Old Jun 16, 2012, 01:37 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
The MJX F45 is sourced from exactly hte same design house as the DH9116. It's simply a bigger version of the same heli. By all accounts, the electronics are much improved. However, it shares the 9116 design and weight issues. That makes it even more stable, with less movement authority. The design points I refer to probably won't mean much to you, but both of these helis use a 45 offset flybar with a 120 swashplate. These are the only helis made that use this combination of features, which are intended to dumb down response and movement.
Again, not a bad heli, but a poor choice as a trainer.
Balr14 is offline Find More Posts by Balr14
Old Jun 16, 2012, 02:16 PM
RCCrashTestDummy is offline
Find More Posts by RCCrashTestDummy
Finding Creative Ways To Crash
RCCrashTestDummy's Avatar
Joined Jun 2012
I see.
Balr14, I appreciate your honesty, and for taking the time to explain. Hahahaa, even though you had to explain it twice, I believe your point of considering a model that will help prepare for advancement is beginning to sink into my thick skull.
Are there a few models, let's say a "Top 3" that you can recommend with confidence? Obviously durability, (See Avatar) and availability of spare parts, will be a key factor. I guess I should also mention my reason's for considering the 9116 and F45. I was looking for a larger heli with the thought that it would be easier to see/orient direction, able to "buck" the wind a little better, and possibly carry a payload such as a camera. It sound's silly now that I see how tricky these things are to fly, but I also hoped to be able to pick-up and set down lite object's as a "test" of skills, so to speak.
Again, thanks for the help.
-Pat
RCCrashTestDummy is offline Find More Posts by RCCrashTestDummy
Discussion First Qudcopter - Hobby King Order - Check List Help Tucker33 Multirotor Talk 9 Apr 06, 2012 04:40 AM
Discussion Placed my first order with HK gunslinger7186 HobbyKing 10 Sep 15, 2011 12:46 PM
Discussion Pleas Help me with walkera 36 WK-0701 Tx kaushiksad Simulators 1 Dec 03, 2007 06:26 PM
help with first plane order merc-blue Beginner Training Area (Aircraft-Electric) 11 May 10, 2005 03:04 AM
Help With Charging Li-Po's With Triton Charger Pleas? Synthetic Batteries and Chargers 13 Dec 17, 2004 08:08 PM
