Old Jun 14, 2012, 11:30 PM
Felix the kat is offline
Find More Posts by Felix the kat
Joined May 2012
Futaba T8J and Flymentor
Recently changed TX and receivers on one of my 450's with Flymentor installed.
With the other TX /RX it worked flawlessly.
Now with the Futaba T8J the flymentor displays glitching on the elevator servo, aileron and pitch are sluggish.
I know it's not the Futaba TX RX since they have been tested with my other birds, and BTW the T8J is VERY good.
This radio does provide for three axis support (FBL) and I've dialed it down to zero on the ail and elev. with no luck. The swash is set at H-1, same as normal, 90 degree or one servo swash. They're all the same thing (no mix swash, as required for Flymentor to do its own mixing). Servos, motor, battery and ESC are OK. ..................................Pretty sure it's a radio setup issue, the thing is where?
Has anyone else had this problem? Any help will be appreciated.
Felix the kat is offline Find More Posts by Felix the kat
Old Jun 15, 2012, 11:10 PM
Joined May 2012
Nevermind
Had forgotten how unforgiving Futaba can be to the servos. It was ONE glitchy servo whom tested out fine just two days ago. It was throwing the whole thing out of sync. Replaced the servo and it's OK now.
Rave Futaba T8J S-FHSS Mikarro Radios 268 Oct 04, 2013 07:10 PM
Discussion Flymentor 3D configuration for Tricopter sleper UAV - Unmanned Aerial Vehicles 3 Apr 16, 2013 04:59 PM
Discussion Who have tried the futaba new T8J? cola2cool Radios 2 May 15, 2012 06:21 PM
Discussion Futaba T8J angelotti Radios 1 Mar 23, 2012 12:13 AM
Help! Kds flymentor x trex 450 x futaba 7c claser 3D Electric Heli Flying 11 Jan 06, 2012 03:01 AM
