Old Jun 18, 2012, 02:44 PM
Olscuzbut is offline
Find More Posts by Olscuzbut
Kamloops BC Can.
Prop upgrade
Now that I am using my Smit Nederland to haul my logging barge, I noticed that it takes its time to get some speed on when the barge is loaded with logs. (especially on a windy day). So, purchased a couple of 50mm left and right 4 blade props. Fit very nicely into the kortz nozzles. The original kit came with 45mm 3 blade props. Don't think there will be any overheating problem with the motors, as I ran all day hauling the loaded barge and they were not even warm to the touch. Am using an Mtroniks viper 40 marine esc, so should have no problems there. Eager to get them all out on the pond.
Olscuzbut is offline Find More Posts by Olscuzbut
Old Jun 18, 2012, 03:44 PM
Steve Bad is offline
Find More Posts by Steve Bad
"Take the Cannollis"
Steve Bad's Avatar
Lake Martin ALABAMA
Joined Feb 2006
Nice fit... If they were just one RCH bigger, you would have been out of luck.
Steve Bad is offline Find More Posts by Steve Bad
Old Jun 18, 2012, 11:40 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Try using Kort Nozzle props, with about .045''-.060'' blade tip, to nozzle, clearance. Just remember, the barge does NOT, have brakes!! Have fun. CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Jun 19, 2012, 05:19 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
If the original props were converting maximum motor power to moving water at max efficiency, it is quite possible that bigger props would just increase the load on the motors. If there is no more power available from the motor, there is no more to put into the props. The loaded barges do represent an increased load, so slower acceleration than when unloaded should be expected, whatever the props are doing.
Agreed about the proper square ended one for use with Korts, though.
mfr02 is offline Find More Posts by mfr02
Old Jun 19, 2012, 07:33 AM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Something like this...
woodybob is offline Find More Posts by woodybob
Old Jun 22, 2012, 12:44 AM
capntroy is offline
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Yep, those are what I run on my nozzle boats; pick a high rpm motor, gear the heck out of it and put as much blade area as possible in the nozzle, if you can see sunshine, you don't have enough wheel...
If you want to avoid the expense of the Prop Shop kort props, just buy some Rivabo wheels that are a 1/4" larger than the ID of the nozzle and mill the tips off square to match the nozzle.
capntroy is offline Find More Posts by capntroy
Discussion GWS Mini Dragonfly Upgrad CAMOMAN Micro Helis 0 Jan 08, 2007 01:24 PM
Discussion T-REX 450 XL Upgrad parts, where? byhsu Mini Helis 1 Oct 01, 2006 06:15 AM
Question what to upgrad frist on my car fast line 1st Nitro and Glow Power Cars 1 Sep 01, 2006 06:21 PM
Discussion Vortex extreme upgrad bob_suruncle Parkflyers 0 Mar 28, 2006 12:45 PM
upgrad parts fpr feda dragonfly night_racer Micro Helis 2 Feb 16, 2004 02:23 PM
