Old Jun 16, 2012, 02:08 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
Best way to balance props
Is putting a small amount of tape on the outermost part of the leading edge on the unbalanced side of the prop an accepted way to balance? I would rather not sand the prop.
ripmax is offline Find More Posts by ripmax
Old Jun 16, 2012, 02:28 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
That's exactly what I do, and I can balance the props pretty quickly and well enough to give smooth and quiet flight, and probably fine for video/FPV.
I used some cheap PVC electrical tape to start with, but it didn't stick well enough and tended to fly off after a few flights. Use a tape with good adhesion. Even sellotape works OK, but it's not really heavy enough for props that need a lot of balancing.
mattcro is offline Find More Posts by mattcro
Old Jun 16, 2012, 02:30 PM
SeismicCWave is online now
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
That's only half way done. You also need to balance the hub of the prop.
SeismicCWave is online now Find More Posts by SeismicCWave
Old Jun 16, 2012, 02:39 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
How do you do that? I'm sitting here balancing props as its too windy out to fly!
Old Jun 16, 2012, 03:00 PM
AMA 46133
Hawaii
Joined Feb 2003
1) The balancer has to be really free spinning. Any friction will create a false sense of balance. The best I have used is that magnetic one.
2) I use lead tape for golf clubs. I have heard you can also get sticky back copper tape.
When you spin the prop the goal is to have the prop stop at any position. If your balancer is really good the prop will always "hang" on the heavy side. The heavy side does not have to be one prop blade. If you look carefully you will notice one side of the hub will always hang down. That is the heavy side. You have to put some weight on the light side (the side that faces up). Once you get the prop to stop randomly then it is really balanced.
Also when you spin an unbalanced prop you will notice that the prop will actually speed up when the heavy side pass the top. It will also slow down when the heavy side is on the bottom.
Sometimes when you balance the hub the blades will be off balance and you have to add tape to the light blade. Sometimes when you add tape to the light blade the hub will now go out of balance.
It is one of the most frustrating to do. However it is also the most rewarding once you get them balanced.
Also using the proper surface of the propeller to engage to the balancer is also important. The balancer usually comes with two slider with O-rings in the middle to act as friction stops. You push them on the prop to center it on the shaft. Use the cone shaped part to push into the prop center hole on the bottom of the prop. Use the flat part to sit on the top of the prop hub. If you are not consistent you will spend a life time balancing your prop. Every time you put the prop on the balancer differently you have to go through the whole procedure and balance again.
If you cannot center the prop properly on the balancer there is no sense in balancing the prop. A poorly balanced prop is worse than using a prop from the factory without balancing.
Old Jun 16, 2012, 03:39 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
Thanks for replies,
SeismicCWave, I have a magnetic hobbyking balancer, which....I'm not impressed with, you can balance a prop, turn it around on the balancer and its out of balance, from what u said down to the hub balance, but it has no orings just 2 cone stops that screw into the prop hub, so there's no way of telling if they are centered correctly.
Think I'm wasting my time with this rubbish balancer!!
Old Jun 16, 2012, 03:47 PM
askman is online now
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
it is funny, I am old school and use hand balancer. it works well enough if you know how. but you need to start with good quality props. some are just garbage.
with decent quality props, I can use hand balancer and get good performance as long as motor is ok. (I've also had some bad DJI motors that needed big balancing help) I need to swap it out as it is iffy to balance motors and I have some sunnyskys coming.
i do check for hub balance. if hub is really out, chances are the prop is garbage. LOL. most of better props (except for woodies) tend to have good hub balancing. (ok, APC sometimes have issues with hub, and I tend to avoid them)
askman is online now Find More Posts by askman
Old Jun 16, 2012, 03:52 PM
whakahere is online now
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
the Top Flite TOPQ5700 balancer looks nice but I can't find anything like that in europe.
whakahere is online now Find More Posts by whakahere
Old Jun 16, 2012, 04:14 PM
AMA 46133
Hawaii
Joined Feb 2003
Yeah I think I am talking about the Top Flite balancer. Actually I made my own. I use some super strong neodymium magnet and a shaft from my old High Point balancer.
Old Jun 16, 2012, 04:15 PM
AMA 46133
Hawaii
Joined Feb 2003
Thanks for replies,
LOL if the prop is out of balance when you turn it around then it is pretty hard to know when it is in balance. Does the cone stop have a flat end and a coned end? You use the cone end on one and the flat end on the other.
Old Jun 16, 2012, 04:28 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
Two cone ends, both the same.
Old Jun 16, 2012, 05:15 PM
recep is offline
Find More Posts by recep
recep
recep's Avatar
Ankara, TURKEY
Joined Sep 2005
After all motor and prop balancing with a balancer you can still get more improvement with this technique.
http://www.rcgroups.com/forums/showp...&postcount=228
recep is offline Find More Posts by recep
Old Jun 16, 2012, 08:54 PM
signal15 is offline
Find More Posts by signal15
Atomic Playboy
United States, MN, Inver Grove Heights
Joined Jun 2012
Keep in mind your cones must be balanced also. The rubber cones on my turnigy balancer were not even close to balanced when I got it. They are better now, but still off enough that I can balance a prop, reorient the cones, and it appears the other side of the prop is the one that's too heavy.
I need to spend some time with it tonight. If anyone has tips on balancing the cones, post them. These things are a PITA. The holes in them were not even centered when I got them. I'd buy balanced cones if someone sold them.
signal15 is offline Find More Posts by signal15
Old Jun 16, 2012, 09:28 PM
AMA 46133
Hawaii
Joined Feb 2003
I am searching for them right now. I have been struggling to find some good precision cones or prop adapters. I made one on my lathe but it is not quite precise enough.
Old Jun 16, 2012, 10:01 PM
icsteve is offline
Find More Posts by icsteve
Imlay City, MI
Joined Dec 2006
Instead of tape, I use clear nail polish. I figure it weighs about the same, and it won't come off.
icsteve is offline Find More Posts by icsteve
Question What is the best way to balance motors ?? G-unit Multirotor Talk 3 Mar 16, 2012 09:36 PM
Discussion Best way to cut down a prop? Randy_H Power Systems 21 Feb 06, 2006 10:43 AM
Transition to Jets from prop - best way?? albireo Electric Ducted Fan Jet Talk 25 Oct 16, 2005 12:43 PM
best way to enlarge hole in prop. JimF Foamies (Kits) 0 Dec 13, 2003 10:57 PM
GWS Box and APC Prop - What is best way to mount? StahlmanGC Power Systems 8 Oct 06, 2003 07:09 PM
