Espritmodel.com Heli Air
Old Jun 17, 2012, 07:16 PM
Joined Jun 2011
have a fms 800mm p-51 need some help
so I have a fms 800mm p-51 mustang plane kit that i have tried to learn to fly but never been successful at. and I wanted to know what's the right way to setup a airplane for flight so that it will fly right the first time? and what's the right way to balance an airplane? do they have to be balanced? any help would be great thanks a lot guys.
Iceman320 is offline Find More Posts by Iceman320
Old Jun 17, 2012, 10:20 PM
Just throw it up!
Merlin Power's Avatar
Australia, VIC, Melbourne
Joined Jul 2011
These 800mm warbirds are not suitable as your first plane. They need to be flown quite quickly otherwise they will fall out of the sky. Also, they can be quite cg sensitive and often need weight added to the nose to balance them out.
I ended up with one AA battery stuffed up the nose of the plane which made it a tad nose heavy. The 65mm cg as quoted in the manual is wrong and it will be tailheavy at that cg.
You measure the cg of low wing planes upside down.
Also, if you are flying with the stock radio, these small planes are twitchy.
I would put it away, learn with a beginners plane like a bixler or a skyhawk or a Cessna, then onto a low wing trainer, then maybe onto an 800mm warbird.
Merlin Power is offline Find More Posts by Merlin Power
Old Jun 17, 2012, 11:56 PM
Joined Jun 2011
are the bigger planes easier to fly, than the 800mm ones? cause that's how it was when I learned to fly rc helis it was easier to learn on a 500class heli than it was to learn on a 450 so is it the same with planes would bigger be better?
Old Jun 18, 2012, 04:43 AM
Just throw it up!
Joined Jul 2011
Yeah the larger planes are much easier to fly as they glide better and are not as twitchy. I started with an FMS Cessna 182 skytrainer and it was great. The only bad part was the landing gear and in particular the front lg which takes a beating for a while until you learn how to land a bit more softly.
I have heard that the Dynam Hawksky is a great plane to start with and more forgiving than the Cessna.
I wanted a plane that looked like a real plane which is why I went for the Cessna. Something with a high wing or a powered glider is the way to go to start out with.
Old Jun 18, 2012, 09:21 AM
Joined Jun 2011
ok thanks, maybe i will look into something bigger, but how can i make the p-51 that I already have fly a little bit better? and how can i measure to get the cog and the balance right?
Old Jun 18, 2012, 03:16 PM
Just throw it up!
Joined Jul 2011
I find that the cg for these mini warbirds needs to be around 45mm from the leading edge of the wing. At that point balancing the plane upside down it should be slightly nose heavy. I have found that these planes like to be a bit nose heavy as they penetrate the air better.
If you have a computer radio, you should dial in some expo and dual rates as I find these mini warbirds really twitchy at 100% throws and no expo.
I know that you want to just fly the P51 but I almost guarantee that you will crash it if it is your first fixed wing.
Old Jun 18, 2012, 07:24 PM
Joined Jun 2011
I have already crashed it a couple of times last summer when I was trying to learn to fly it, so I just let it sit for a year while I learned to fly my rc helicopters instead of the p-51. I would really like to learn to fly with the p-51 that I have if possible but if I have to buy another plane i guess I can save up the money after I get my truck painted and done I guess.
Old Jun 18, 2012, 08:06 PM
Joined Apr 2012
Check out the fy-30a gyro stabilizer. It's not cheap, but think of it as training wheels until you get more comfortable with the p51. It will make the airplane very docile in flight, takeoffs & landings & you can switch it on or off.
Rustvyper is offline Find More Posts by Rustvyper
Old Jun 18, 2012, 10:10 PM
that's gonna leave a scar
KCinNC's Avatar
Marina Village, NC
Joined Aug 2007
i know the feeling
i have a 800mm T-28 & 800mm TA6.....they both fly perfect..but the P-51 just didn't want to fly ? i have a second one. still don't want to fly like the other 800mm planes ??? can't figure it out
KCinNC is offline Find More Posts by KCinNC
Old Jun 19, 2012, 02:06 AM
Just throw it up!
Joined Jul 2011
Originally Posted by KCinNC View Post
i know the feeling
Mine has always flown well on both 2cell and 3cell batteries. Add weight to the nose and it is one sweet flying plane. Without weight it is like a dog dragging its backside along the carpet and not flyable. The P40 was the same.
This is proof that it flies well only on a 1000mah 2cell:
FMS/Airfield P-51 Mini 800mm Second Flight of Maiden Day. (1 min 0 sec)
Old Jun 19, 2012, 09:11 AM
Joined Jun 2011
how much weight did you add to the nose of the plane? and i think that I should have bought one of the bigger p-51 planes to learn to fly?
Old Jun 19, 2012, 06:48 PM
Just throw it up!
Joined Jul 2011
I added one AA battery up in the compartment that is visible when the wings are off. The bigger ones are easier to fly, but even then I still think that a trainer is better. Plus you don't want to bang up a nice looking P51
Old Jun 19, 2012, 08:05 PM
Joined Jun 2011
Ok thanks for the help i will decide now if i want to lear to fly planes or just stay with helis. Don't know right now If i want to dump any more money into rc stuff right now.
Old Aug 29, 2012, 07:31 PM
Joined Aug 2012
800mm P40 - Maiden Flight
I just got a banana hobbies p40. I have flown before, but its been a while. I decided I'd take it up.
Well i made the idiot mistake of not velco-ing my battery to the fuselage....yea that resulted in a 150 ft dive to asphalt...
Anyone have a motor for an 800mm fms? msg me.
Thanks!
eric34069 is offline Find More Posts by eric34069
Old Aug 29, 2012, 07:41 PM
Santa Cruz, CA
karltrek's Avatar
United States, CA, Santa Cruz
Joined Sep 2011
Thanks!
This is the exact motor you need. I believe it is the same one that FMS uses. It's inexpensive via Hobby King!
http://www.hobbyking.com/hobbyking/s...dProduct=18648
karltrek is offline Find More Posts by karltrek
For Sale FMS P-40 or and FMS 800mm Misc Parts yahhtrick Aircraft - General - Miscellaneous (FS/W) 0 May 05, 2012 01:52 AM
Discussion Have the FMS P-51 Mustangs been discontinued? P-51 flyby Electric Warbirds 11 Apr 25, 2012 01:24 PM
Wanted FMS Airfield Wrecks.......T-28, P-51, P-40, P-47 eggsplurt Aircraft - Electric - Airplanes (FS/W) 3 Jan 06, 2012 05:01 PM
Wanted Airfield FMS P-51 or any P-51 P-51 flyby Aircraft - Electric - Airplanes (FS/W) 2 Nov 10, 2011 09:13 PM
