Old Jun 14, 2012, 08:29 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Exhaust Tube? To taper or not.Opinions please
I have seen arguments for both routes..I used a straight tube on my scratch scorpion that I affixed a cone (built from a sippy cup)to at the end of the straight tube to drop the exhaust diameter..(over the last 4 to 5 inches)
I have also read that you should taper the exhaust through it's entire lenth..But have read that this increases friction along the entire lenth of the exhaust..
I need to build 2 tubes for my scratch Raptor and I'm wondering which route to take..
Any comments would be appreciated along with a little info on why you feel the way you do on this subject...
Thanks fellas for all the great info I have read and been given here at RCG..
Take care...........chris
Hover or die is offline Find More Posts by Hover or die
Old Jun 14, 2012, 08:53 AM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
Just build two tapered tubes. Make them the desired diameter at the exhaust end or 85% of fan swept area. I don't agree with the taper adding more friction than a straight run.
Doug Bateman is offline Find More Posts by Doug Bateman
Old Jun 14, 2012, 09:11 AM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
I am sure there is a magic formula, but I have always used a tapered cone.
Then I used for the exit, If I wanted thrust about 80% diameter of the fan, speed I went about 70% of the diameter.
Then I adjusted to suit my needs.
Use this program it sure makes thurst tubes super easy.
http://www.pulserate.com/
racer1 is offline Find More Posts by racer1
Old Jun 14, 2012, 09:28 AM
Joined Mar 2011
You see fellas,,2 diff opinions in 2 post...both respected!!
Doug,
Thanks for posting,yes I have read that it does and that it doesn't cause extra friction...
Racer1,
thank you for posting the link and what you choose for thrust versuses speed with fine tuning..All this info is very useful to many..
The Raptor is 62" X 44" and will probably push 10lbs(all up) so as much as I like speed I will lean towards the higher thrust exit diameter..Using 2 80mm JetFans on 6s (HET 700-68-2250)
Thanks fellas,plese keep the comments coming.........................................Chr is
Old Jun 14, 2012, 09:43 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Hover or die You could PM falcon 5, he went with straight tubes with taper on the ends for his T-38. He may have some opinion on this.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Discussion I need some help on a prop size and opinion if its going to work or not sherlockshah Pusher Prop Jet Models 1 Apr 20, 2012 10:04 PM
Question M-60 ballast tube or not? ZoomBug Slope 13 Dec 15, 2011 04:24 PM
Discussion Is tapering of CF tube size a bad idea? wopachop Foamies (Scratchbuilt) 9 Nov 19, 2011 11:13 AM
Question Taper exhaust ducting to FSA?? meteor Electric Ducted Fan Jet Talk 1 Oct 15, 2003 10:58 PM
Exhaust taper PJF Electric Ducted Fan Jet Talk 2 Feb 16, 2002 10:30 AM
