Old Jun 14, 2012, 12:23 PM
essadiq is offline
Find More Posts by essadiq
essadiq's Avatar
Joined May 2012
this is my own design of a small trainer
hello
i designed my own design
and i wanna post it here ....to be checked by the members
essadiq is offline Find More Posts by essadiq
Old Jun 14, 2012, 04:01 PM
essadiq is offline
essadiq's Avatar
Joined May 2012
40 views and no one paricipe
Old Jun 14, 2012, 04:10 PM
Byrdman is offline
Find More Posts by Byrdman
Winter Haven FL
Byrdman's Avatar
Joined Dec 2003
If it balances and you have enough power on the front of it, it should fly.
Seriously though, I dont see anything that would prevent it from flying. It looks a lot like some other designs that have been posted up. It might be more stable if you extend the tail some. Other than that I dont see anything wrong with it. just keep it close due to the small size of it.
Have you ever flow before? If not, I would highly recommend using a proven plan for the first one, then build this one to experiment.
Byrdman is offline Find More Posts by Byrdman
Old Jun 14, 2012, 04:17 PM
hankg is offline
Find More Posts by hankg
Lost but making good time
Joined Nov 2008
essadiq,
I'm comparing your specs against my specs...It looks interesting. One thing that sticks out in the angle of incidence of the wing looks like it could cause you some problems. I don't think you need any angle at all with a profile model such as this. If you are worried about lift, you might want to consider a KFwing instead. I like the side view of the fusalage. Check out how Gene Bond used a KF wing on his EPP piper's wing. It both gave the wing strength, added in lift and also allowed the profile fusalage to fit into a slot for more strength.
What material are you going to build it out of...EPP, Depron. What do you think it's weight will come out to be with and without motor, battery and esc/receiver.
Regards,
Hankg
hankg is offline Find More Posts by hankg
Old Jun 14, 2012, 04:19 PM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
not a pro but i think wing should be same to stab or elev. How thick is foam
space 1 is offline Find More Posts by space 1
Old Jun 14, 2012, 05:56 PM
essadiq is offline
essadiq's Avatar
Joined May 2012
Originally Posted by hankg View Post
essadiq,
Regards,
Hankg
THANKS FOR YOU ALL GUYS
i'm so happy to share with me my work
and i'm gonna modify the plan by extending the tail .....and i'm gonna try to build it with the depron ...(and i think to get the angle of incidence in the wings ...zero)
thanks guys for help
Discussion Designing my own Woody ak79 Thermal 213 Jun 12, 2013 08:58 AM
Discussion this is my own design of a small trainer essadiq Electric Plane Talk 6 Jun 16, 2012 06:54 AM
Build Log My Litt'le Gal2 - 28"WS first own design build timatworksg Foamies (Scratchbuilt) 8 Dec 21, 2011 04:56 AM
Discussion My own design B-2 stealth with Ducted prop sukhoidave Pusher Prop Jet Models 1 Oct 31, 2011 03:17 PM
