Old Jun 18, 2012, 08:35 PM
Slinger1 is offline
Find More Posts by Slinger1
Joined Jan 2007
Motors with more power than Omega 103g and 130g??
Hi guys,
I love my Omega 103g and 130g motors, but some of my planes are on the heavy side and a bit more grunt would come handy.
All my setups are 3s and ideally I would like to keep it that way.
Which motors would be a noticeable upgrade?
Cheers!
Slinger1 is offline Find More Posts by Slinger1
Old Jun 19, 2012, 07:06 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Too many possibilities and also lack of requirements to really make a suggestion.
Are you already pushing the Omega motors to their max ?, have you tried different props ?, do you want more low end thrust or high end speed ?.
Alternatively, add more lightness to your planes
eflightray is offline Find More Posts by eflightray
Old Jun 19, 2012, 03:33 PM
GPT is offline
GPT
Find More Posts by GPT
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
I moved from Omegas to Motrolfly and are very happy.
GPT is offline Find More Posts by GPT
Old Jun 19, 2012, 05:32 PM
Slinger1 is offline
Joined Jan 2007
To be honest, I am not sure if the motors are 100% maxed out, but I am certainly following 3DHS's recommendations. For example: On my 47" Extra 300 SHP I am using the Omega 103g with APC 13x6.5E. The problem is that my Savox metal gear servos are considerably heaver than the HS-65 MG. What I am missing the most is awesome vertical performance.
Old Jun 19, 2012, 11:08 PM
yellowcolorado is offline
Find More Posts by yellowcolorado
United States, LA, Metairie
Joined Feb 2009
Get a watt meter to see if your pushing your system. How old are your batteries? If they have some flights under theyre belt try picking up some new ones with higher C ratings. Of course make sure your prop is on correctly and the throttle range is set correctly.
yellowcolorado is offline Find More Posts by yellowcolorado
Old Jun 20, 2012, 03:05 AM
GPT is offline
GPT
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
13x6.5 is maxed out for the 103g motor. The 130g will perform better and can run up to 14x7.
Found WANTED: Omega 103g 1030kv Motor -= GYRO =- Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2012 12:16 PM
Found Omega 103g motor omster Aircraft - Electric - Power Systems (FS/W) 0 Oct 15, 2011 01:01 PM
Wanted WTB 103g Omega Motor shadow102 Aircraft - Electric - Power Systems (FS/W) 3 Oct 13, 2011 11:50 PM
Wanted Omega 130g/103g oilfield1 Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2010 01:14 PM
Sold 3DHS 47" Velox NIB with Omega Motor 130g Willmsy Aircraft - Electric - Airplanes (FS/W) 9 Sep 21, 2009 02:50 PM
