Joined Jan 2011
Thanks. Looks better than mine...
Will try to adjust the poti. Today i will try to build the OSD like the SimpleOSD by Flytron. Maybe with the LM1881 the detection of the newline sync is better than with the diyosd osd method with the analog comparator, and i hope the letters will be more stable.
Joined Jan 2011
Jalves:
Have you edited the settings in the code correctly for the diyosd? What voltagesource are you using? A lipo, a BEC or a stable voltagesource? Are you sure there are no other misstakes you made? You can also try to replace the 680k resistor with a 710k resistor on the rst pin of the lm1881 |
Haifa, Israel
Joined Nov 2009
The the last image looks as dimming does not work (not connected or disabled by software). |
| Thread Tools | |
| Build Log Opensource frames design files! | DexterIt | Multirotor Talk | 5 | Apr 26, 2012 08:42 AM |
