Old Jun 16, 2012, 12:00 AM
ognolman is offline
Find More Posts by ognolman
United States, NC, Butner
Joined Jun 2011
Standoffs a little too short
I've got a DA 50 I'm mounting in a Sbach that previously had a DLE 55 in it and I've found that the standoffs for the DA a re just a smidge too short. The back of the spinner is going to rub the cowl on one side. So I was thinking about adding washers to add about 1/8" to the standoff length. I was planning on adding them to all four standoffs at the firewall to preserve any thrust angles it needs.
Does this sound like a good plan?
Ben
ognolman is offline Find More Posts by ognolman
Old Jun 16, 2012, 04:09 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I've done it. Should work.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Jun 16, 2012, 06:23 AM
epoxyearl is online now
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
The only concern is how many threads you'll have in the standoff,after the washers are added......Be careful that at least 1/4-5/16" of bolt goes into the stand off,and not just a couple of threads.....If that checks out,you're fine.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: "Everything OLD is New...
Old Jun 16, 2012, 09:40 AM
ognolman is offline
Joined Jun 2011
Good point,I should have plenty of thread in the standoffs. Thanks, fellas!
Ben
Old Jun 19, 2012, 11:20 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
An old tool and die man told me one time that 1.5 X Diameter of the bolt/screw is the minimum amount of thread you should use.
I think he was talking about steel and cast iron. IMO, 2 bolt diameters in aluminum should be safe enough. I believe this should be obtainable in most situations.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: I looked and I looked and I...
Old Jun 19, 2012, 10:46 PM
ognolman is offline
Joined Jun 2011
I tried it out last week and it flew great with two washers under each standoff. I'm going to get some longer bolts for it just for that extra margin of safety, but I'm pretty sure I've got 2 bolt diameters in the standoffs now, maybe more. I had a DLE 30cc almost fall out of the cowl not long ago, so I'm pretty anxious about that now.
Thanks for the tip!
Ben
Discussion Wires are too short! mprs4me Electric Plane Talk 28 Jun 07, 2012 02:33 PM
Discussion Put together a little indoor flying Video (with aerial video too) cannondale1974 Scratchbuilt Indoor and Micro Models 0 Mar 09, 2012 11:04 AM
Help! Nose gear is too short dk31 The Builders Workshop 9 Dec 10, 2011 12:52 PM
Discussion Losi 8ight T- motor shaft too short Endlesslag Electric Motor Design and Construction 1 Sep 23, 2011 07:09 AM
Discussion Saito 62 propshaft too short Timmer001 Engines 6 Sep 20, 2011 07:13 AM
