Old Jun 15, 2012, 08:48 PM
GreenAce92_v2 is offline
Find More Posts by GreenAce92_v2
Euphoric flights
GreenAce92_v2's Avatar
United States, NY, Buffalo
Joined Aug 2011
Non-computer radio mixing
I wanted to know if this mixing (by wire) that I had in mind would work
This is for a four servo flying wing which requires all four servos for turning and only the back two for pitch.
This is for radios that do not have mixing.
I am just wondering if my wiring schematic would work.
The signal depiction is only for clarification not actual like pulse modulation as I don't know how that works.
Can someone check this over, especially when you are climbing and banking (mix of both controls).
I fear that it isn't possible.
p.s. each connected wire is parallel wired as in red red, black black, yellow yellow
GreenAce92_v2 is offline Find More Posts by GreenAce92_v2
Old Jun 15, 2012, 08:55 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
If the question is if you need a computer radio to fly a flying wing, the answer is NO! You can do like some full-size planes and use outer surfaces as ailerons and inner ones as elevators. The Horten wings were done this way, as was the XB-49 I believe.
One thing you DO want to have is differential on the ailerons. You definitely want the inside aileron deflecting higher up than the outboard one goes down. This is easy to accomplish mechanically by not using the control horns and servo arms parallel at neutral.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jun 15, 2012, 09:03 PM
Euphoric flights
Joined Aug 2011
I forgot to mention this; my computer radio was sent in so I only have analog radios
Also specifically my gull wing flying wing has flaps deployed on take off (6 moving surfaces)
So it is rather advanced
In order to avoid a small niche of operations by requiring an advanced radio, I sought after an analogue solution.
If further interested I can show you a video of my control surfaces.
Thank you for that vital piece of information regarding deflection though I don't completely understand that last paragraph?
Old Jun 15, 2012, 09:12 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
In flying wings especially you generally need to have more drag on the inside aileron to provide the yaw for turning, and because of the lower relative airspeed. You get the yaw by differential. Differential is having a different mechanical throw for the same input signal from the stick (ie, you can use a Y harness).
To do this mechanically, you start with the servo arm in a more "down" position (if your horns are on top of the wing, then the servo arm tip is closer to the control surface). As the servo pushes the arm away, it quickly reaches a point of little travel for a large angular rotation (simple geometry). When the servo pulls for up, it has lots of travel before it reaches the same point.
Is your radio gone for a long time? Changing linkages for differential is a lot of work for a short-term outage.
I'd be interested in seeing your model. I really like models of birds!
Andy
Site Sponsor
Old Jun 15, 2012, 09:18 PM
Euphoric flights
Joined Aug 2011
Ok I am going to draw models in paint to see if I understand what you are describing.
See my gull wing flying wing is unique. The top view geometry of the wing allows flaps to be installed on the wing so I am not sure if I can implement the yaw aspect.
Are you saying that having this differential is a mix of both yaw and bank?
(Rudder aileron mix) ?
My model is designed for and classed as "Unlimited Sport" rolls on axis, insane exponential climbs (by use of flaps) high speed operation and super slow flight (flap landing).
Yes my radio is gone for like two weeks, however a friend of mine offered me to use his radio. Still I am interested in implementing your suggestions for better overall performance.
Old Jun 15, 2012, 09:43 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
I'm downloading the videos you sent. They take forever as I don't have a high-speed connection out here in the boonies. I'll have to get back to you.
Experiment on paper with the geometry. The goal is to see more upward deflection for the same angular rotation.
Andy
Site Sponsor
Old Jun 15, 2012, 10:08 PM
Euphoric flights
Joined Aug 2011
"In the boonies" haha
Why don't you steal some internet, decry pt the signal from satellites
Thanks for looking into it.
Still I am curious
Here is an image of more confusion
Additionally: Perhaps this is getting more advanced but even at this scale, should one taper the profile with swept wings?
Also in regards to high speed flying, currently I fly with fully symmetrical airfoil but I can't help but think to add wash, though I fear that the camber may cause problems with opposing angles of attacks (due to the bends "Gull Wing" )
Also for speed runs, I feel like the model would want to balloon if it had any camber.
Old Jun 15, 2012, 10:20 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
You need a reflexed airfoil. There are non-reflexed flying-wing airfoils, but they aren't going to be good for what you're trying to do.
Over on the Builders Forum you might find better advice. There's a guy BMatthews there who is very helpful and very experienced.
Andy
Site Sponsor
Old Jun 15, 2012, 10:42 PM
Euphoric flights
Joined Aug 2011
Well thank you very much for your help.
Old Jun 16, 2012, 07:46 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Your picture is "about right " conceptually.
A flying wing -like a flying anything- has to have something which keeps it pointed in the right direction
A flying wing is nothing more that an exceedingly short moment craft
(Imagine a Piper Ccub then visualize the tail moving forward till it is touching the wing
Same rules apply but now on the flying wing -you need MORE forces because the moment arm (distance) is much shorter .
This is why the reflexed airfoil - either built in or done via moveable surfaces -is a must.
without it -the wing has no force to hold it at the desired angles of attack
- next slide please -
richard hanson is offline Find More Posts by richard hanson
Old Jun 16, 2012, 08:58 AM
Euphoric flights
Joined Aug 2011
Can't a wing without reflex fly just because it is balanced "neutrally" ?
In the sense that you fly by "angle of attack" as in, the profile is flat, pop elevator a bit to change angle/datum line then aircraft continues to fly at that angle from power of the motor.
By angle I mean new incidence / angle of attack on a fully symmetrical airfoil "plank type wing" so sweep doesn't help with increasing moment arm.
Old Jun 16, 2012, 09:28 AM
Joined Oct 2007
Not very well is the answer as it simply has no stability .
It will glide depending on the cg and power will change climb /dive
you really need an opposing force which can be trimmed to stabilize it
IF one had a super computer which would constantly twiddle control surfaces - it would work
The super fighters have tailplanes which can be seen to constantly move to deliver smooth flight - same thing here .
Some of the little new Bind n fly models from Horizon have accellerometers on board which constantly correct minor inputs and smooth out setups which make these models too sensitive for many flyers -terrific setups!
Old Jun 16, 2012, 10:01 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
I recommend you read one of these books:
Model Aircraft Aerodynamics by Martin Simons http://carstensbookstore.com/moaiaebymasi.html
Gliding with Radio Control by Martin Simons http://carstensbookstore.com/glwiracobyma.html
RC Model Airplane Design by Andy Lennon http://www.amazon.com/R-C-Model-Airp.../dp/0879382384
I recommend them in that order.
Andy
Site Sponsor
Old Jun 16, 2012, 10:20 PM
Euphoric flights
Joined Aug 2011
Thank you for the excellent recommendations.
Thanks for all of the responses.
p.s. I thought that the 6th generation fighters are terrible?
I understood what you were referring to but it seems that giving up longitudinal stability (positively stable from geometry and aerodynamics is what I mean) for agility seems like a bad idea. Although I wouldn't think of an F22 as an "efficient" design, it's like a rocket. Not literally but short stubby wings, vertical climb that sort of deal.
A high speed flat airfoil acting like a dive plane on a submarine.
Old Jun 17, 2012, 07:52 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
If you have a computer to fly the airplane for you (ie, to stabilize it) then you aren't giving up anything, only gaining agility.
And with the right CG, they are docile: http://www.montanadesign.com/planes/
Andy
Site Sponsor
Question Using mixes on a computer radio for ornithopter flying keithm Ornithopters 5 Apr 27, 2012 05:19 AM
Discussion computer radio necessary baldy1953 3D Flying 2 Feb 26, 2012 04:04 PM
Discussion Control Surfaces Mixing vs Non-Mixing derrick_chi UAV - Unmanned Aerial Vehicles 4 Nov 30, 2011 10:11 PM
Help! T-rex 450 and an old JR non computer heli radio ??? Aero12 Electric Heli Talk 2 Nov 09, 2011 03:19 AM
Question BCPP non linear tail mix on stock radio MadMorgan Micro Helis 0 Aug 29, 2007 05:59 PM
