This thread is privately moderated by iannybeany, who may elect to delete unwanted replies.
Old Jun 15, 2012, 10:35 PM
iannybeany is offline
Find More Posts by iannybeany
Australia, NSW, Alstonville
Joined Jan 2012
Revival of preloved Glider.
Some 40 years ago a very good friend Wayne Hadkins gave me a glider that I have flown only several times that we launched using a catapult made from surgical tube as shock cord was harder to find and more expensive. I launched this glider some weeks ago using the same catapult and found much to my surprise that the wing tips folded into and touched each other resulting in the plane falling out of the sky in a spin and crashing tail first. The tail was quickly repaired but replacing the broken brass tubing and refitting the spring steel wing rods took a little longer but with the magic builders bog you wouldn't think it had broken.
Today with an electric motor fitted to the once sleek balsa nose it will again roam the skies taking in the views of our beautiful countryside...I hope to have a camera there to record the launch and if Matt turns up with his mounted camera plane we might get a few arial shots of her flying as well.
I have the youtube "Test Flying Ian's EP glider build" not sure if this will link you but i will try it
Test Flying Ian's EP glider build (6 min 52 sec)
you can search using the Test flying bit in Youtube and comes up. We have a great flying field. Not officially a flying field but it works.
iannybeany is offline Find More Posts by iannybeany
Discussion Reviving a dead Lipo stockman20 Batteries and Chargers 42 Feb 15, 2016 10:15 AM
Discussion EZ Laser 200 - reviving DYORD The Builders Workshop 7 Jun 13, 2012 09:56 AM
Discussion Reviving JR 783 for 2.4 w4yn Radios 0 Jun 05, 2012 07:24 AM
Discussion 808 taken a bath i and way way to revive? fishycomics Aerial Photography 1 Mar 23, 2012 07:36 AM
Discussion Reviving an old Hyper 7 or getting a new knfevg Off-road Cars 5 Oct 25, 2011 07:34 AM
