Old Jun 15, 2012, 04:19 AM
brw0513_2 is offline
Find More Posts by brw0513_2
Joined Dec 2006
Idea
Spinning Direction - Spark Ignition Engine
Not sure if I'm dreaming or not so need some advice.
I have a model helicopter project in mind. It will be powered by the new OS GT15HZ gas engine when it becomes available:
http://www.os-engines.co.jp/english/...newsgt15_e.pdf
For my application, I really want to run this engine "backwards" i.e. have the crank turning clockwise when viewed from the front rather than the conventional anti-clockwise direction.
Is it just a matter of repositioning the timing magnet to the equivalent location before TDC and spinning the engine clockwise to start?
Any lessons someone can help me learn cheaply?
Good advice appreciated.
brw0513_2 is offline Find More Posts by brw0513_2
Old Jun 15, 2012, 04:44 AM
Patxipt is offline
Find More Posts by Patxipt
engine-a-holic
Portugal, Lisbon
Joined Jun 2007
Unfortunately not. The intake is timed on the crank, so unless you had a way of rotating the carb 90 to the side of the silencer, like on Enyas, or a rear carb intake like the GT33, on this engine, you're out of luck.
Are you thinking of a Chinook to model?
Patxipt is offline Find More Posts by Patxipt
Old Jun 15, 2012, 07:47 AM
Joined Dec 2006
I'm intending to put the GT15HZ into a Henseleit TDR airframe.
Thanks for the quick reply.
Old Jun 15, 2012, 08:07 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
In looking at the pics of the engine, it cannot be run in reverse, unless you have a reverse rotation crankshaft made for it. I doubt OS will make one too, but you never know. The crankcase is a one piece design, so you cannot rotate the carb 90 degrees to set it up to run in reverse. Of course you'll have to retime the ignition for reverse rotation too.
earlwb is online now Find More Posts by earlwb
Old Jun 15, 2012, 11:07 AM
Reginald is online now
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Indeed. Some makes did have clockwise crankshafts. Like Webra. I used one of these on a Marutaka P-38 in the 70'ies. Like earl says, with an engine that has a detachable front one can rotate it to have clockwise running.
Reginald is online now Find More Posts by Reginald
Question Asp FS91AR with spark ignition Georgseema Engines 17 Oct 23, 2012 03:48 PM
Discussion Glow engine, spark ignition Brutus1967 Fuel Heli Talk 2 Oct 23, 2012 12:41 PM
Off Site Siedel 7 cylinder Gasoline Spark Ignition 250CC Radial RC Airplane Engine icharus Aircraft - Fuel - Engines and Accessories (FS/W) 9 Apr 22, 2012 01:24 PM
Sold C&H Synchro-Spark ignition system needacheaphobby Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 01, 2012 10:03 AM
Help! Identitifying old spark ignition motors modlflr Engines 4 Sep 21, 2011 06:25 AM
