Old Jun 15, 2012, 02:11 AM
glouis is offline
Find More Posts by glouis
glouis's Avatar
Ireland, Dublin, Howth
Joined Nov 2008
changing mode on a Futaba T6J to sheet on left ?
Hi, do any of you know if it is possible to change the mode on a Futaba T6J ? One tx I am looking to buy has the "throttle" on the right but I am used to sheet in-out with my left hand. Is it possible to change that mode or is it set by the manufacturer ?
Cheers,
Gilbert
glouis is offline Find More Posts by glouis
Old Jun 16, 2012, 08:55 PM
skipper67 is online now
Find More Posts by skipper67
Neptune, New Jersey
Joined Nov 2010
Just plug your rudder servo into the 3rd channel on your receiver. That will make the steering on the left stick.
skipper67 is online now Find More Posts by skipper67
Old Jun 17, 2012, 10:37 AM
chilisoling50 is offline
Find More Posts by chilisoling50
Joined May 2007
If I am not wrong the set up you have now is called Mode 1 with throttle on the right .
What I have done to change mine to mode 2 is by opening the back of the cover and remove the spring from the left side and put it back on the right side. This way the rudder will still have the spring actions( return to neural position after you push it once) and while the left stick is just sliding up and down.( becarefull which spring to remove_, you need to remove the spring that dictates the up and down motion of the stick ( for sheets pull in and out ) not the other one which control the horizontal motion one.
You will see a piece of ratchet at the right side now above the stick drum .
Just put it on the left side so it will do the same as before on the right side before).
If there is no Futaba ratchet there already. Yo can make one or buy it from Tower Hobby.
Good luck.. I do the same for all my Hitec Radio transmitter.
chilisoling50 is offline Find More Posts by chilisoling50
Mini-HowTo Futaba 9VAP - Accessing the Service Menu, Lithium Battery replacement & mode change quincross Radios 20 Jun 28, 2016 10:29 PM
Help! how to change mode pcm to ppm futaba ff8 super!!!! bravo122 Radios 1 Mar 09, 2012 03:15 AM
Discussion Possible to change from mode 2 to mode 8 in flight? DX8 Rooster433 Radios 2 Feb 29, 2012 08:48 AM
Help! Channel 6 and 2 on Futaba T6J matphlox Radios 2 Feb 08, 2012 01:52 AM
