Joined Jun 2012
Cutting Foam.
Layout of some of the fuselage parts. Also shown are the intended flight pack components. 4 channel.
The fuse and tail will be foam with some tisssue and paper. The wings will be old-school balsa and tissue construction. Upper is 17.5 X 3.5, lower 13.5 X 2.75 inches. Total area roughly 98sq. " The Olfa circle cutter was used to cut the wheels and the round firewall. Not a sales pitch but I highly recommend one of these if you're a scratch builder. The foam that is painted blue is a test a sample. I used water based Acrylic poster paint and thinned it with alcohol. I'm American but I live in Thailand so I'm somewhat limited with availability of hobby items considered standard back home. The paint technique is also going to be used on the wings. This is the first time I've tried this so bear with me through the testing phase.
Joined Jun 2012
Motor mount and tail feathers
Decided to use a balsa firewall and motor mount. I have some foam planes that have been flying for over 11 years and this always seems to be a weak spot. So a bit of balsa there should do the trick.
Also going to use a bamboo elevator joiner that will also give strength to the horizontal stab. Going to use a vacuum formed cowl, possibly a vac formed cockpit area but Bristol Board might be easier and quicker. Still not sure on controls... This work was done over a three day period but posted mostly today just to catch up..
Joined Jun 2012
Time to grab a tissue...
Now for the tissue part.
This is the first time I've tried to combine tissue and foam. I think it has a place in modeling here as it offers options for compound curves and simulates early or fabric covered aircraft with little addition to weight. The trick is I think to get the finishing product, in this case paint, to be compatible with both surfaces. The tissue I used is general craft store or gift tissue, and the paint... water based poster type acrylic paint. Low cost safe items. I had tested the acrylic paint thinned with isopropyl (rubbing) alcohol applied via airbrush and was pleased with the result. Attractive, good coverage and durable. I wiped the foam board clean with alcohol and dried it prior to painting. Amazing the dirt that came off what appeared to be white clean foam!
Lenox, Michigan
Joined Nov 2005
I use gift paper tissue on my spacecraft and it works great! I print the full color graphics on it, use spray adhesive to stick it onto the foam then spray clear acrylic on top. It tightens up the skins and seals them nicely.
Check out some of my stuff http://www.rcgroups.com/forums/member.php?u=78981 |
Joined Jun 2012
Bit more progress...
I've built real planes, balsa planes, plastic planes, paper planes and a few foam ones so using a little from all is a first so hang in there for my tresting phases...
I printed some tissue for the fuselage but found It didn't quite look right with foam in this particular case so I went back to plain paper. I also found the coloring as downloaded from the web was bit bright. I recall reading something 20 odd years ago about light and models etc so in a nutshell I darkened the print about 25%. Have the turtle deck done and experimenting witrh side fairings. I'm pleased with the test results so moving on. Anyone with me on this? feel free to chime in... this bird might not not be the most popular me thinks...
Making Spoked Wheels
I've attached a PDF of a site no longer with us on making small spoked wheels.
There's a different method outlined at: http://www.papermodelers.com/forum/t...-tutorial.html |
| Thread Tools | |
| Discussion Mini-D Micro DLG | AeroHeadTW | Hand Launch | 223 | May 16, 2013 03:24 PM |
| Sold ParkZone Ultra Micro Mosquito Mk VI BNF-$95 w/shipping | Jason Justice | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 03, 2012 06:09 PM |
| Build Log Glenn Torrance 1/3 Fokker D.VI | Captainhook1 | Scale Fuel Planes | 612 | Jul 06, 2011 09:10 PM |
| Fokker D-VII Micro Scale | Gordon Johnson | Indoor and Micro Models | 40 | Oct 22, 2002 11:08 AM |
| Fokker D.VI 3-view drawing | FLMODELER | Scale Electric Planes | 5 | Oct 01, 2002 08:48 PM |
