The problem is that 70mm EDF are usually meant for high powered setups and cosequently on the heavier side and will be overkill for you r model. That A-10 model really should have had only 55 or 64mm fan units. The only 70mm fan unit I think will be close to what you have is the GWS unit they used in the A-4 they sold.
Latest blog entry: Wicked Powered Tech One Neptune EDF!
It is not listed as it will damage the motor on 4S.
Is that 64mm EDF?
What amp ESC do you have in now?
My guess looking at the size of the model is that Setup C would be preferred (see post #3 in this thread).
350 watts will fly a Phase 3 F16, the only thing is the power system is kind of heavy for the watts putting out. For comparison, the Wicked 4800 motor in one of the 64mm fan units I sell
Setup A on this page: http://www.rcgroups.com/forums/showp...21&postcount=2 will put out ~350-380 watts on 3S yet the motor and fan unit will weight less than just the Eflite 3200 motor. So you will be carrying some extra weight using that stock Habu setup. |
| Thread Tools | |
| Sold Dons Wicked EDF 4800KV brushless and 55mm EDF UNIT | hi2nr | Aircraft - Electric - Jets (FS/W) | 4 | Mar 01, 2012 06:51 PM |
| Sold Dons Wicked EDF 4800KV 55mm EDF unit | hi2nr | Aircraft - Electric - Power Systems (FS/W) | 0 | Mar 01, 2012 06:28 PM |
| Mini-HowTo Mounting the Wicked EDF motor into the HET 6404 64mm EDF Fan unit | The Don | Don's RC | 0 | Jan 28, 2012 11:20 AM |
| Discussion dons wicked edf plus 4400 60mm edf applications | tommythecat | Don's RC | 6 | Nov 20, 2011 01:13 PM |
| Question Hobbykings edf 35mm Mig-15 *Wicked Setup* | deuce66 | Don's RC | 4 | Oct 27, 2011 07:56 AM |
