Old Jun 20, 2012, 09:02 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Put a light layer of FG on and you've got a composite plane. Noone can tease you for flying a foamie. LOL
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jun 20, 2012, 09:09 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I'm in also!
Bob
bruff is offline Find More Posts by bruff
Old Jun 20, 2012, 09:37 PM
mike2663 is offline
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Originally Posted by sam51401 View Post
Lets get the basic stuff first then we can work on the finer details. Fahim does offer a vacform cockpit already for his A-10 which Keith makes and supplies to him.
Yea, Fahim and Keith are already a team on those parts!!!!!! They have already been working back and forth on each others kits and such for some time. I even think Fahim is cutting Keiths MD80 project and a B757
Join the Foam Revolution!!!
I'm just pre planning here.
mike2663 is offline Find More Posts by mike2663
Old Jun 20, 2012, 10:45 PM
awrightbrother is offline
Find More Posts by awrightbrother
Wowplanes.com
awrightbrother's Avatar
Florida
Joined Nov 2007
I agree with Sam, lets stay focused and lets stick to basics for now, the bells and whistles can always be added later. Making molds and pulling plastic costs time which translates to money as you know?
My kits are designed for builders, and I assume you are all builders. My objective is to provide a basic platform, as scale as possible, that goes together very easily. Then you guys have to put on your creative hats and add/subtract to it. I will cut the parts and document how to assemble them and how to get a finished frame. You don't always have to follow my build exactly, if you have a better idea. Share it with us all.
Fahim
awrightbrother is offline Find More Posts by awrightbrother
Old Jun 20, 2012, 11:24 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Originally Posted by awrightbrother View Post
I, lets stay focused and lets stick to basics for now, the bells and whistles can always be added later. Making molds and pulling plastic costs time which translates to money as you know?
Fahim
Right on..!!!
Basic airframe only....good job. !!!
The individual can glass it if he wants to or keep it foam if he wants to..more options that way.
falcon5 is offline Find More Posts by falcon5
Old Jun 21, 2012, 01:25 AM
eaticus is offline
Find More Posts by eaticus
eaticus's Avatar
Everett, WA
Joined Aug 2002
OK folks, I have read thru all your comments, and it looks worthwhile to do a 72 incher with the cost analysis posted by erh7771.
But I have one last question. The kit price will be in the $150 range which would put the finished cost around $550, that meets the $400 to $600 finished cost you were hoping for. How many of you are still interested?
Fahim
I am in!
eaticus is offline Find More Posts by eaticus
Old Jun 21, 2012, 08:15 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Fahim
I am thinking of buying 2 kits...
How much LS\SS do you think it would need to cover it?
For inspiration here is a smaller 68" F18 twin 90 foam based Haoye F18....notice how the plane can slow down because wing loading is supper light
Nice in air presence
Haoye F-18 twin EDF jet on two 6S lipo packs (3 min 0 sec)
erh7771 is offline Find More Posts by erh7771
Old Jun 21, 2012, 08:25 AM
erh7771 is offline
Joined Nov 2005
Yes you are correct and a clear canopy...
So a clear canopy comes with it?!
If so, VERY nice...if not will you supply the foam canopy cover so one can do a plastic canopy?
Also, what EPS foam density will you be using for the kit?
If it's the high density small bead then we can LS spray that with a 29usd hopper with the big holes attachment...I've done it before and it comes out as hard as a rock....will make in air time even shorter
Thx in advance
Old Jun 21, 2012, 08:58 AM
erh7771 is offline
Joined Nov 2005
Or if the foam is dense enough 2 - 3 layers of LS2\SS1K can be sprayed or brushed on in less than a couple of hours..
Here are some picks of the 68" foamy KMP F18 redone as a super hornet and glassed with retract mounts
The only thing missing is panel lines...I would love to know how some make panel lines practically.
I'm looking forward to this, seems like a good mid level builders kit seeing the frame is already done.
Old Jun 21, 2012, 10:18 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I have tinkered with panel lines a bit.
For foamies, I found for best results, apply lines before glassing.
I like to use straight edges like a metal ruler. Turn it on its side and press it into the foam and you have one thin indentation that has a nice effect. Turn the edge of the ruler and stand it vertical, this is a perfect tool for making smaller panel lines. I have also found using straight edges on their side is far easier to make straight panels all the way across a wing or up and down a fuse.
Let me know how it works out for ya.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Jun 21, 2012, 10:28 AM
rossaer is offline
Find More Posts by rossaer
Joined Aug 2008
I may have missed the intended power system.....will it be a single fan or two?
al
rossaer is offline Find More Posts by rossaer
Old Jun 21, 2012, 10:53 AM
mike2663 is offline
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Thin chart tape before primer also works. You can either leave it or pull it off. Looks pretty good if you practice.
Old Jun 21, 2012, 11:08 AM
kydawg1 is offline
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
I am in for an F-5 90mm.....subscribed.
kydawg1 is offline Find More Posts by kydawg1
Old Jun 21, 2012, 11:18 AM
delperena is offline
Find More Posts by delperena
Joined Feb 2006
F-5 90mm
Please count me in for one (1)
delperena is offline Find More Posts by delperena
erh7771 is offline
Joined Nov 2005
al
Wide open, it looks like the unglassed weight of those KPMs were like ....6 or 7lbs which would open the model up to twin 70s
We'll know soon, I think a good portion depends on the density of the EPS...
Discussion Is there a 90mm F-5, F-20, or T-38? demetrius Electric Ducted Fan Jet Talk 11 May 10, 2016 12:03 AM
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion T-38 talon/F-5 5" EDF Wingnut31 Foamies (Scratchbuilt) 12 Feb 11, 2011 11:13 AM
Discussion HUGE 6mm F-5 hand cut kit....any interest? corsair nut Foamy EDFs 45 Apr 27, 2008 10:32 PM
