This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Old Jun 15, 2012, 08:59 AM
unclegeorge is offline
Find More Posts by unclegeorge
Trader Rating: 251
United States, FL, Sarasota
Joined Feb 2005
Trader Rating: 251
Sold
NIB-PTE 36CC Gas Engine $279 buy 2 for $250 Each +S&H
I have several NIB PTE-36CC Gas engine for $279. New cost $298!!! (S&H $12.00 Priority Mail)
Buy two Engines for $250 each plus S&H of $12.00 Each.
The PTE36 is the best engine in its class. You can use the same prop, fuel, ambient conditions, spark plug, etc. s the DLE 30! Note: The PTE-36 uses the same engine mounting pattern and same prop bolt pattern as the DLE-30.
The PTE36 is the smoothest, most powerful, and easiest to start.
The main advantage is that it is rear exhaust! On narrow cowled planes like the P-40, P-51, Spitfire, etc., there’s no cutting a hole through the side of the cowl. You don’t spoil the looks of your plane. I always hate cutting the shark’s mouth out of P-40’s cowl for the side exhaust muffler - what a sin! This engine is awesome. It used a Walbro carb, no imitation! It uses an iridium plug which is better than the NGK-CM6 (though the NGK-CM6 will work also).
The bearings are the highest quality of any Chinese engine – they are true Japanese NSK bearings. All the components are top quality which is what makes it run so well and last for a long time.Note: The PTE-36 uses the same engine mounting pattern and same prop bolt pattern as the DLE-30.
Ignition: PTE have their own ignition. It works very reliably. It operates on a wide variety of voltages 4.8 - 7.2. Use 4 and 5 cell Nicad or NiMh without a regulator. Use LiFe without a regulator. With LiIon or LiPoly, use a regulator set at 7v or less. There is no improvement in performance with higher voltages, so don’t use them. There is no warranty on ignitions because if they see more than 7.2v, they can fail. Use a heavy duty switch due to the high current. A 1400 mah battery is good for 6 flights or more. I typically use a 2600 mah LiIon battery which will last for a weekend of flying on a single charge.
Specs:
Displacement: 36CC
Bore x Stroke: 38*32
Carburetor: Walbro
RPM Range: 1350-9000RPM
Ignition: DC 4.8-6 Volts (made by Pterodactyl)
Fuel mixture: 25-50 : 1
Propeller Recommendations:
Break in: 2-blade: 18x8 (5+ gallons)
Broken in: 2-blade: 19x8 - 20x6
3-blade: Biela 16x10 - 17x10
4-blade: Biela 16x8 (Mustang/Warbirds)
Engine warantee work can be handled at:
Ibcinyou/rc,P.O Box 432044,St. Louis, Missouri 63143
Please give me your mailing address and please help me keep track of you order by typing in the item you are buying in the “Subject line” along with your mailing address in your Pay Pal purchase.
My account in Pay Pal is under uncgeorge@comcast.net
Uncle George
unclegeorge is offline Find More Posts by unclegeorge
Sold NIB-9CC Gas Engine the same size as >40 Glow Engine! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 25, 2012 10:19 AM
Sold NIB-Price Reducded- PTE-36CC Gas $249 unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 3 May 19, 2012 01:25 PM
Sold NIB PTE-36CC Gas $269 unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 3 May 15, 2012 03:43 PM
Sold US Engines NIB 41cc (2.5 cu in) gas engine. REDUCED !! puplover Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 15, 2011 01:41 PM
Sold PTE36R 36cc gas, rear carb and rear exhaust ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 26, 2011 08:42 AM
