Jun 16, 2012, 05:49 PM
United States, TX, Humble
Joined Mar 2011
Blade 450 Wobble
I picked up a brand new Blade 450 that crashed on the first take off. When I got it, it had new blades. When it spun up, it wobbled. I took the head apart and found a bent feathering shaft, bent main shaft and a couple teeth missing on the main gear. I replaced all of these items as well as the thrust bearings on the feathering shaft. Now it spins up with much less wobble, but still wobbles a little. Also, the main gear and tail gear don't spin flat, the wobble up and down as the head spins.
I'm assuming that I need to replace the One-Way bearing hub and shaft but before I spend too much more on parts, I wanted to see if there's anything else I should try.
Thanks!
