Old Aug 08, 2012, 12:31 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Not open source!
jalves is offline Find More Posts by jalves
Old Aug 08, 2012, 12:57 PM
muerzi is offline
Find More Posts by muerzi
Joined Jan 2011
Jalves.
I got your mail. I will try to integrate a function to auto-set the bit positions.
In next steps i'll also build a routine to auto-adjust the delay before reading from the analog comparator
muerzi is offline Find More Posts by muerzi
Old Aug 08, 2012, 01:10 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
muerzi,
Did you read my questions in the mail?
Old Aug 08, 2012, 02:17 PM
muerzi is offline
Joined Jan 2011
I read your mail yes.
I think your problem is that the bit-positions are not set correct. You can also try to point your cam at a black background
Old Aug 14, 2012, 02:28 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Muerzi any news?
msev is offline Find More Posts by msev
Old Aug 24, 2012, 11:09 PM
mattthomas78 is offline
Find More Posts by mattthomas78
Crash test dummy....
mattthomas78's Avatar
United States, TN, Waynesboro
Joined Mar 2012
I'll be coming back here again!!
mattthomas78 is offline Find More Posts by mattthomas78
Old Aug 26, 2012, 04:25 AM
muerzi is offline
Joined Jan 2011
As jalves had problems (think the bit positions are not right) i'm working on a code which will put a testpattern on line 6 every frame that the arduino can adjust the positions himself.
Though this process can run this way: osd puts in line 6 a testpattern. At the groundstation you press a key, and the arduino reads out the correct positions where the bits start. The pattern will be 10101010 10101010
Any other idea about this?
Had a job change this month and very less time.
Hope i'll release the code within 2weeks
Old Oct 04, 2012, 12:57 PM
msev is offline
Joined Sep 2010
So whats up this thread is a bit quiet?
Old Feb 27, 2013, 12:27 AM
muerzi is offline
Joined Jan 2011
Are there still some people interessted?
Old Feb 27, 2013, 02:28 AM
msev is offline
Joined Sep 2010
Yes I'm interested, but now a better osd to integrate this would be Dennis Frie's Max osd, since it has more system resources available for program space. Take a look here: http://www.rcgroups.com/forums/showthread.php?t=1776186
Dennis is developing it a lot, that lm1881 based one is not being any more developed.
Old Feb 27, 2013, 09:06 AM
muerzi is offline
Joined Jan 2011
Ok, looks nice.
But for that we need an idea how to ouput the data in the hidden video lines. Max7456 is not doing it. Also we need to grab the hsync and vsycn for counting lines that we know when to ouput the data.
Any other ideas?
Old Feb 27, 2013, 10:33 AM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Originally Posted by muerzi View Post
Ok, looks nice.
Any other ideas?
Start without going into the VBI lines space.
Do like the ikarus OSD that it inserts the data in the side on the image.
The space consumed is minimal.
Example:
Ikarus OSD primer vuelo (4 min 10 sec)
IceWind is online now Find More Posts by IceWind
Old Feb 27, 2013, 11:32 AM
muerzi is offline
Joined Jan 2011
Nice.
Thought about making special characters for the bits 1 and 0 and show them in the first or last row or the visible picture. Can be also very small, and you can also play the data if you play the video again. Will try to post a photo
Old Feb 27, 2013, 11:37 AM
IceWind's Avatar
Joined Feb 2005
Yeah, the advantage of this system is that the data is always recorded with the video. (most codecs or devices strip out the VBI space).
Making easier to implement some other app to extract the data.
Old Feb 27, 2013, 02:54 PM
msev is offline
Joined Sep 2010
Ok, looks nice.
Any other ideas?
Maybe you should contact Dennis Frie, he will probably give you some good idea.
Build Log Opensource frames design files! DexterIt Multirotor Talk 5 Apr 26, 2012 08:42 AM
