Old Jun 18, 2012, 02:39 PM
shepster is offline
Find More Posts by shepster
shepster's Avatar
United States, IN, New Castle
Joined Mar 2010
Question
Smoke system
I have a sullvin skywriter and was wondering about the way you run the lines.understand where they go but should you use a vent line or not.some say no because of priming it.if you do use 3 lines one for vent 1 for filling and 1 to smokepump. but if you run one from pump to tank and can you use a t fitting for vent and filling.by pluging vent off while you fill then uncap after for vent ? which is best way.
shepster is offline Find More Posts by shepster
Old Jun 18, 2012, 06:02 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
If you plug a vent,while filling,there's no place for pressure to escape,as the fuel is introduced.Using three lines is best and most-trouble free.Install two "pickup" tubes -one for filling/draining,one for pump pickup.leave the vent alone to do just that.....vent.
epoxyearl is offline Find More Posts by epoxyearl
Old Jun 18, 2012, 07:47 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
I was using a 2 line system with a du-bro style gas fuel filler in the line to the smoke pump.
That way the plumbing is a peice of cake. one line is the vent, and the other is for the pump, but is also the fill line, but will shut off oil going to the pump while it's being filled.
Don't forget to run neoprene near the exhaust (tygon cant stand the heat) and put a non return valve in there so the muffler doesn't blow all the oil back into the tank and you lose your prime.
Curare is offline Find More Posts by Curare
Sold Ordinance/Smoke System/Canopies/DragChute V12DRIVER Non R/C Items (FS/W) 6 Oct 15, 2012 10:11 PM
Cool Smoke systems for EDF pdawg Electric Ducted Fan Jet Talk 22 Aug 14, 2012 03:08 PM
Discussion Glow smoke systems: 2 & 4 stroke Alex Koehn Beginner Training Area (Fuel) 9 Apr 13, 2012 05:25 PM
Sold Sullivan Skywriter 753 Electronic Smoke system marksextra Aircraft - General - Radio Equipment (FS/W) 6 Mar 07, 2012 01:29 AM
FS TME Smoke system, The best smoke system out there Pilot44 Aircraft - Fuel - Airplanes (FS/W) 8 Jan 06, 2004 08:38 AM
