Old Jun 16, 2012, 08:39 PM
nautique is offline
Find More Posts by nautique
nautique's Avatar
United States, CA, Roseville
Joined Feb 2011
Question
Power Question
Just bought these motors:
http://www.rc-drones.com/Avroto-M2814-11S.php
And have these Esc's:
http://www.atlantahobby.com/store/pc...ESC-p16423.htm
And plan to use this battery:
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Are my ESC's adequate or do I need to go bigger?
nautique is offline Find More Posts by nautique
Old Jun 16, 2012, 08:44 PM
a2j812 is offline
Find More Posts by a2j812
Joined Apr 2012
You should be fine. I'm running a 3S 5000mAh, 1440KV motors and a 25Amp speed controller, and things are running fine.
a2j812 is offline Find More Posts by a2j812
Old Jun 16, 2012, 09:03 PM
jpsabo is offline
Find More Posts by jpsabo
jpsabo's Avatar
Joined Feb 2011
You should have no problem. I run the Avroto motors with 30 amp Maytech ESCs on 3S and the ESCs barely get warm. You picked a good motor too...I've used these on 3 quads and they perform great.
Regards,
John
jpsabo is offline Find More Posts by jpsabo
Old Jun 16, 2012, 09:16 PM
nicnaimless is offline
Find More Posts by nicnaimless
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
I run Avrotos on 30amp Turnigy Plush and haven't had an issue. You should be just fine.
nicnaimless is offline Find More Posts by nicnaimless
Old Jun 16, 2012, 09:22 PM
nautique is offline
nautique's Avatar
Joined Feb 2011
Very good to hear. Now if I only knew how to mount the motors, nothing lines up. Running this frame:
http://www.cnchelicopter.com/servlet...-carbon/Detail
Overkill, perhaps? Anyone think so?
Old Jun 16, 2012, 09:34 PM
jpsabo is offline
jpsabo's Avatar
Joined Feb 2011
Try mounting the motor directly to the mount on the frame. Don't use the mount included with the Avroto. You should be able to get at least 2 screws to hold the motor, which is fine. Blue Loctite them, too.
Old Jun 16, 2012, 10:55 PM
c/f is offline
c/f
Find More Posts by c/f
c/f
Joined Jan 2004
A bit unconventional thinking but heres the way I see it.
589gram battery is good for aprox 1500W for 5 minutes using my rule of thumb that 10grams battery nets 25W power for 5 minute.
1500W / 4 is 375W per motor.
375W / 14.6VDC under load is 25.6 AMPS
Everything looks Kosher to me............
c/f is offline Find More Posts by c/f
Latest blog entry: Time Capsule Heli
Help! Power HD DSP-33 sub micro servo question? sgomes Micro Ready-to-Fly 0 Mar 10, 2012 11:15 AM
Help! Question regarding the repair of a Power 25 haines74 Power Systems 9 Mar 03, 2012 08:51 AM
Discussion Anderson Power Pole Metal Locking Pins Question? itsme2 Batteries and Chargers 7 Mar 01, 2012 09:31 PM
Discussion Building GP Reactor 3D, Power question. billmjam Electric Plane Talk 0 Feb 26, 2012 07:59 AM
