Old Jun 17, 2012, 05:16 PM
sykmethodz is offline
Find More Posts by sykmethodz
Joined May 2012
FPV - Self Contained
Hi Guys,
Does anybody know of a way to set up FPV system that does NOT require the trainer port? Similar to the Fatshark teleporter system?.
I want to set up my joystick and an FPV system simultaneously and I'm finding very little information on this.
Thanks!
sykmethodz is offline Find More Posts by sykmethodz
Old Jun 17, 2012, 06:29 PM
Bindle83 is offline
Find More Posts by Bindle83
The FPV Ninja
Bindle83's Avatar
Brisbane, South East QLD
Joined Dec 2008
Originally Posted by sykmethodz View Post
Hi Guys,
Thanks!
Are you currently using your trainer port for uhf?
I have the use of my trainer port on my Futaba 7c due to installing the uhf inside the case and joining some wires. That may be an option for you also. Otherwise another more tech savvy person on this forum may be able to give you some better guidance.
Bindle83 is offline Find More Posts by Bindle83
Old Jun 17, 2012, 08:07 PM
chemnut842 is offline
Find More Posts by chemnut842
United States, MD, North East
Joined Apr 2011
Yeah - same. I am using TSLRS with a 9C. I just soldered the wires for the transmitter module straight to the pins where a standard module would normally go. Then I gooped a bunch of hot glue on top of it all. I also cut the voltage regulator out and soldered a bit of wire in its place.
chemnut842 is offline Find More Posts by chemnut842
Old Jun 17, 2012, 10:02 PM
Joined May 2012
Fpv
Actually I'm not using the trainer port at all right now. I'm planning to get a set of fat shark dominators and they will require the use of the trainer port for head tracking.. and in order to use the AEOS FPV SYSTEM 1.5 for my joystick i also need the trainer port to plug in my joy stick.
Old Jun 17, 2012, 11:03 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
You can use this system directly connected to a UHF tx. It's for joystick only.
http://www.nghobbies.com/cart/index....roducts_id=486
Martin Y is offline Find More Posts by Martin Y
Old Jun 17, 2012, 11:48 PM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Skymethodz - No offence intended but your first post does not make any sense, this is how it should read.
Hi Guys,
Does anybody know of a way to set up a head tracking system that does NOT require the trainer port? Similar to the Fatshark teleporter system?.
I want to set up my joystick and the head tracking system simultaneously and I'm finding very little information on this.
Thanks!
Its not the FPV system that uses the trainer port it is the head tracking.
and sorry I cant help with an answer but i hope i've helped you to explain your situation a bit better so that others can help.
nogas is offline Find More Posts by nogas
Old Jun 18, 2012, 03:16 AM
D-OCHO is offline
Find More Posts by D-OCHO
The Netherlands, OV, Oldenzaal
Joined Jul 2010
Good answer.
@Skymethodz:
Look at the following picture maybe it might help you with your problem.
By the way this is backside of a Futaba square plug.
D-OCHO is offline Find More Posts by D-OCHO
Old Jun 18, 2012, 03:01 PM
Joined May 2012
Firstly I'm sorry for the confusion, as I'm sure you all can tell I'm VERY new to FPV. Thank you guys so far for all the help I'm starting to understand a bit more. This sounds like a Mod/DIY job right? I'm fine with that but I don't have experience doing this with RC Equipment though. Slightly related - I was a computer tech for about 10 years so this doesn't scare me a bit but I don't know anything about it.
I am purchasing a ton of new hardware for this set up so I am totally open to any suggestions you guys might have!. Some of the hardware includes...
1) Transmitter - Futaba?
2) New FPV set up - Fatshark Dominator head set w/ MIG head tracking or similar
3) Pan/Tilt mount and Camera
4) Joystick - Logitec G940 ( flight stick and throttle)
The goal is to set up my joystick and throttle system (logitech G940) for flight control and throttle as well as a Head tracking system to be used simultaneously for FPV flight. Unfortunately the hardware I am finding requires that both of these use the same trainer port(see links below).
Thanks a lot for the link D-OCHO! - Am I right in thinking you are suggesting I would have to mod the trainer cable or get a male Futaba square adapter and make the connections manually between the joystick and head tracking pins? if so, would there be any issues with software or recognizing the hardware attached?( I would associate this with driver issues)
What ism having trouble with is figuring out is... what hardware I need for this to work with both the joystick and throttle as well as the head tracking simultaneously while in flight
Any links one my have to tutorials or websites that have more detailed information about how to mod / configure this would be REAAALLY appriciated.
Hardware I found
For the joystick communication - requires trainer port
http://www.aeorc.com/english/?product-324.html
For FPV - requires trainer port.
http://www.hobbyking.com/hobbyking/s...PV_System.html
P.S. I KNOW I'M A NOOOOB! :/ I hope you guys have the patients to help a guy out. Thanks in advance,
Chris
Old Jun 18, 2012, 03:08 PM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
well better read on the reviews on that 'FPV system 1.5' product for joysticks. I heard it can be a real pita to find compatible components and set up to run reliably. It also says it may work with certain head tracking unit(s). But be advised you should find someone on RCG with a working system and just copy their setup. Most of these will not work with just any joystick.
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old Jun 18, 2012, 04:46 PM
Joined May 2012
Your definitely right, I read the same and watched a video or 2 about the Aero fpv system as well. As well. my hope was to make any adjustments needed on the programmable transmitter to overcome any downfalls of the fpv system.
That being said I would MUCH prefer to copy somebody elses working design unfortunately I don't know how to find that person :/
Discussion Self Esteem vs Self Respect ... logan5 Life, The Universe, and Politics 7 Jan 18, 2012 07:31 PM
Build Log Self designed Self made depron craft Aviator001 3D Foamies 6 Jan 04, 2012 09:30 AM
Discussion Best self-levelling plane style for FPV BJM-Maxx FPV Aircraft 14 Apr 02, 2010 05:31 PM
