Joined Mar 2010
3 axis accelerometer controlled Lights
http://kamus-poweredblog.blogspot.com
This is the link to my Blog describing my accelerometer controlled light strips. Ideas or suggestions welcome! |
Ohio
Joined Nov 2003
Yes. The Airbus in the storm.
Not really, but did put an accel in the "tilt mode", so it was seeing earth, to create a constant angle signal, used to stabilize pitch axis, on a hand toss glider. It only gave a useful signal when close to level. Worthless. A plane is about like a baseball you throw into the air. Ballistic flight. You really need an IMU. Let me clarify the experiment. A PICAXE was used to drive the elevator servo from the tilt accl sensor. On the ground, it worked perfectly. You could hold the plane and tilt nose down, and the elevator would proportionally move up, to correct. But in the air it worked entirely differently. I also tried a GMR magnetic sensor to use the earth field. That worked well, but only in one direction. Gave error going around the compass dial. Just some whacky experiments. |
Ohio
Joined Nov 2003
But that is when level? How about when doing loops and rolls?
The phone just has accels, no gyros? I am no physics expert, have learned a little by reading about the people making IMUs, the math is staggering. There does not seem to be any way to simplify it. |
Ohio
Joined Nov 2003
How steep can you bank? Your phone probably has an ARM cpu, and 3 axis accel, so
that is a lot of power. But remember the trick of the stunt pilot, holding a glass of water, and doing a 360 deg roll, the water stays in the cup. So that level sensor fails! |
Ohio
Joined Nov 2003
I meant they did not work the way I expected in flight.
I was using "tilt mode", not the classic accel use, which is where you get an output only when accel is changing. It seems impossible to make a fully 3D level indicator with only accels, that's all. The fact that IMU's use 3 accels and 3 gyros supports that. Not sure why your phone level app works so well, there is probably an attitude of the plane that will confuse it. |
| Thread Tools | |
| Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro | eyeinsky1 | Aerial Photography | 3 | Jun 06, 2012 03:38 PM |
| Discussion Small Three Axis Accelerometers | Indubitably | Dynamic Soaring | 3 | May 02, 2012 10:53 AM |
| Discussion 3 Axies FLybarless Controllers | WOS | Electric Heli Talk | 2 | Apr 07, 2012 11:08 AM |
| Discussion KK MultiWii Multicopter Controller Board V5.5 for Y3 3-axis 4-axis Y6 6-axis single-a | disneytoy | Multirotor Talk | 2 | Feb 10, 2012 12:21 AM |
| Discussion HillCrest Labs Scoop Pointer, 3 gyroscope, 3 magnetometer & 3 accelerometer. | Toysrme | Multirotor Talk | 5 | Dec 23, 2011 10:25 AM |
