Old Jun 25, 2012, 06:19 AM
pathloss is offline
Find More Posts by pathloss
Joined Dec 2011
Bill,
Could you give us a quick tut on what the EEyes uses to decide what receiver to use? Mine seems to have similar issues, and will switch to a far inferior receiver, and will only switch back to the better receiver if it totally looses video sync on the poor(er) of the two. It seems to be simply based on if it has sync or not. Does not seem to select the best picture. I am @ 1280 Mhz and using identical receivers with one exception, that being the remote receiver is on an adjacent tripod about 10 cable feet away.
Are the levels from the receiver critical in the inputs of the EE?
I doubt the type of antenna would have anything to do with the issue described in the thread. The band width and output response of the receiver, however could be important. Again, could you advise what EE uses to determine what receiver?
THANKS!
pathloss is offline Find More Posts by pathloss
Old Jun 26, 2012, 08:57 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Thanks, Rene. The items are on their way here and will report back with testing results.
Pathloss, the diversity algorithm checks for several things (and is proprietary) but should definitely not be switching from a good quality signal at all. What brand of receivers do you have?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jun 28, 2012, 04:23 PM
pathloss is offline
Joined Dec 2011
Using the following:
Racewood 1.3GHz Wireless AV Receiver VRx For FPV & Wireless CCTV Cameras Blue Label 1.2TR-1500B. (Dronesvision.com)
Works well. I understand the confidential nature expressed, but only ask if it should switch away from a 'snowy' picture into a good one, and if the sensitivity, and / or video levels have anything to do with it?
Would a 10' jumper cable on the diversity have anything to do with it? I could coil up a longer jumper on the other if you think it may help equalize the response.
Old Jun 29, 2012, 02:03 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, it should not switch to an inferior channel. It's detecting something in the signal of the superior channel that is causing it to think the channel has an issue. We'll be testing the specific HW for Rene's problem, and will see if that might also explain your issue.
If you test with short cables, does the problem occur?
Site Sponsor
Old Jul 03, 2012, 02:48 PM
ReneNL is offline
Find More Posts by ReneNL
ReneNL's Avatar
Joined Jun 2012
To be sure, I did shorten all cables to max 20cm. Also rewind everything. You guess... No difference.
ReneNL is offline Find More Posts by ReneNL
Old Jul 06, 2012, 01:42 PM
pathloss is offline
Joined Dec 2011
As soon as the oppressive HEAT stops, I will be able to fly it again. I will likely elect to add length to the 'local' receiver, as my 'crash' pod usually stands 6 to 8 feet away from the tracker.
Old Jul 06, 2012, 08:39 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Pls let me know what you find. Heat? It's 68 degrees here in the Seattle area.
Site Sponsor
Old Jul 11, 2012, 07:54 AM
V_Okto is offline
Find More Posts by V_Okto
Joined Feb 2011
hey im using thwo rc305 reciver with HELIX and SWP too!
mostly the same problem but my ET loves the helix and switches to early away from the SWP with perfekt signal
V_Okto is offline Find More Posts by V_Okto
Old Jul 14, 2012, 04:27 AM
V_Okto is offline
Joined Feb 2011
same issue :
Diversity switching issue (2 min 8 sec)
Old Jul 14, 2012, 12:46 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
V_Okto, we have two RC305s and related equipment on order, and once those get here, we'll sort out what's going on.
Site Sponsor
Old Jul 15, 2012, 06:26 AM
V_Okto is offline
Joined Feb 2011
great !
Old Jul 15, 2012, 05:51 PM
ReneNL is offline
ReneNL's Avatar
Joined Jun 2012
Yep, exactly the same problem!
Old Jul 19, 2012, 12:53 PM
HomerJ79 is offline
Find More Posts by HomerJ79
Joined Mar 2009
Same here, same equipment, same problem
HomerJ79 is offline Find More Posts by HomerJ79
Old Jul 19, 2012, 04:38 PM
bubuu is offline
Find More Posts by bubuu
From se saus of tschärmaniee
Joined Oct 2008
Oh noes! You guys ruined my day!
And i always thought i was something special...
Please let us know if there is light at the end of the tunnel, or maybe even a solution
bubuu is offline Find More Posts by bubuu
Old Jul 20, 2012, 01:32 AM
Felias is offline
Find More Posts by Felias
Joined Jan 2011
+1
@ billpa : Thanks already for investigating. It would awesome if you could sort things out.
Felias is offline Find More Posts by Felias
Discussion help adding a potentiometer on one channel.. joy4u Radios 6 Apr 05, 2012 08:51 AM
Discussion Gifts for the Loved one. blueangeljetgirl Electric Warbirds 11 Jan 12, 2012 10:54 PM
Discussion 7 Billion people! Goat, you're gonna love this one. Mr. Wiz Life, The Universe, and Politics 15 Oct 27, 2011 04:23 AM
Poll 2 Servos on One or Two Channels ? Hossinarizona Radios 2 Oct 09, 2011 10:28 PM
