The FoamJack - The 'Leftover' Foamy - With TONS of Build Pics
I drove up to San Francisco, and had to leave my beloved cardboard park flyer (that was still a WIP) behind. I quickly felt I needed something in the air, but I really didn't have much in the way of building materials. No wood or plastic or any linkage parts, but I did have a bag of misc tubes, some welding wire, and my tools. Nearest LHS is pretty far away. So I went to home depot and bought only a sheet of pink foam, and would wing the rest of the build with materials that weren't originally designed for modeling. I wanted to keep it simple, so I remembered the Vought XF5U 'Flapjack' and used it as inspiration:
I was going to build it with dual motors and dual stabilizers, but I went for a simpler design while preserving the circular body. In short, I'm trying to build a plane with almost no dedicated RC-built parts except a motor, Rx, and servo combo from a much smaller plane. Finished: Parts List (Yes, it seems strange. I know.): 1x Sheet of 3/4" HomeDepot PinkFoam 1x Roll of your favorite brand Duct Tape. (Order this if you want to be awesome.) 2" of 18 gauge welding wire (I think it is, anyway. Random rusty wire next to my welding stand in the garage. Any stiff 1mm wire would work.) Assorted Bits and Pieces of Brass Tubing (From a bag like this) 10 sticks of hot glue A thin carbon fiber strip Turnigy 1811 2900kv Outrunner Turnigy Plush 6A ESC Nano-Tech 850mAh 2S Berg 4L Receiver (LHS didn't have any micro Spektrum Rx's, so I went 72mhz) The Fuselage: I started out with a broken screwdriver and a bit of welding rod with the corners bent, and used a pencil to trace a circle: I then cut the circle: Then I took a razor blade to the edge and cut it. It's pretty rough but will be smooth enough once the coating gets on here. This isn't a precision aircraft. I also cut the control surfaces. And I gave it a test coating. Yes. That is duct tape. It seems rather convenient actually. A bit heaver than packing tape but much more sturdy. This thing will be crashing a lot. The Motor Mounting: I didn't have any wood around at all (I don't even have a workstation yet up here, was still using the floor. Ergo I don't really have ANY building materials). So I cut a small block of foam and four welding wires, with the tips bent into hooks: I then drove the wires through the foam and made them hook onto the edge of the motor mount, like so: Then my cat decides to launch an assault on the secret manufacturing facility: Now that the invasion is repulsed, I get back to work. I use my soldering iron to channel the foam, and lay in the back of the wires, and hot glued them in: Now I see something worrying: during the hot glueing, the motor block slid a bit, and the center of the motor is now about 1cm away from center. It is still facing forward, so it won't be a huge concern, but I'll have to compensate for that when flying: I accidentally broke off the tail piece of the body, so I stick a carbon rod back in it and hot glue it on: Next, the carving and complete coating. |
| Thread Tools | |
| Build Log Big Quad build from leftovers | KCV6 | Hoverfly Technologies | 18 | May 03, 2012 08:20 AM |
| Sold GoodLookBuy X400 (or X525) leftover parts | Rifraf | Aircraft - Electric - Multirotor (FS/W) | 0 | Apr 05, 2012 08:58 PM |
| Discussion What's Your favorite Thanksgiving Leftover? | Air Vaca | Life, The Universe, and Politics | 47 | Nov 25, 2011 10:21 PM |
| Chariot mini Foami | ilaurencet01 | Indoor and Micro Models | 2 | Mar 30, 2005 04:30 AM |
