Old Dec 19, 2012, 12:11 PM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
Iv been looking for a online user manual for the DH 9116 tx as an alternative to the 9X.
What can the DH 9116 tx do.. Or not do compared to the 9X
GiantScale is offline Find More Posts by GiantScale
Old Dec 30, 2012, 09:07 PM
bflan2001 is offline
Find More Posts by bflan2001
Always borking my corter
United States, CA, Mountain View
Joined Feb 2012
Originally Posted by stormforce View Post
I did some modifications to the throttle stick also, to remove the "ratchet" feel of the throttle stick.
Open up the 9116 tx, and find the shiny metal leaf spring on the throttle stick. Remove it and sand down the ridges on the curved part of the throttle stick (not totally, just enough to take the edge off the ridges, as you'll still need some grip). Then flatten the ridge on the leaf spring and slip a few layers of heatshrink tubing over the end of the leaf spring where it contacts the curved part of the throttle stick. Mildly flatten out the section of the leaf spring where it screws into the housing to increase the normal tension on the throttle stick. Re-assemble the mechanism and fine tune the spring tension by tightening the screw to suit your preference.
There should be a large disclaimer following these instructions that warn people how much of a royal pain in the ass it is to reassemble the transmitter after removing the stick. You can save a TON of time by not removing it and just sanding it down with the stick in place. Putting it back together is like trying to build a house of cards in your hands. There are multiple pieces and every one has to be perfectly lined up for the stick to go back together. I just spent a half hour messing with mine and it's still not back together.
bflan2001 is offline Find More Posts by bflan2001
Old Dec 30, 2012, 11:45 PM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Tx ratchet mod...
Hi,
Sorry, but I think that you're mis-reading the post...
There's no ref; to actually removing the Tx stick assy in the post.
Or, alternately, replace the leaf spring with a full length, thin slice of steel sheet (metal yard fencing sheet steel works well), and drill two holes in either end and screw in one screw completely on one end of the new leaf spring and use the opposite end screw to increase the tension on the spring to suit your stick resistance preference.
If you find it's too tight and you don't have much adjustment, use a light rub of candle wax on the curved part of the throttle housing, but not too much as it may make the throttle stick flop all over the place, especially if you can't apply enough tension to the new spring. You want it to be firm, but to be easily moved.
As you found, it just requires you to sand or file the teeth down a little to reduce the strong ratchet effect & adjusting the spring tension in the (shiny) bar.
Apply a little dry lube if nec.
L..
Rajah235 is offline Find More Posts by Rajah235
Old Jan 12, 2013, 01:26 PM
Iowa City Iowa
Joined Jun 2000
Just received a few 9116 Tx's and although they are a improvement.. Im disappointed in the dead band center stick. Anyway.. the rudder is much more manageable and the feel is overall better. But seems the rudder trim does nothing..
I dont understand what these are.. what do they do?
press of the SEL button, AILE SUB L flashes - 000
press of the SEL button, THRO SUB F flashes - 000
press of the SEL button, RUDD SUB L flashes - 000
press of the SEL button, back to ELEV SUB F flashes - 000
press of the MENU button, THRO TRI 0 - 000%
press of the SEL button, THRO TRI 1 - 025%
press of the SEL button, THRO TRI 2 - 050%
press of the SEL button, THRO TRI 3 - 075%
press of the SEL button, THRO TRI 4 - 100%
press of the SEL button, back to THRO TRI 0 - 000%
Old Jan 27, 2013, 06:16 AM
fishawk is offline
Find More Posts by fishawk
Joined Jan 2013
hi fun posted in the wrong place with the wrong subject I apologize. I'm looking for anything possible ways of changing the stick configuration of my the 911 stock controller. I fly the symai s 107 G and I absolutely love it. I bought the v911 4 channel and I like it, however I DESPERATELY want the rudder control on the right stick like the 3 channel.Is it possible to bridge/jump the circuit traces trading sides or some kind of programming change that could be done? Judging by the posts I have read it's apparent some of you really know what your doing. Maybe this is rediculous to you but I refuse to simply get used the existing configuration. My S107G and my RC planes all have the right stick configuration the same.ANY feedback would be greatly appreciated. JB
fishawk is offline Find More Posts by fishawk
Old Jan 27, 2013, 07:33 AM
Gygax is offline
Find More Posts by Gygax
FPV Plank Scratcher
Gygax's Avatar
Australia, NSW, Keerrong
Joined Jan 2013
hey fishawk
i suggest buying a 9116 tx (maybe about $20?) and following the instructions from the great Stormforce to convert the tx from mode 2 to mode 1. (which changes the rudder to the right stick)
9116 tech manual - http://www.rcgroups.com/forums/showa...1&d=1340883143
then bind it to your 911
Gygax is offline Find More Posts by Gygax
Old Jan 31, 2013, 07:08 PM
MicroHeliManiac is offline
Find More Posts by MicroHeliManiac
Joined Dec 2012
Just wondering if anyone has posted a complete list of settings on the 9116 TX that would be optimal for flying the v929 quad? How would you compensate the 20 40 60 100% rates on the 9116 TX or flipping? Just got the 9116 TX and am a noob when it comes to it. Thanks in advance
MicroHeliManiac is offline Find More Posts by MicroHeliManiac
Old Feb 01, 2013, 06:15 AM
Iowa City Iowa
Joined Jun 2000
I dont have the V929 so can only comment on my V911's.. But I never messed with the throttle. I only had to reverse some of the servos. rudder and elevator I think. Then used the high dual rate as my main program and dialed the expo down on the AILE and RUDD. Then I have to remember to go the rudder sub-trim before I fly to make the rudder trim actually work, but with the up and down buttons instead of the trim switch. Its to bad the 9116 has no mixing capability's, but how much can you expect from a $11 Tx?
Old Feb 23, 2013, 12:17 PM
jwilkers is offline
Find More Posts by jwilkers
FA39WNXCP3
United States, OH, Worthington
Joined Dec 2012
I just got my DH controller.... Followed the instructions at top of thread.... absolutely ZERO rudder operation at all. any stick....
display shows no bars when rudder moved.... left stick also feels rough... not smooth movement like right stick.
Do I have a bad controller?
jwilkers is offline Find More Posts by jwilkers
Old Feb 24, 2013, 05:18 PM
jwilkers is offline
FA39WNXCP3
Joined Dec 2012
Fixed it... opened it up and there was some error in assembly... stick evidently wasn't seated properly in its mount.
Old Sep 11, 2013, 10:39 AM
hifinsword is online now
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
Flying the V9xx & V9x9 with a DH 9116 Tx
Originally Posted by jamiedg View Post
Hi eertan,
see the below 9116 guide which covers the bind process.
http://customers.skymesh.net.au/%7Em...ech_manual.pdf
The simple v911 bind process is;
1. Insert the lipo battery in the v911 heli - Rx board led flashes.
2. Then make sure the Tx throttle is fully down and switch on the 9116 Tx.
3. Once the normal bleeps have finished you should have bind - Rx board led now steady.
4. Follow the previous posts in this thread to reverse the Rudder and Ailerlon controls
cheers,
My Beetle arrived last week
Just a note to confirm that the WLtoys beetle v929 quadcopter works fine with the 9116 Tx. The stock Tx is fine but I like having the individual control on rates, tend to use rudder on 50% which gives a slower turn.
Follow prev post to reverse RUDD and ELEV.
So it reverse RUDD & AIL for the WL Toys V9xx series, and reverse RUDD & ELEV for the WL Toys V9x9 series?
hifinsword is online now Find More Posts by hifinsword
Question DH 9116 new TX won't work, lites work Sculptor Beginner Training Area (Heli-Electric) 12 Jun 28, 2012 03:50 PM
Help! DH 9116 LCD settings question Sculptor Beginner Training Area (Heli-Electric) 17 Apr 20, 2012 07:15 AM
Discussion DH 9116 TX has a speed step in throtle Sculptor Beginner Training Area (Heli-Electric) 2 Mar 10, 2012 07:42 PM
Help! Noob with dh 9116 charging issue Skeye1022 Beginner Training Area (Heli-Electric) 7 Jan 05, 2012 08:41 AM
