Old Jun 25, 2012, 11:12 AM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
I built an 81" long F-4 a few years ago and it had a 1.5" thick wing with a NACA 2408 airfoil. AUW was 15.5 pounds and it flew very well as a pusher prop. Here is a pic of the gear wells with a 1 1/8" thick retract unite and a 1" thick wheel for referance.
falcon5 is offline Find More Posts by falcon5
Old Jun 25, 2012, 11:52 AM
awrightbrother is offline
Find More Posts by awrightbrother
Wowplanes.com
awrightbrother's Avatar
Florida
Joined Nov 2007
Originally Posted by rossaer View Post
Just checking in again on the length of this project. Will the jet be able to be "disassembled" for transportation? 81" in length is pushing 7 feet it won't fit in my truck at that length.
Also I like the discussion on how "scale" to keep the project. I'd vote for a slightly thicker wing and larger inlets if it helps in efficiency and performance. As long as they don't become cartoonish, better flying qualities are more desireable than scale looks on the ground....but of course that is just my opinion.
al
This where your building skills come into play. As i said before, these kits are highly modifiable. You can build it such that the nose can be disassembled at the intakes, and the wings come off, or build it as one lump. I will be shipping the fuse in at least 2 sections, otherwise the box size becomes humungous.
awrightbrother is offline Find More Posts by awrightbrother
Old Jun 25, 2012, 11:55 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Fahim,
Just curious as to what drawings you are using for this? I looked at the exact setup that C/N is suggesting a couple years ago and ironically came up with 80" as the fuselage length for a single 90mm fan. Back when I looked at this the figures I came up with for intake area even at 80" length and a single 90mm fan looked a little on the low side for a 100% scale intake. I was planning on a small 3rd duct that would merge with the 2 main intakes just ahead of the fan. This was going to be a full duct though and not a cheater hole. As you have discovered a scale T-38 is a tough plane to tackle. Take a look at this link starting at post number 15. Some pretty nice CAD work there on the T-38. Up until these guys started this project the best drawings were from the DACO book on the T-38.
http://forum.largescaleplanes.com/in...pic=28715&st=0
Steve
SteveC68 is offline Find More Posts by SteveC68
Old Jun 25, 2012, 11:56 AM
Wowplanes.com
Florida
Joined Nov 2007
al
Not to worry, I am not going to sacrifice performance for scale.
Old Jun 25, 2012, 12:03 PM
Wowplanes.com
Florida
Joined Nov 2007
That should fit even a compact SUV or truck. But of course people can build it so it comes apart.
Fahim
Old Jun 25, 2012, 12:09 PM
Wowplanes.com
Florida
Joined Nov 2007
Originally Posted by SteveC68 View Post
Fahim,
Steve
Steve
Yes the T38 is a tough one as I am discovering. I came up with 80.64" for a 90mm so I rounded it up to 81". We are both pretty close.
The ducts are cut at an angle in both the vertical and horiz planes, so we end up with more area than if they are looked at from the front. I was making that mistake earlier on until I realized the cut angles.
Taking that into account the cummulative area of both ducts is 10.8 sq in vs the 8.4 sq in FSA of a 90mm fan.
Fahim
Old Jun 25, 2012, 12:31 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Fahim
Build it were the nose tip comes off and the main part could be less than 72" detached and 81 attached...that doesn't seem like it would be too hard with some wood parts and some wood or nylon screws...
erh7771 is offline Find More Posts by erh7771
Old Jun 25, 2012, 02:22 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
72" is manageable, but sections smaller than 65 inches make it far more manageable for those of us that transport in 4door sedans...
Although like you said, that can be left to the builder to decide
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Jun 25, 2012, 06:15 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
having the nose seperate inbetween the ducts is the best place ,and can be supported on each side by the inlets .spring air 602's and Tams mini retacts would work well in the 1.5" thick wing . both of these can support the weight and are high quality. also when doing inlet cacls i've been told you figure in all the way to the mid point of the radius of the lips .we may have to have a bit bigger radius then scale,as the scale lips are too sharp, but it will suck air cleanly and there will be more than enough FSA . cant wait to see some foam to be cut.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jun 25, 2012, 10:30 PM
Wowplanes.com
Florida
Joined Nov 2007
Since I have to ship the fuse in 2 parts, I have made it separable at the ducts. The Spring Air 602 retracts are perfect. I resell then so that is what I used for the drawing.
I have an idea to make the intake walls thinner than the foam wall. Hard to explain, but will show in the build. We may not need any intake ducting because there is no obstruction in front of the fan.
This design turned out to be more complex than I had imagined. Because of the size, the parts count has gone up and so has the complexity of the cuts.
I am almost there but have one thing I can't seem to figure out. How do I make the stabilator operate. The fuse sides are not parallel, so one rod will not work. If I have 2 rods, then how do we operate each. Any ideas would be appreciated.
Fahim
Old Jun 25, 2012, 10:49 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Something like pillow blocks, with a seperate servo driving each side. Or a single, bent rod operaring both sides, that runs under the thrust tube/bifurcated duct. If its split, I'm imagining a setup similar to what's in my Yellow F-18 single.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jun 25, 2012, 11:12 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
the easiest way for you is to make them work with two servos ....2 strong MG servos will be easier to stuff in there and no need for custom parts.
Old Jun 25, 2012, 11:32 PM
p901P901 is online now
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Elevators supported by these http://www.servocity.com/html/standa...rvoblocks.html would work. HET uses two separate rods to support the elevators. See pictures. These are controlled by 2ea servos.
p901P901 is online now Find More Posts by p901P901
Old Jun 26, 2012, 06:25 AM
mike2663 is offline
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Fahim
Thanks for the update. How is the target cost of $150.00 looking?
mike2663 is offline Find More Posts by mike2663
Old Jun 26, 2012, 08:37 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
fahim, you have to do 2 seperate stab rods, as the F-5 family has anhedral in the stabs. you can still have the pivot line from stab to stab, it doesnt have to be perpendicular to the side of the fuse, just to the centerline of the fuse.
corsair nut is online now Find More Posts by corsair nut
Discussion Is there a 90mm F-5, F-20, or T-38? demetrius Electric Ducted Fan Jet Talk 11 May 10, 2016 12:03 AM
Cool Micro F-5/T-38 Parkflyer Build boingk Pusher Prop Jet Models 2 Oct 17, 2011 09:58 PM
Discussion T-38 talon/F-5 5" EDF Wingnut31 Foamies (Scratchbuilt) 12 Feb 11, 2011 11:13 AM
Discussion HUGE 6mm F-5 hand cut kit....any interest? corsair nut Foamy EDFs 45 Apr 27, 2008 10:32 PM
