Old Jun 15, 2012, 06:55 AM
kingkyle is offline
Find More Posts by kingkyle
United States, NJ, Kinnelon
Joined Jan 2011
Build Log
Quest for 200mph EDF carbon dart
I've decided to scratch build something fast. Or atleast attempt to. The idea is to build a delta shaped really low profile / drag dart shaped 90mm EDF.
Rough specs:
36" Wing span
48" length
Pink foam fully covered in carbon fiber cloth using wet layup with West Systems.
90mm Wemo
ARC 36-75-1.5
12s
11.5 lbs of thrust
goal weight of 5.5lbs
GOing to need some serious thinking about CG because the calculator doesnt show the front section.
Rough shape
vertical stabs came out awsome, so strong I cant even flex them. I'd say 10 times stronger than a fiberglass setup maybe 50% more weight
kingkyle is offline Find More Posts by kingkyle
Old Jun 15, 2012, 06:57 AM
kingkyle is offline
Joined Jan 2011
Here is my fastest plane do date... not an EDF but you get the point
Funjet Ultra ARC 36/65 motor (0 min 35 sec)
Old Jun 15, 2012, 08:14 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
My question is what tx/rx are you using that isn't affected by the CF.
Check this out, might be something usefull in there.
http://www.rcgroups.com/forums/showthread.php?t=1507491
Mark
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 15, 2012, 08:53 AM
kingkyle is offline
Joined Jan 2011
Mark
I use a full range Spectrum steup, never knew carbon caused issues, i'll mount the sattelite outside the fuse if I have an issue.
Old Jun 15, 2012, 09:09 AM
Joined Dec 2008
I knew there can be issues with CF. I don't know enough about it yet to know how much it too much. I want to put some in my F-86F, so I need to find out soon myself. I do know that on a 2.4 system the antenna can't be in line with it. Good Luck
Old Jun 15, 2012, 06:59 PM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
Carbon fiber has been known to absorb radio waves.
I noticed you are using a very heavy weave. Around 5.75-6.0oz. Why?? Even for 200mph is a bit much. Plus you are using a higher density foam.
To eliminate the weave look, it will become even heavier. Creating even more load on the airframe.
Proper composite sizing is a balance between what will work and what just adds weight.
Just my thoughts.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Jun 15, 2012, 07:45 PM
kingkyle is offline
Joined Jan 2011
It's really not heavy. I couldn't find lighter carbon cloth. I could have gone with fiberglass but I'm going outside the box. The airframe has no spar of any kind. The foam weighs next to nothing yet it's like steel. I'm not going to make it smooth, I'll try the golf ball dimple method
Top layer done
Old Jun 15, 2012, 11:06 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
freakin crazy man...can't wait to see that fly !!! nice work
KCinNC is offline Find More Posts by KCinNC
Old Jun 15, 2012, 11:55 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
that looks like #582 C/F typially used for car hoods these days.a plan weave 3.6 oz C/F would be better.the composite store has it cststore.com is there e-mail i think. ...not sure the golf ball dimple thing will work ......no full scale plane have used it .who know you might be on to somthing.i think if you get close to 200 all the dips low spots are going to cause proplems ....it's going to take a ton of power to get close to 200 ."Knifelittle" tried it a few years ago ...i cant remeber if he made it or not.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jun 16, 2012, 07:00 AM
kingkyle is offline
Joined Jan 2011
thanks for the info, I've been looking for lighter weight cloth. I've been using http://www.jamestowndistributors.com...Plain+Weave+3K
If I could cut the cloth weight down, its the perfect material because it needs no reinforcements at all in the foam. This is really just a prototype to see how it fly's on 6s first, work out the bugs and then build a second one for 12s possibly go to EffluxRC for a hot 90mm 12s setup.
Old Jun 16, 2012, 09:12 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Foamular 250 isn't heavy. In fact it's quite a bit lighter than the commonly used Dow blue foam. I think the cloth you used is ok. I have been using up a roll of it for years because it was really cheap compared to fabric made with 1k tow.
Where you can really improve next time is by vacuum bagging. When you lay up composites out in the open like this, you end up using way too much resin and you still need more to make it smooth. Take some time and learn about using vacuum with mylar for parts without compound curves, like the wing. You can squeegee the cloth out on the table first, on top of some plastic and then pick the plastic up with the fabric and flip it over on top of the foam. Peel the plastic off and smooth out.
BTW, the homebuilder guys mix up a slurry of resin and micro to squeegee out on the foam first. If you have sanded the foam, it can end up absorbing resin, so this seals it up with stuff that is lighter than straight resin.
Good try. I could have helped a bit more if you posted when you first started, but that's okay. I learned a lot by trial and error when I started messing with composites. No internet back then and people who knew this sort of stuff didn't like telling others too much about it. Lots more sharing going on these days!
Steve C is offline Find More Posts by Steve C
Old Jun 16, 2012, 09:25 AM
Joined Dec 2008
Foamular 250 is great stuff. Most of what we have up here in MN is the 25# density. And we have lots of it, ALL year long. Weird trade off, you can't get it, but can fly year long! We have foam all year long, and can only fly for a few months. BTW, Foamular is very nice to hot wire!!
Old Jun 16, 2012, 09:50 AM
kingkyle is offline
Joined Jan 2011
Thanks Steve! yes I wish I had someone to teach me vacum bagging. It really is the best way to do it. I could save like 100g of resin on a 600g total weight airframe as it sits right now. Do you know of any good vacum bag kits that are sold? even for small parts so I get the concept first then I can make it on a large scale.
Old Jun 16, 2012, 09:51 AM
kingkyle is offline
Joined Jan 2011
Yeah other than the mess it makes carving and sanding, this foam is perfect and I get it in 8x3 ft boards at home depot for $9
Old Jun 16, 2012, 10:30 AM
Joined Dec 2008
Sounds like a good price. Here the 2"x 4'x8' sheets of foamular 250 are about $23 and change. Have a Menards just a 1/2 mile away. Need a touch more bondo for my plug, so I suppose I HAVE to go there later!
Build Log Quest 200mph, Q-2.6....sketckes of a twin 90mm Knife Liddle Electric Ducted Fan Jet Talk 1287 Sep 18, 2015 07:25 PM
Question Ultimate Speed Jet for EDF 90mm? (+200mph) eJets Electric Ducted Fan Jet Talk 7 Oct 09, 2008 02:46 PM
Sold Carbon Mach Dart, heavily modified for ds, pics added Bill L Aircraft - Sailplanes (FS/W) 1 Jun 09, 2008 08:45 AM
Micro Edf Design the Quest for the Holy Fan aerogel Scratchbuilt Indoor and Micro Models 51 Aug 13, 2005 05:31 PM
Quest for an ideal EDF airfoil olmod Modeling Science 0 Mar 27, 2005 10:48 AM
