Old Oct 07, 2012, 05:43 AM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
Quantity will be 64 to build up to 2 crafts.. make it 80.. maybe find use for others.. can you estimate the weight for each pair?
prodriverex is offline Find More Posts by prodriverex
Old Oct 07, 2012, 05:47 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
It's gonna be expensive..
Those are 3D printed by another compagny, i do the design and send it there to be printed. And 3D printing is not cheap.
Look at the price for the 16mm clamp here
No i don't know the weight but the material is real light.
You want to use my original design with a standoff or only a screw and bolt that go thru ?
Which hole spacing you need ?
Anything on which height..?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Oct 07, 2012, 06:06 AM
The Engineer
Singapore
Joined Dec 2009
Your price for qty of 30 I think is reasonable. But color got black?
Old Oct 07, 2012, 06:07 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
If you look at shapeways, there is a dropdown to choose the material.
There is Red and Black also, but cost more.
I have a friend who have dye the white part if you want to do that i can give you info on what he took.
Old Oct 07, 2012, 07:31 AM
The Engineer
Singapore
Joined Dec 2009
I just browse thru the color. Very ideal.. red for front, and black for the rear booms..
I can find out the weight by estimation.. but need to know the material pty. Irony is Im a new distri for EOS machine, but we do not have a service bureau in Singapore. The nearest is Australia.
As for the Al standoff, how is it mated to the plastic?
I prefer to have just screw and bolt so that I can mount top and bottom with something of need to like the baseplate use.
Hole spacing? Ain't that standard? Or you mean the hole size? To fit M3. What length do I need to get?
Old Oct 07, 2012, 07:34 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
There is no standard in hole to hole spacing.
You will use them on which plate?
Old Oct 07, 2012, 07:46 AM
The Engineer
Singapore
Joined Dec 2009
No I'm not using any production plate. Will be scratch built to my own design.
Say 4mm away from the circumference of the arc.. is that a good consideration for strength? I.e 35mm centre to centre of both holes.
Old Oct 09, 2012, 01:30 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Got time to play with the 25.4mm boom clamp this morning.
Let me know what you think.. I can make it the way you want..
Cutting down the material is not easy here.
Do you want to stay in normal size.. i mean do you need to have the clamp the size of a particular standoff. I have use 1.5" here...
BTW: if you make custom center plates... i could cut them for you on the CNC..!
Old Oct 09, 2012, 06:55 PM
The Engineer
Singapore
Joined Dec 2009
Thanks mate! Can't see the pic now.. I havent had the time to draw up a new plate yet but it will be made from CF so cannot print. Or u can cut CF too? That will be perfect and save me time. This will be a work multirotors so better be nice. My PC PSU is still down so can't fire up the AutoCAD..
Old Oct 09, 2012, 07:02 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I have deleted the Bart since... LOL
http://www.shapeways.com/model/73141...m-clamp-2.html
Old Oct 09, 2012, 07:04 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I can cut CF but it's expensive material.
You will need to supply it.
Old Oct 09, 2012, 07:26 PM
The Engineer
Singapore
Joined Dec 2009
Hehe.. saw it.. very nice and optimised material use. So how can I place order? Youv have to put in on the list as ready to buy? How many per plate production?
As for the CF plate, I understand. Let's see how my own DIY isotropic sheet turns out. I also ordered a honeycomb Al.. don't know what to do with it yet
Old Oct 09, 2012, 08:18 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I made that one too but it take a lot of material...
http://www.shapeways.com/model/73133...72a923ccae3b8b
Old Oct 09, 2012, 08:27 PM
The Engineer
Singapore
Joined Dec 2009
I prefer this since it will be lighter. You are making things happen!
Old Oct 09, 2012, 08:35 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Just uploading one with less material (less tall)
Will see..
Will get you an order link too..
Discussion DiaLFonZo-Copter Crazy2Fly Quadcopter 340mm Dialfonzo Multirotor Talk 87 Feb 07, 2016 06:41 AM
Build Log Unrealistic's HEXorcism 600 - Luis & DiaLFonZo-Copter unrealistic Multirotor Talk 47 Oct 23, 2012 04:09 AM
Discussion DiaLFonZo-Copter TrinitY Quad V2.0 Dialfonzo Multirotor Talk 316 Mar 12, 2012 04:46 AM
Sold Like new 500 Parts Tail, frame boom tail block main blocks motor mount rx mount blueindian Aircraft - Electric - Helis (FS/W) 2 Dec 21, 2011 02:05 PM
