Old Jun 14, 2012, 10:23 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
Help!
AR600 AND AR8000 browning out/rebooting, but not blinking?
Ok... so I'm trying to complete a new build airplane. While doing my final servo movement checks, no matter what receiver I put in, it has split second brown outs or complete reboots, .... BUT, while using a TM1000 telemetry module, I notice no voltage drop below 5.9 (6v set). It seems to be okay for the first 10-15 seconds of full throw, multi-surface movements, but then kicks in and happens faster and faster until it takes less and less servo movement to trigger.
I've tried two ESE/BEC combos (both previously used and known good 60A Opto ESCs with separate 6v BECs).
I've used complete set of analog servos, and complete set of digital servos. It seems the reboots happen more frequently with the digitals.
The receiver is NOT flashing after the brown outs, but only the multi-second brownouts. I was initially trying to use a AR600, but then tried an AR8000 for troubleshooting. I noticed on the AR8000, when the brownouts happen a red light on the rx lights up, but then goes out right away after it recovers.
The telemetry reading in the DX8 DOES NOT show any holds or lost frames.
I'm totally lost, but afraid to fly this airplane!?!?! HELP!
-= GYRO =- is offline Find More Posts by -= GYRO =-
Old Jun 14, 2012, 10:31 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Have you put a meter inline and checked current draw of the servos?
cmala is offline Find More Posts by cmala
Old Jun 14, 2012, 10:47 PM
Joined Nov 2010
No I haven't, I don't have a tool for that... I suppose I'd have to build some kind of jumper for that?
but if the rx reboots/resets, shouldn't that make the light blink?
Old Jun 14, 2012, 10:49 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
I dont think dsmx blinks.
dentalpain is offline Find More Posts by dentalpain
Old Jun 14, 2012, 10:55 PM
Joined Nov 2010
Ok, but shouldn't my telemetry tell me holds and lost frames?
Old Jun 14, 2012, 10:56 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The brownout detector doesn't work with DSMX. This was a point of criticism when DSMX was announced and there was a fair bit of discussion.
The reason is that DSMX is frequency hopping. The brownout detection system needs the transmitter to be on a fixed pair of frequencies. When the power is restored, if the receiver sees the same frequencies as before the brownout, it thinks the interruption must have been accidental. That's why it flashes when you fail to turn off the transmitter (which causes it to pick a new pair of frequencies. None of this works with DSMX.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jun 15, 2012, 12:26 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Do you have a digital multimeter? Do you have a watt meter?
Old Jun 15, 2012, 03:37 AM
3DNater is online now
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
Joined Aug 2010
It seems weird that you are having the same problem with multiple sets of servos. Have you tried a different battery? It sounds like you have eliminated just about everything else. If you have not tried more than one battery have you run the motor under a load yet?
3DNater is online now Find More Posts by 3DNater
Old Jun 15, 2012, 03:47 AM
aerocal is online now
Find More Posts by aerocal
Central California
Joined Dec 2006
Interesting situation.
The frame loss and hold(flightlog) data is stored in the Rx and read by the TM at regular intervals.If/when the Rx reboots the flightlog data is reset.
After a reboot flightlog data will be rezeroed.The red led does light momentarily during bootup.It is a hold indication as well.If it blinks it is indicating a hold since its last powercycle.It also resets during reboot.
Sounds like you have something else contributing to this situation.Since you are talking about it simply doing it while holding full throws I think maybe you are allowing the servos to travel until the surfces are out of travel and they are binding and stalling the servos.
Huge HUGE current draw when this happens.
Likely 5 amps or more and possibly over 10 on a full size digital servo.
You say you notice no voltage drop.What does your min/max data show after one of these events?How are you powering the TM module? A y-harness with power and TM plugged in and the other going into the bind/data port?
If your arrangement is setup so the Rx bus is powered "downstream" of the TM connection to the power the TM may not be able to see the power loss on the Rx bus itself.Put the power into the Rx on another port(s) and plug the TM into the dataport by itself.This will give a true reading of the voltage on the Rx bus itself.
The voltage may very well be holding at an acceptable level on the Rx bus until the BEC shuts off from overload too.Then it resets and powers back on.If you do nothing to correct the overload it will likely shut off and then reset and shorter intervals as it continues its cycle.
This kind of sounds like what you have going on.There are several variations on this scenario depending on how you have things hooked up but I would venture to say stalled servos are the big factor here.
aerocal is online now Find More Posts by aerocal
Old Jun 15, 2012, 10:23 PM
Joined Nov 2010
I think you are right. I returned both the set of digitals, and the analogs today. They were the EPBUDDY.COM's OEM brand, New Power. Guess they should have been named, "Too Much Power"
I picked up a set of HS-65MGs to throw into the plane, we'll see if that fixes the problem. I've used this BEC with 4 HS-5065MGs, 4 SH-0257MGs in the past, so I'm certain its not the BEC.
I guess my final question is why no Holds or Lost Frames on the transmitter telemetry screen?
Old Jun 15, 2012, 10:33 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
If the receiver is reset (low power) then it will have 0 because that's all the frames and holds since it's last power-up. The TM1000 does NOT remember anything, it's just a pass-through device for that data.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jun 15, 2012, 10:35 PM
Joined Nov 2010
Andy
Andy,
then what is the point of the screen on the dx8 showing the F and H numbers if it doesn't count them? It seems to count the antenna numbers just fine (when flying on different airplane)
Thanks for reading this thread and weighing in.
-Gary
Old Jun 15, 2012, 10:48 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
They are only valid if you power the receiver properly. You are apparently having trouble doing that with those servos.
It's the old "garbage in, garbage out" problem. Fix the power problem and you'll see good data again.
Andy
Site Sponsor
Old Jun 15, 2012, 10:55 PM
Joined Nov 2010
Andy
While I respect your answer it seems like a cop out. So the dx8 telemetry system will only count the times rx has power trouble if the rx doesn't have any power trouble?
Seriously doesn't make sense.
I understand the servos were over amping my bec and knocking power out to the rx... But that is EXACTLY the thing I want my telemetry system to tell me about so I can trouble shoot.
Or am I missing something?
Old Jun 15, 2012, 11:16 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Gary,
Don't look at Frames and Holds to find brownout data! That's like asking your altimeter to tell you how fast you're going. If you want to know about power problems, look at the voltage data instead.
If your power problem is so severe that it kills the telemetry, there's not much anybody can do. That's a blackout, not a brownout! It takes power to transmit telemetry, and it is being sent at the same time that your servos are being updated. You need to have adequate power there for that to happen. It doesn't have to be perfect, but it has to be reasonable.
OTOH, the fact that the numbers are reset to 0 (after being non-zero) while in flight IS telling you that you have a power problem because your receiver is being reset.
The fact that the power glitch is so bad that you aren't getting telemetry data when you try to move the servos is telling you there's a HUGE power problem. If you can change it from huge to manageable, then you can start to use the telemetry to help you debug the problems.
If you suspect that there really is a big power problem (it sounds like there is), then you might try powering the telemetry separately and see what happens. You'll need to make some special cables to do that, but you can measure what's happening on the servo bus during those problem times if you use the "flight pack" input to monitor the receiver.
I don't know your skill level. Can you figure out how to do that wiring yourself? Or do you need one of us to draw it out for you?
I'm heading to bed now. I'll check back in the morning. If you need me to draw it out I'd be happy to do that.
Andy
Site Sponsor
Data Down but not out The_Builder Hand Launch 5 May 02, 2012 09:57 PM
Discussion Brand New HK OrangeRX brown out/signal fade geekrawker Radios 11 Apr 09, 2012 05:20 PM
Discussion Washed out Video on goggles but not screen? techspy FPV Talk 0 Feb 13, 2012 02:54 PM
Discussion AR6200 blinking..maybe not brown out. sajeev Mini Helis 12 Sep 09, 2008 07:35 AM
Help! BCP 4in1 lights BLINK RED-BLINK RED-SOLID RED and will not arm!! Gawker Micro Helis 15 May 01, 2007 08:56 AM
