Old Jun 14, 2012, 07:03 PM
morris alabama
Joined Feb 2001
Zo fly F86 sabre
Having trouble slowing this down to get a decent landing. Also seems to take a couple hundred feet to rotate and take off. I have plenty of power and am wondering do I have a nose heavy condition. Anybody have this and did you add weight to the nose. I've seen videos of the jet taking off in 30 feet or less and not taking the whole runway to land. Every time I try to lighten the nose the jet seems to be tail heavy in flight.
tigermoth is offline Find More Posts by tigermoth
Old Jun 15, 2012, 06:06 AM
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Have one but still in build and not flown yet. However.... things necessary for jets pretty much across the board: 1 - make sure the stance on the ground is just a bit nose-up; 2 - remember that to fly, it has to have enough speed to build lift, and that may well take a good 150' or more depending on lots of things, like how heavy, how much power (batts good ones?), type of runway surface, etc.
Be aware that EDFs in general are more like real-world counterparts than the typical high-wing RC plane is. Wing loadings are somewhat higher, which means more speed is necessary to keep them flying. There's less wing area to generate lift at low speeds. Overall, they're supposed to fly like a jet does - which means you've got to fly them that way.
Speeds will be higher on landing than a Cub or Mustang, simply because of the intended use of the plane and the design of parts that goes with that use. There are always exceptions to this, but if you fly it like a jet it will work fine. Get used to thinking this way, provide for enough room in flying and landing, and it will become second nature to you quickly.
Just don't expect, or try, to fly it like you would a typical foamy warbird.
PikeStaff is offline Find More Posts by PikeStaff
Old Jun 15, 2012, 06:45 AM
morris alabama
Joined Feb 2001
It is a handful to fly and land properly that's for sure.
Old Jun 15, 2012, 11:18 AM
USA, NY, Yonkers
Joined Aug 2002
I had my maiden flight yesterday after trying for 2 weeks. The narrow rubber wheels would dig into loose dirt on the ground and make takeoff very difficult as the plane could not build up enough speed. After several days of rain here in NY, we had a full day of sunshine and the dirt on the field was smooth and hard. The f86 wheels could not dig into the hard surface and so the plane lifted off in about 50ft. It flies very nice and has a long glide when setting up for landing.
pc_pilot is offline Find More Posts by pc_pilot
Old Jun 15, 2012, 12:14 PM
morris alabama
Joined Feb 2001
Did you add any weight to the nose?
Old Jun 15, 2012, 12:53 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
A thought... my Venom F-86 is (bigger, of course) very, very sensitive to CG, especially so when it comes to forward CG. 3 or 4 mm makes all the difference in the world here, between a smooth, sweet, scale-like takeoff and a very fast, lousy-handling skateboard. Do be sure to have the nose slightly high when it's sitting on the wheels, as a slightly positive AoA is very important for takeoff on jets. If the plane has no up-tilt on the ground, AND a forward CG, it's not gonna want to rise except with a lot of elevator, and then it's gonna shoot straight up. With resulting stalls and misery.
Check the CG; if it's less than at least 25% of the chord then move it back a few mm and see how that reacts. And above all, keep speed up to where it flies on the wings, not on thrust.
Old Jun 15, 2012, 01:24 PM
USA, NY, Yonkers
Joined Aug 2002
Hello Tigermoth, I did not add any weight to the nose. I am using a 2200 4S 40c battery and it balances perfectly on the balance point in the manual.
Old Jun 15, 2012, 01:25 PM
USA, NY, Yonkers
Joined Aug 2002
Has anyone changed the wheels on their F86? I can't find wheels that fit.
Old Jun 15, 2012, 03:10 PM
morris alabama
Joined Feb 2001
I think my added weight up front might be causing my problems. I use the same battery as you do. The aoa is basically set on these so there is not much I can do about that.
Old Jun 15, 2012, 03:33 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
You can always use a larger front wheel, or smaller mains. That will help AoA to something more approaching usefulness. You don't need much here; just a couple of degrees makes it wayyy better.
Old Jun 15, 2012, 03:54 PM
morris alabama
Joined Feb 2001
Thanks. I will try smaller mains.This is one good looking arf that I am having trouble figuring out.I think most of my problem is added weight up front. I will remove and test fly.
Old Jun 15, 2012, 09:45 PM
USA, NY, Yonkers
Joined Aug 2002
You shouldn't have to add weight up front. Remove the weight and try again.
Old Jun 16, 2012, 10:11 AM
morris alabama
Joined Feb 2001
Removed the weight and crashed.Went into thick woods so I have written it off. This jet absolutely refused to fly without about an ounce or more up front. With my setup the weight made the diff between flyable or not. I did remove some of the weight and got better and slower landings but it still needed a good bit of runway to get off. I have another built that I flew this morning and it also needs the weight to fly.All in all I think that I will leave it alone as is and just keep close watch and attention while flying. It still is a very good arf as far as I am concerned.
Old Jun 16, 2012, 09:00 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
Truly sorry to hear of all your troubles. Hope the second one treats you better. Still putting mine together, may be ready by the middle of next week ( I don't work too fast any more...) and when it goes up I'll check back in and report what it does.
Old Jun 18, 2012, 04:13 PM
morris alabama
Joined Feb 2001
Found the F-86 with little damage. Weight will go back in for flight. The 3 that I have built all needed the weight to fly properly.
Sold Kyosho SQS F86 sabre wings NIP Hawker007 Aircraft - Fuel - Jets (FS/W) 0 Nov 30, 2011 12:03 AM
Sold NIB E-Flite F86 Sabre w/electronics. slowrolldoc Aircraft - Electric - Jets (FS/W) 2 Nov 02, 2011 10:27 AM
Discussion 3S set up on E-Flite F86 Sabre Pjuran Electric Ducted Fan Jet Talk 1 Oct 25, 2011 05:40 PM
Discussion E-Flite F86 Sabre ARF - Electronics Pjuran Electric Ducted Fan Jet Talk 1 Oct 21, 2011 04:28 PM
