This thread is privately moderated by The Don, who may elect to delete unwanted replies.
Old Feb 09, 2013, 02:47 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Sounds like you have a clone hobbywing ESC. If it does not say "Hobbywing Flyfun" on the ESC and come with an anti-counterfeit code then it is a knockoff.
Don
The Don is online now Find More Posts by The Don
Old Feb 09, 2013, 11:30 PM
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
I checked it out tonight and there is a label on the bag. HobbyCool.
To me that's Not Cool! A Big Vendor advertising it on eBay as an HW and it has an HW label on the ESC. Guess that's faked.
heritageflyer is offline Find More Posts by heritageflyer
Old Feb 10, 2013, 12:18 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Correct, label is faked, packaging duplicated etc, except the performance is not duplicated. Hobbywing has not made "Pentium" labeled ESC since May 2011. Any vendor selling a Hobbywing "Pentium" is selling a knockoff. That is why HW changed the name of their ESCs to FlyFun and well as include an anti counterfeit code with each ESC. I have and always will only sell genuine Hobbywing ESCs.
Don
Old Feb 10, 2013, 10:55 AM
Joined Nov 2008
Just went to order and see the 40A is out of stock. How long before they are back?
Old Feb 10, 2013, 11:00 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Just got a shipment in and guess I forgot to add the stock in, give me few minutes to update the website.
Don
Old Feb 10, 2013, 11:20 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Website update.
Don
Old Feb 10, 2013, 12:42 PM
Joined Nov 2008
Old Feb 14, 2013, 08:27 PM
Joined Nov 2008
Maiden Flight on the new 6000Kv and Wemo Combo! No issues with swapping out the Genuine HW 40A for the fake one and this one worked instantly in all ways, programming and running.
Glacier 3S 1000 30C Lipo balanced out right on, perfect CG in flight.
36-39A @ 375 - 393 Watts!!! Just over 3 minute flight and the pack was spent.
Next test is try a CG check and mounting with the Zippy Compact 3S 1800 25C. Maybe I can buy another two minutes flight time...
F-22 Mini-Raptor on Don's Wicked 6000Kv 50mm Wemotec Fan! (3 min 16 sec)
Old Feb 17, 2013, 04:08 PM
Dallas
Joined Aug 2002
Hello Don, I have a hobby people f16 kit, no fan or anything came with it, plan to run 2200-2600 4S with it. What motor fan combo do you recommend? I'd want it balanced as well. Thanks!
birdy233 is offline Find More Posts by birdy233
Old Feb 17, 2013, 04:23 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
See post #2 in this thread. I used Setup B and 4S 2200. For bigger 4S go setup C or D.
Old Feb 21, 2013, 10:58 PM
Yes it was Abby Normal
Joined May 2012
Hello Don,
FH64_Lucky helped me find you....thank goodness for the internet....always a wonder from Ham Radio days.
I just ordered an HK Flying Shark...and one of your balanced 64mm EDF set ups as follows:
Order #: 130221-203500-9597
Wicked EDF Motor 4800KV
Motor Configuration: Standoff w/rotor plug for EDO Mount and Dynamic Balance
Balancing: Standard Balancing
64mm EDO Type I EDF Ducted Fan Unit
Rotor Plug: Include DonsRC 3mm rotor plug (slip fit)
I am wanting more low end gunt than top end speed for this crazy flying shark. This is my first EDF so I may have mis-matched my motor thinking that a KV4800 would be better for this 700G RC airframe than a KV4400 or lesser KV motor. Please forgive my noobness regarding KV to RPM to thrust ratio. Anyway...if you have a better suggestion for my set up to the Hobby King Flying Shark please make changes at will....I'll pay more as needed.
I am flying from a Fort Worth Texas area club grass runway strip...so this EDF shark will be hand launched...I wanted to make sure I have enough hand launch thrust to make take offs a little more easier....and provide this thing with enough power to scat back up verticle from a low slow glide path down the runway.
Your suggestions are most welcome..and if the KV4800 is a good match to the 64mm fan assembly then....good!
Thanks in Advance,
TwistedGrin
Hurst, Texas
TwistedGrin is offline Find More Posts by TwistedGrin
Old Feb 21, 2013, 11:50 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Actually I think that will be a good setup for the shark. It is more power than the stock setup yet not the excess power of the 4S systems. I think you will like the setup. Make sure you use a 40 amp ESC and I would suggest a 3S 2200 lipo 30C or higher.
Don
Old Feb 22, 2013, 09:06 AM
Joined May 2012
Don
Aye 10:4 Don...Will have a SkyPower 45amp BESC with 2250mah 65C 3S LiPo...should help keep the power valves open
Thanks for balancing out the rig too.
TwistedGrin
Old Feb 23, 2013, 04:38 PM
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Wicked plus 4400kv
Hi, Don - any ETA for restock on the 4400's?
PikeStaff is offline Find More Posts by PikeStaff
Old Feb 23, 2013, 05:09 PM
Joined Nov 2008
Third flight on the Zippy Compact 3S 1800 25c's today. Not as powerful as the Glacier 3S 1000 30c's. Did gain about 45 sec with laying on full throttle most of the flights. So they did last longer, but the Glacier 30c's have more Punch.
Thinking about getting some 3S 1500-1600 30-35c's to try next. I think that is the happy medium for weight vs power.
F-22 Dons Wicked 6000 Wemo Combo on 3S 1800 25c (3 min 45 sec)
Sold Dons Wicked EDF 4800KV brushless and 55mm EDF UNIT hi2nr Aircraft - Electric - Jets (FS/W) 4 Mar 01, 2012 07:51 PM
Sold Dons Wicked EDF 4800KV 55mm EDF unit hi2nr Aircraft - Electric - Power Systems (FS/W) 0 Mar 01, 2012 07:28 PM
Mini-HowTo Mounting the Wicked EDF motor into the HET 6404 64mm EDF Fan unit The Don Don's RC 0 Jan 28, 2012 12:20 PM
Discussion dons wicked edf plus 4400 60mm edf applications tommythecat Don's RC 6 Nov 20, 2011 02:13 PM
Question Hobbykings edf 35mm Mig-15 *Wicked Setup* deuce66 Don's RC 4 Oct 27, 2011 08:56 AM
