
Old Jun 20, 2012, 03:34 PM
ltc is online now
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Rgds, Steve
As an EE (40 yrs experience ... still learning and having fun with electronics every day), there is nothing challenging or difficult to design a BEC (linear or switching) that would work for your input/output requirements.
If an off the shelf BEC is unacceptable (and there are many readily available units) and if you want to do more DIY work, I would suggest getting a regulator evaluation board from TI or Linear Technology. These are readily available and allow you to regulate with minimal dissipation / minimum input - output differential.
The 78xx, while venerable and useful, would not be my first choice for this application.
ltc is online now Find More Posts by ltc
Help! A123 battery pack for Rx: voltage regulator required? Paul_BB Radios 5 Mar 26, 2012 10:17 AM
Discussion LiFe/ a123 rx pack voltage and servos hidaven Electric Plane Talk 3 Mar 14, 2012 03:44 PM
For Sale Taildragger RC 2sp a123 rx packs taildragger21 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 21, 2011 09:42 AM
Question Silicon "dropping diode" choice for 2S1P LiFePO4 Rx airborne packs?? The PIPE Radios 22 Oct 06, 2011 12:11 PM
Found A123 Rx Packs JPHen Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 14, 2011 06:56 PM
