Old Jun 17, 2012, 11:00 PM
sam51401 is offline
Find More Posts by sam51401
Fly more Foam
sam51401's Avatar
United States, IN, Sellersburg
Joined Jun 2004
Here is what i found in the two threads covering the CS 12bl 70 and 90mm fans for FSA as listed in the threads.
70mm= 4.43 sq/in
90mm= 7.88 sq/in
sam51401 is offline Find More Posts by sam51401
Old Jun 17, 2012, 11:25 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
f5 has much larger inlets than a t38
corsair nut is offline Find More Posts by corsair nut
Old Jun 17, 2012, 11:47 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
if the fan was located behind the speed brakes on a T-38 the speed brakes could be set up to move up inside the fuse and let aux air to the fan through some naca type ducts in the bottom of the ducting.good inlet ducts would allow good performance at 85% fsa once up to speed.i think this is the best way to have a scale T-38
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jun 18, 2012, 12:39 AM
awrightbrother is offline
Find More Posts by awrightbrother
Wowplanes.com
awrightbrother's Avatar
Florida
Joined Nov 2007
Transport would not be a problem as Andy says and I agree. The fuse can be built in two parts, the wings can be removable, the V stab can be removable.
If built for 1 fan, it will have to be 90mm.
70 mm would not have enough juice IMHO
If a 90 mm has 7.88 sq in FSA, we are still short at 72" length.
Operating a fan with less that 100% FSA is choking the fan. The airbrake opening can be used as cheater holes, but that causes thrust loss due to turbulence. Kinda defeats the purpose, IMHO
One idea would be for me to find the size where the intake areas add up to 7.88 sq in. That would be the minimum suitable size for a single 90 mm setup. Stay tuned.
awrightbrother is offline Find More Posts by awrightbrother
Old Jun 18, 2012, 12:50 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
we've flown planes with 85% fsa and it went 160 mph .there is some ram effect .if cheater is done with naca type scoops threes not that much turbulance.you could cheat the inlet say 10% and it would still look right . i think a 72-75 inch long fuse would be the better market.
Old Jun 18, 2012, 12:53 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
AS knows his airflow. Go with his numbers and you`ll be good.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 18, 2012, 02:03 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by awrightbrother View Post
At 144" length the each duct intake area was 12 sq in.
At 72" length, the area goes down by a factor of 4 i.e. it will be 3 sq in.
If we use both ducts to feed one 100 mm fan we have 6 sq in feeding a 9 sq in FSA
It won't work
Fahim
Don't use inlet ducting...
Plenty of planes flown with open ducting and intake lip only, easier for you...
After seeing stock Habu keep up with 120s on circuit during fly in I'm convinced 90% of EDF ducting is bad anyway...
erh7771 is offline Find More Posts by erh7771
Old Jun 18, 2012, 02:08 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
dont want to get into a disscussion about ducting .....but i would make plugs and the ducting ,and make them available to those that want ducting.
Old Jun 18, 2012, 08:51 AM
mike2663 is offline
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
I agree. I just don't see modelers jumping all over a 144 inch version. The cost and size would really limit the market. Sure break down would solve the transportation issue but just adds more construction issues.
mike2663 is offline Find More Posts by mike2663
Old Jun 18, 2012, 11:48 AM
sam51401 is offline
Fly more Foam
sam51401's Avatar
Joined Jun 2004
Per inlet!!!!
70mm= 4.43 sq/in
90mm= 7.88 sq/in
I listed the 70mm fan in that it wouldn't be a single 70 but a twin. This way the inlet for EACH fan would need to be 4.43 sq/in and a AIR SALLY duct to route it to the fan.
Old Jun 18, 2012, 11:57 AM
sam51401 is offline
Fly more Foam
sam51401's Avatar
Joined Jun 2004
clarify please
It won't work
Fahim
You have "each" duct or intake would be 12 squares, then refine to a 72" model as having only 3 squares. Is this PER SIDE on just one intake???
If so, then at 72", the intakes would be a combined 6 squares total intake area.
If you enlarge by the using a 20% rule then they would be 7.2 sq/in total intake area for the 90mm fan.
IF, IF you then use the the 85% FSA intake for the 90, this would be 6.69
Old Jun 18, 2012, 01:14 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
I got to thinking about it and whatever size you all decide on I really think this is going to be great!!!! There are Tons of F-16's, F18's, Hawks, etc. out there but you just don't see a good quality mid sized T-38/F-5 for EDF.
Getting Air Sally in on it with his high quality duct lay ups and your gona really have something here...
Yep I think you guys got a winner idea here for sure!!
You can put me on the list for one.
Andy
falcon5 is offline Find More Posts by falcon5
Old Jun 18, 2012, 01:15 PM
rossaer is offline
Find More Posts by rossaer
Joined Aug 2008
hmmm, my vote would be for the smaller sized plane, 12 feet long is a very BIG plane. I understand the "knock down" concept but still wouldn't the larger size be that much more expensive than than a 70" ish size? How about the price difference between 1 90mm setup vs 2 70mm systems? Are they similar? But either way I think I'm in!
The T-38 is my favorite jet after the SR-71.
al
rossaer is offline Find More Posts by rossaer
Old Jun 18, 2012, 02:33 PM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
I am all for a 90mm or larger airframe; I love the design and have been following Falcon's build with amazement.
...the big question is what are these expected to cost (estimations)? Knowing the price point would allow me to tell you if I am a buyer or not.
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Jun 18, 2012, 03:25 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
I think twin 70's is a good idea. The T-38 fuse is wide but not tall/deep. Fitting a single 90mm fan inside will make it quite a bit bigger unless you do a hump like the Top Gun Mig 29 and F-15.
If you want really good performance from a jet, ducting is a must.
Steve C is offline Find More Posts by Steve C
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 10:58 PM
Discussion T-38 talon/F-5 5" EDF Wingnut31 Foamies (Scratchbuilt) 12 Feb 11, 2011 12:13 PM
Discussion HUGE 6mm F-5 hand cut kit....any interest? corsair nut Foamy EDFs 45 Apr 27, 2008 11:32 PM
Discussion Is there a 90mm F-5, F-20, or T-38? demetrius Electric Ducted Fan Jet Talk 8 Jul 01, 2006 11:25 PM
