Old Jun 16, 2012, 10:17 AM
Nethole is offline
Find More Posts by Nethole
Registered Lurker
Nethole's Avatar
Joined Aug 2004
which, DJT or DFT to use with turnigy 9x?
I'm having trouble figuring out which one can be used with the turnigy 9x
Nethole is offline Find More Posts by Nethole
Old Jun 16, 2012, 11:27 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
DJT.
DFT is Futaba standard, need an adapter to make it work in a 9X.
renatoa is online now Find More Posts by renatoa
Old Jun 17, 2012, 03:11 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
Hey, did you see the prop adaptor pictures I took time to post for you?
ripmax is offline Find More Posts by ripmax
Old Jun 17, 2012, 04:57 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The 9x has JR form factor module slot so requires DJT.
Daedalus66 is offline Find More Posts by Daedalus66
Old Aug 27, 2012, 12:53 PM
flipy is offline
Find More Posts by flipy
United States, FL, Tampa
Joined May 2010
Hi, I want to use a FrSky TX with both an Hitec Aurora 9 and a 9X.
If I buy one of those (either DFT or DJT), will it be possible to use it on the other radio?
Also, if a mod needs to be done, is it just a matter of pinout connections?
flipy is offline Find More Posts by flipy
Old Aug 27, 2012, 03:47 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The 9X uses a JR type module socket so it can be used with the FrSky DJT directly or also uses the DFT with an adapter:
http://www.flytron.com/openlrs/123-f...e-adapter.html
The Hitec A9 has a Futaba/Hitec module opening but more pins than the normal Futaba/Hitec modules so the regular DFT module needs to be modified!
http://www.rcgroups.com/forums/showt...ht=hitec+modul
coriolan is online now Find More Posts by coriolan
Old Aug 27, 2012, 03:52 PM
flipy is offline
Joined May 2010
It is possible to make a custom cable to plug the TX to the radio?
I'm planning on hooking it up with velcro to the back side of the radio and be able to switch if needed.
My only concern if anything else has to be done to the module/radio in order to get it working.
Old Aug 27, 2012, 06:20 PM
coriolan's Avatar
Canada
Joined Sep 2006
It is possible to do so with a cable between module and Tx socket but a bit risky as the pin order isn't the same for JR and Futaba/Hitec(regarding V+ and ground). Much safer to use the trainer port to feed the ppm to the module, but in the case of Aurora9 & 9X the trainer socket only provide ppm&ground so you would need a mean to power the module(kind of like the Anylink system).
Old Sep 01, 2012, 08:59 AM
FPVking is offline
Find More Posts by FPVking
Estonia
Joined Jul 2011
HK combo offer for JR module + Telemetry RX is good option.
Just TX module is more expensive.
FPVking is offline Find More Posts by FPVking
Old Sep 04, 2012, 04:31 AM
flipy is offline
Joined May 2010
Is the PPM output the same on both modules?
Apart from the PINs, may be the signal inverted or something like that?
Old Sep 12, 2012, 05:12 AM
Joined Sep 2007
Today modules are universal, autodetects PPM logic
Discussion Can the Turnigy 9x with FrSky DIY kit be used with simulator genrlst Radios 2 May 23, 2012 01:19 PM
Discussion Can you use the Turnigy 9x for simulator or buddy box? RPTheLefty Electric Plane Talk 3 Feb 09, 2012 06:44 AM
For Sale Turnigy 9x with Smartieparts board and LCD, Frsky DJT/DHT-U Spare Smartieparts board daign Aircraft - General - Radio Equipment (FS/W) 4 Nov 27, 2011 08:20 PM
Help! Help with my new Turnigy 9x/DJT/D8RSP/DHU setup for my quadcopter: daign Radios 0 Aug 05, 2011 02:33 PM
