Old Jun 15, 2012, 01:41 AM
wc_wickedclown is offline
Find More Posts by wc_wickedclown
United States, CA, Signal Hill
Joined Aug 2009
whats the maximum main blade pitch for the align trex 450 v2
please and thank you
wc_wickedclown is offline Find More Posts by wc_wickedclown
Old Jun 15, 2012, 03:33 AM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Depends on how you want to fly, the rotor rpm, blade length, and how much power the motor, esc, and lipo can provide. Most casual flight is under 9 degree's pitch, you can get most 3D manuvers with 12 degree's, and all out crazy stuff might take as much as you can give it without binding, and bogging it down. To much pitch can also cause the blades to be past the most efficient angle. You can tell when your past the most efficient angle from the blade sound, and the helicopters performance. When checking for binding you need to add the cyclic pitch to the regular pitch. You do this by moving the transmitter cyclic stick to each corner, and the throttle/pitch stick to the top, and bottom of its travel, while checking for binding.
Roto Rob is online now Find More Posts by Roto Rob
Old Jun 15, 2012, 03:50 AM
Joined Aug 2009
thanks rob
im wanting to do some mild 3d tic tocs etc but watch this video the bird is using a scorpion 6 the head speed sounds good but it flips over to slow.
i want it to flip fast but i dont want it to be to twitchy
i have it at 12- 12+ was at 9+ and 7 neg in this video
you think increasing the pitch like i did will help it a long ?
killer exi 450 inverted nose in mild 3d at the field (2 min 2 sec)
Old Jun 16, 2012, 01:48 AM
Denver, CO
Joined Dec 2005
To do flips, and rolls you need aileron, and elevator pitch. Hard to hear the helicopter because of the music. So you'll have to tell if it was bogging. If so it could be the throttle curve. For 3D about 10 degree's cyclic pitch is fairly good, but will be really close to binding, with the sticks in the corners. I would start around 12 degree's pitch, with around 8 to 10 degree's cyclic. Then back it off, if it bogs to much, or binds. The more head speed you have, the less pitch is needed.
Old Jun 17, 2012, 10:29 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
you also need to remember , if you have , say flying at around 7 to 8 degrees of regular head pitch, adding 6 or 10 aileron or elevator pitch to it will add to 14 to 18 degrees of total pitch .
jombo is offline Find More Posts by jombo
Old Jun 17, 2012, 12:38 PM
Joined Aug 2009
how does this one sound i didnt run it with music so you can here the bird better
if i go over 3000 rpm i get a big growl sound that causes the gyro to go nuts
as long as i dont go over 2900 its ok ill get it figured out one day
happy fathers day tarot zyx DFC low profile head exi 450 nose in landing and lift off practice (5 min 26 sec)
Old Jun 18, 2012, 02:50 AM
Denver, CO
Joined Dec 2005
Sounds like it has plenty of power, and the cyclic looks fast enough to do most 3d.
Old Jun 18, 2012, 01:05 PM
Joined Aug 2009
thanks brother i followed you guys advice and checked and adjusted my cyclic pitch to 7 degrees with 12 degrees of collective pitch gotta test it out today
thank you all
Old Jun 19, 2012, 01:12 AM
Joined Aug 2009
well after 12 degrees pitch and 7 degrees cyclic pitch it still seems like its not gonna roll and flip fast enough maybe some kbdd extreme paddles ?
how is the image quality ? telescopic zoom test killer exi 450 cyclic response test. (6 min 24 sec)
im using 30% expo maybe ill try zero expo in indle up to speed up the rotations
Old Jun 20, 2012, 12:52 AM
rovpilot26 is offline
Find More Posts by rovpilot26
www.scaleflying.com
rovpilot26's Avatar
Humble, Texas
Joined May 2009
One thing to remember is that the -6 motor doesn't have the higher torque of the -8
I've found it's sweet spot for power around 3200rpms, and around 12degrees of collective pitch and 11degrees of cyclic pitch on my fbl 450Pro
rovpilot26 is offline Find More Posts by rovpilot26
Old Jun 20, 2012, 04:10 AM
Joined Aug 2009
thank you
i checked my throttle curve and idle up was at 85 percent
here is a taste of 100 percent it seems much better
wide angle lens test jvc everio HD killer exi trex 450 clone 100% head speed test. (5 min 9 sec)
Old Jun 20, 2012, 01:05 PM
www.scaleflying.com
rovpilot26's Avatar
Humble, Texas
Joined May 2009
Awesome!
Old Jun 20, 2012, 01:10 PM
Joined Aug 2009
you guys think if i used less expo it might flip and roll faster ? i should i increase the dual rate ?
Old Jun 20, 2012, 01:12 PM
www.scaleflying.com
rovpilot26's Avatar
Humble, Texas
Joined May 2009
Less expo, and also increase the cyclic pitch range. Just make sure that there is no binding in the corners
Old Jun 24, 2012, 11:56 PM
mattox is offline
Find More Posts by mattox
mattox's Avatar
peoria,az
Joined Sep 2009
just let me play with it a day and itll be the fastest thing you ever seen.
mattox is offline Find More Posts by mattox
Discussion Which 450 - Blade 450 or Trex 450 Sport V2 damiens75 Electric Heli Talk 27 Nov 15, 2011 03:09 PM
Wanted Tarot Flybarless Main Grips for Trex 450 PRO V2 norstaroption Aircraft - Electric - Helis (FS/W) 0 Oct 28, 2011 09:32 PM
Discussion Main Blades for Trex 450 Pro? juribe2 Mini Helis 4 Sep 16, 2011 08:02 PM
Wanted Align Blade grip Trex 450 V2 GCchoppers Aircraft - Electric - Helis (FS/W) 0 Aug 14, 2011 08:01 PM
New Product 325mm Carbon main rotor blades for Align Trex 450 Qianlong model Product Announcements 0 Nov 12, 2008 09:41 AM
