Old Sep 10, 2012, 02:54 PM
ReneNL is offline
Find More Posts by ReneNL
ReneNL's Avatar
Joined Jun 2012
Hello again billpa,
Well, I tested all diversity settings (1 untill 10) in 12 batteries/flights today.
The result... a little bit better but looks overall to much at my last made video.
Look for yourself;
Nonpublic EagleEyes beta 2 firmware update. My test-results after 12 flights. (3 min 31 sec)
To be short... takes to long to switch to the helical on distance and random switching
in the 100/600 meter range. Sorry
René
ReneNL is offline Find More Posts by ReneNL
Old Sep 11, 2012, 04:13 PM
ReneNL is offline
ReneNL's Avatar
Joined Jun 2012
Billpa, the sunny side... your not alone with this.
Look at a video from the ImmersionRC DUO5800v2 5.8GHz Diversity Receiver.
Same problems with this combi antenna's (SPW & Helical).
5_8RangeExample (1 min 9 sec)
Hope this gives you extra power to sort things out
René
Old Sep 12, 2012, 11:19 AM
V_Okto is offline
Find More Posts by V_Okto
Joined Feb 2011
same here, adjusting the brightness on the 600tvlWDR does not help.
Sens 5 is the best, testet all numbers.
strang switches are still there :/
V_Okto is offline Find More Posts by V_Okto
Old Sep 14, 2012, 01:15 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi ReneNL, that's really interesting info. Are you using the same transmitter that is being bundled with the RC305, with the Duo?
Come to think of it, what I am seeing on the oscilloscope coming out of the RC305 could easily be an issue with the Tx rather than the Rx.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Sep 16, 2012, 02:17 AM
ReneNL is offline
ReneNL's Avatar
Joined Jun 2012
Hello billpa,
I'm not sure what you mean. This is not my movie but one I found on YouTube. I do not own Immersion transmitters or receivers. What I do use is the transmitter that is stock with the 305 receivers. Look at (for example) foxtechfpv.com. They come in 200, 400, and 500 mw shape. I own them all and can try another one if you like me to.
René
Old Sep 17, 2012, 01:31 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Sorry, Rene. I thought this was a test you ran.
I am going to do some additional changes, and will report back when those are ready.
Site Sponsor
Old Sep 27, 2012, 11:04 AM
V_Okto is offline
Joined Feb 2011
any news ?
i steped back only using the SWP (no diversity) its more save for low and near copter fpv.
Old Sep 27, 2012, 11:59 AM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, no news yet. Trying to find the time to do additional experiments with these!
Site Sponsor
Old Oct 01, 2012, 04:47 PM
ReneNL is offline
ReneNL's Avatar
Joined Jun 2012
I bought a Tracker with 10 turn helical and use the Eagle Tree for now as an expensive video-splitter.
My groundstation is still build for diversity so any updates are welcome and will be tested.
My believe that it's not only the use of the 305 reveivers in combi with helicals and other 'new' antenna's but also the brightness
of the more and more populair Pixim cams these days availible for less money than ever.
Aldo some Pixim cams are working very nice with the beta's, ti's not a garantee these wil work for everyone.
Rest to say that I see the same problems with the other diversity builders, the problem seems complex I guess.
Let's hope EagleEyes will be the first with perfect diversity
Good luck Bill, waiting for the next update,
René
Old Oct 11, 2012, 03:47 PM
V_Okto is offline
Joined Feb 2011
i hope so too.
Old Oct 16, 2012, 01:48 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Guys, we will keep at it!
Site Sponsor
Old Oct 19, 2012, 11:24 AM
Xian01 is offline
Find More Posts by Xian01
Joined Jul 2011
last settings not stored
@billpa
I´ve flashed the Eagle Eyes software with the new one, which you have recommended in this thread. The diversity function works fine now! However when the eagle eyes is switched off the last settings are not safed. After restart the device always operates in AV1. For me this is an issue because the EE is mounted in a box and I have to open it all times in order to reenter diversity mode. Can you pls. fix this issue?
BR Xian01
Xian01 is offline Find More Posts by Xian01
Old Oct 23, 2012, 12:25 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Xian01, thanks for this report. Are you using the OSD Pro? If so, you need to set the channel in the OSD Pro menus, as that setting will override the button setting.
Or, if you are not using the OSD Pro, we will investigate the issue further.
Site Sponsor
Old Oct 23, 2012, 01:52 PM
Xian01 is offline
Joined Jul 2011
No I don't use OSD.
I just updated the firmware with 10.53 alpha version. The problem is that "EagleEyes FPV Station" always forgets the last settings. So in my case I use it only as diversity. Power off-> Power On. Eagle Eyes starts at AV1. Diversity LED is not switched on.
So I have installed 10.04 from your website and this issue is solved. Last setting is diversity mode and EE will start in diversity mode.
Old Oct 25, 2012, 01:24 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Ok, thanks. We'll get that reproduced and fixed here asap.
Site Sponsor
Discussion help adding a potentiometer on one channel.. joy4u Radios 6 Apr 05, 2012 08:51 AM
Discussion Gifts for the Loved one. blueangeljetgirl Electric Warbirds 11 Jan 12, 2012 10:54 PM
Discussion 7 Billion people! Goat, you're gonna love this one. Mr. Wiz Life, The Universe, and Politics 15 Oct 27, 2011 04:23 AM
Poll 2 Servos on One or Two Channels ? Hossinarizona Radios 2 Oct 09, 2011 10:28 PM
