Old Jun 16, 2012, 11:57 PM
SGsoar is offline
Find More Posts by SGsoar
United States, CA, LA
Joined Aug 2007
New updated Crius Multiwii SE flight controller
is anyone flying this board? It looks similar to the original crius SE edition but smaller and with a port for GPS
SGsoar is offline Find More Posts by SGsoar
Old Jun 17, 2012, 12:18 AM
haydent is offline
Find More Posts by haydent
haydent's Avatar
Australia, NSW, Temagog
Joined Jun 2012
and more expensive. for same money might as well get the pirate board and have more connect ability again plus mega 2560 chip !
http://www.rcgroups.com/forums/showthread.php?t=1648569
http://www.goodluckbuy.com/mwc-multi...ard-quadx.html
haydent is offline Find More Posts by haydent
Old Jun 17, 2012, 04:12 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
The Crius is actually $10 cheaper than that board, and it takes up less space without all the pins sticking out the sides.
http://www.ebay.com.au/itm/Mini-RC-U...item3cc53b6d2b
The ATMega2560 chip is the same performance as the ATMega328 chip on the Crius, the only difference is the 2560 has 256k of flash. As the Multiwii code uses just 16k you have 240k empty. Kind of pointless really.
Erknie is offline Find More Posts by Erknie
Old Jun 17, 2012, 06:01 AM
GoFaster is online now
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Not really. With the new functionality being added recently, they are bumping into ATMega328P flash and RAM/stack memory limits.
GoFaster is online now Find More Posts by GoFaster
Old Jun 17, 2012, 06:36 AM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
I ordered one of the new Crius boards last week, looking forward to using it. I already have a couple of other Crius boards, and both fly nicely.
TS00 is offline Find More Posts by TS00
Old Jun 17, 2012, 06:37 AM
vodanh1982 is offline
Find More Posts by vodanh1982
Joined Feb 2012
ATmega2560 has 4 x 16bit timer. It will be useful for 400Hz Hi-res motor output.
vodanh1982 is offline Find More Posts by vodanh1982
Old Jun 17, 2012, 09:06 PM
SGsoar is offline
Joined Aug 2007
I'm a little confused about the RX input.. does it only work with newer receivers that have ppm sum? or is it possible to use old style rx with individual channel connection?
Old Jun 17, 2012, 09:52 PM
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
MultiWii will run with either. Though if you want to run a specific config or extra features (I forgot exactly what) you have to use PPM sum in order to free up pins
Old Jun 21, 2012, 11:06 AM
magik30 is offline
Find More Posts by magik30
France, Languedoc-Roussillon, Nimes
Joined Mar 2012
Too bad she did not come out with new BARO.
I have to buy a second for my little SE Crius tricopter, then what?
I'll be waiting a bit after this news.
magik30 is offline Find More Posts by magik30
Old Jun 24, 2012, 11:02 AM
magik30 is offline
Joined Mar 2012
effacer
Old Jul 06, 2012, 01:05 PM
mealie is offline
Find More Posts by mealie
Joined Jun 2011
Hey guys
There is lower price in www.rctimer.com.
They also provide I2C-GPS NAV Module and cheap U-blox GPS receiver.
The new SE FC can used for standard recriver, no only PPM SUM style.
mealie is offline Find More Posts by mealie
Old Jul 23, 2012, 01:13 AM
blackbird2 is offline
Find More Posts by blackbird2
Greece, Makedonia Thraki, Ag. Vasilios
Joined Mar 2010
If you add the gps is like the naza feaures - RTH etc. ?
Thank you.
blackbird2 is offline Find More Posts by blackbird2
Old Jul 23, 2012, 06:56 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
Hey I have the Remzibi OSD with GPS.. Can I just piggy back of that one to the Crius board ?
http://www.goodluckbuy.com/remzibis-...r-fpv-uva.html
jbalat is offline Find More Posts by jbalat
Old Jul 24, 2012, 05:42 AM
eyeinsky1 is offline
Find More Posts by eyeinsky1
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Originally Posted by mealie View Post
Hey guys
Standard receiver can be used up to a Hexa copter, I posted the wiring diagram here but only sum ppm. I will put the standard hookup later.
http://www.rcgroups.com/forums/showthread.php?t=1695636
eyeinsky1 is offline Find More Posts by eyeinsky1
Old Aug 25, 2012, 03:56 AM
hamburger is offline
Find More Posts by hamburger
Hamburger
hamburger's Avatar
Joined Jan 2010
going to get one of these?
Then please read about bad service from forcehobby@ebay. http://www.rcgroups.com/forums/showt...0#post22508305
Apart from that, I have several 5x5 crius lite boards and two crius mini boards which work as expected.
hamburger is offline Find More Posts by hamburger
Discussion Freeflight FF or Crius Multiwii se araz_baldar Multirotor Talk 1 May 16, 2012 04:18 PM
Discussion Help with the CRIUS SE multiwii based board vcazan Multirotor Talk 7 May 07, 2012 03:38 PM
Sold crius multiwii se alcrsh01 Aircraft - Electric - Multirotor (FS/W) 1 Apr 20, 2012 10:09 AM
Sold CRIUS MultiWii SE V2.0 Talajouy Aircraft - Electric - Multirotor (FS/W) 4 Apr 19, 2012 12:06 AM
For Sale New Multiwii quadcopter with Crius Lite $210 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Mar 06, 2012 06:12 AM
